what to do with my pitot
sperry50(at)comcast.net
PostPosted: Wed Jan 03, 2007 6:34 pm    Post subject: what to do with my pitot Reply with quote
I am building a 601XL from a quick build kit and will be nearing the point where I have to make some pitot decisions. I plan to put in the Dynon D-100 and their website shows an optional pitot that gives angle of attack. My question is if I am building VFR do should I do it?
I would welcome any comments from those of you who have actually used this set-up. From the looks of things the AOA pitot uses an angle of attack tube and a pitot tube but no static tube so I suppose I would have to make my own static port. The pitot that comes with the kit already has this but will not work with the AOA. Any real experienced answers would be greatly appreciated.
Skip Perry
601XL (quick-build with all the first run faultsJ)
Fort Myers, Florida
DO NOT ARCHIVE [quote][b]
p.mulwitz(at)worldnet.att
PostPosted: Wed Jan 03, 2007 7:12 pm    Post subject: what to do with my pitot Reply with quote
Hi Skip,
I feel your pain.
The AOA has nothing to do with IFR flight. It is used to tell you how close to a stall your plane is. The notion (I haven't tried it yet, but I have been lectured continuously for a year or two by several of my local chapter members) you use the AOA to adjust your approach speed to allow minimum landing distance without getting too slow so you stall and crash. It automatically adjusts to different aircraft loads and weather conditions so you can fly close to the edge and get maximum results. It also can be used for minimum speed takeoff and climb.
I think you can purchase the probe from Dynon for installation before you are ready to buy the big expensive electronic box for your instrument panel. This is probably a good idea since they will probably improve the box in the time between your pitot installation and your first flight. It is best to put off the purchase of any electronic stuff until you really need it.
I can't give any great advice on the static port question. It is somewhat a black art to determine how to position one or two of these things to give you unbiased airspeed and rate of climb readings. Surely you don't need to do it the way the kit is arranged to get good results.
Good luck,
Paul
XL fuselage
At 06:33 PM 1/3/2007, you wrote:
[quote] I am building a 601XL from a quick build kit and will be nearing the point where I have to make some pitot decisions. I plan to put in the Dynon D-100 and their website shows an optional pitot that gives angle of attack. My question is if I am building VFR do should I do it?
Skip Perry
601XL (quick-build with all the first run faultsJ )
Fort Myers, Florida
Ron Lendon
PostPosted: Wed Jan 03, 2007 9:15 pm    Post subject: Re: what to do with my pitot Reply with quote
Skip,
I was going to begin fabricating one last night but have the same problem you have. I will be following Pauls suggestion and getting the Pitot / AOA from Dynon.
Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
jnjkimbell(at)HOTMAIL.COM
PostPosted: Thu Jan 04, 2007 5:08 am    Post subject: what to do with my pitot Reply with quote
Skip, I use the Dynon D-100 and installed the AOA after the wing was built. If you decide to use it, do it now, kBey difficult later, but doable. The AOA is basically a stall indicator and I got it for my 701 to help on short field landings. Turned out to be wasted money and time on my AC as my stall (read mush) speed with power off is to slow for Dynon to read. Probably would not be a problem on the 601. Not much help for your setup, but as they say, My 2 cents worth. DO not archive. Joe from Fl.----- Original Message -----
[quote] From: Skip Perry (sperry50(at)comcast.net)
To: zenith-list(at)matronics.com (zenith-list(at)matronics.com)
Sent: Wednesday, January 03, 2007 9:33 PM
Subject: what to do with my pitot
I am building a 601XL from a quick build kit and will be nearing the point where I have to make some pitot decisions. I plan to put in the Dynon D-100 and their website shows an optional piton that gives angle of attack. My question is if I am building VFR do should I do it?
Skip Perry
Fort Myers, Florida
DO NOT ARCHIVE
href="http://www.matronics.com/Navigator?Zenith-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
dbortol
PostPosted: Thu Jan 04, 2007 6:19 am    Post subject: what to do with my pitot Reply with quote
My plan is to use the D-100 (or whatever is around by the time I get
to that point!) without the AOA feature, and the lift reserve
indicator (LRI) as described on ch601.org. The LRI will keep right on
going should the EFIS quit for any reason, and along with a few other
backup instruments should allow a safe conclusion to the flight.
Dino Bortolin
601XL/Corvair (tail)
[quote] from Fl.---
Float Flyr
PostPosted: Thu Jan 04, 2007 6:28 am    Post subject: what to do with my pitot Reply with quote
The static port is usually positioned at a point on the fuselage where the Bernoulli principal is least. This will be a relatively flat place which is parallel to the direction of travel. It can also be part of the pitot probe. I'm sure the plans for your plane will give you the optimum location.
My advice is to install two static ports, one on the opposite side of the fuselage, and Tee them together to the static port of your ASI, Alt and VSI inputs. That way a slip or uncoordinated flight won't upset your EFIS readings.
As for the AOA probe I'd go for it because it can come in handy when you are used to using it. some call the AOA a lift reserve indicator. The idea is to touch down just as the wing stalls and to take off as soon after wing stall as possible. Weight of the probe is not too much of a factor just remember with two pitots you will have to keep the probe covered on the ground. Sort of a double jeopardy.
The pricing of electronic flight instruments has been more or less stable over the last few years and no doubt newer and better will come along but you want to fly today.
Noel [quote]
Skip Perry
Fort Myers, Florida
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
dredmoody(at)cox.net
PostPosted: Thu Jan 04, 2007 7:09 am    Post subject: what to do with my pitot Reply with quote
The pitot that came with your kit has two probes, one is a pitot tube and the other is a static source. I recommend buying and learning to use the AOA sensing probe from Dynon if you are going to use their EFIS/EIS unit. Approach and deparutre flown by reference to a calibrated, functioning AOA system is much safer than trying to calculate stall speed in various weather conditions, aircraft configurations and weights.
Mount the kit provided unit on the opposite wing following the plans' directions. You can either "T" the pitot lines together and the unit will "see" the average of the two installations, or you can connect them to a valve accessible inflight to establish an "either/or" option. Either one will work with the Dynon unit's airspeed sensing device. The benefit of two pitot tubes is that one can smack a bug and cease to function until you land and clear it.... rare but possible.
The kit provided static source can be used as your only one or can be backed up by a second one (they have been known to ice over).
Ed Moody II
Rayne, LA
601XL/Jabiru/Flap motor
pilot4pay
PostPosted: Thu Jan 04, 2007 7:37 am    Post subject: what to do with my pitot Reply with quote
I would like to give the group a heads up as to another valuable function of
the AOA indicator. It can be used to determine your aircrafts most efficient
cruise angle of attack. By taking a series of data points (MP, Fuel flow,
IAS, AOA) plot the data on a graph and find you optimum AOA. This ideal AOA
is the same for all weights.
I would refer you to FLYING HIGH PERFORMANCE SINGLES AND TWINS by John
Eckalbar Ch. 9.
For now I'll spare you all the math and such, but the AOA really is useful
for more than just flying the approach phase of flight. It can help you
stretch your fuel, and learn if airframe modifications help or hinder your
efficiency.
Craig Smith
Future CH801 builder
Craig Smith
CH640 builder
SN: 0078
"Just think how stupid the average person is,
and then realize that half of them are even stupider!"
--George Carlin
pacificpainting(at)comcas
PostPosted: Thu Jan 04, 2007 7:38 am    Post subject: what to do with my pitot Reply with quote
I'm using a unit from riteangle(at)aoa.com. I have never had better customer
service. It doesn't use probes that can get plugged up. Check it out.
Dave
Gig Giacona
PostPosted: Thu Jan 04, 2007 7:57 am    Post subject: Re: what to do with my pitot Reply with quote
I too am going with the Dynon but I finished my wings before I made that decision. So I only have 2 pitot/static lines running out to the wing and I have the holes positioned for the factory pitot/static tube.
I chose not to go ahead and mount the tube at the time because I figured it would get broken off during moving the wing around.
My plan now is to use the Dynon probe with AOA and use the two lines that are out there for Pitot and AOA and mount the static port somewhere on the fuselage.
W.R. "Gig" Giacona
601XL Under Construction
PostPosted: Thu Jan 04, 2007 8:09 am    Post subject: what to do with my pitot Reply with quote
If a late installation is necessary, cut an inspection port at the pitot / AOA location and do the installation on the hatch cover. Some guys in the list have done that from the get-go just to facillitate removing the pitot rig to prevent damage in storage and handling of the wings.
Ed Moody II
---- Joe and Joan <jnjkimbell(at)HOTMAIL.COM> wrote:
what to do with my pitotSkip, I use the Dynon D-100 and installed the AOA after the wing was built. If you decide to use it, do it now, kBey difficult later, but doable.
btucke73(at)yahoo.com
PostPosted: Thu Jan 04, 2007 8:30 am    Post subject: what to do with my pitot Reply with quote
Skip,
I installed the Dynon pitot tube, intending on
using the Dynon unit in the future. I did not install
it. the unheated pitot tube from dynon is not too
expensive, and is of good quality. Even if you do not
use the AOA function of the Dynon in the future, you
will have installed a nice pitot tube. I plan to add
a LRI sometime soon, connecting it to the dynon probe.
I installed the static port half way between the
wing and the horizontal stabilizer, with good results.
As Paul mentioned, AOA indication compensates for
aircraft weight. It tells you exactly what is going
on with your wing. Whenever we were in the landing
configuration in the Hornet, after the initial
airspeed check, we never referenced the airspeed
indicator again. We flew completely off of AOA
indication. This allowed us to land on the carrier at
the slowest practical speed, regardless of aircraft
weight. Maximum trap was 34000 lbs, and typical empty
weights were 25 - 26000 lbs. Calculating the landing
speed based on this kind of weight difference is not
the kind of cockpit math I wanted to do, especially
when trying to land on the postage stamp.
Unless you are dropping into very small
airfields, you may never use it. But...
VR/
Brandon Tucker
601 HDS / TD / Corvair
45 hours
Gig Giacona
PostPosted: Thu Jan 04, 2007 9:29 am    Post subject: Re: what to do with my pitot Reply with quote
Where exactly did you place the Static port? I've been looking for an answer to that question for a while now.
btucke73(at)yahoo.com wrote:
Skip,
Brandon Tucker
45 hours
W.R. "Gig" Giacona
paulhartl(at)cox.net
PostPosted: Thu Jan 04, 2007 9:47 am    Post subject: what to do with my pitot Reply with quote
Hi Skip,
I have the Dynon D10 (early model) in my HDS and use their pitot tube for
both IAS and AOA. I highly recommend using Dynon's pitot with their
instrument - it works well, and AOA is (once properly calibrated) the
instrument that you will grow to love. It's what the Navy teaches their
carrier
pilots to watch most closely on approach for carrier landings, and it will
help you nail your landings, too - once you learn to use it. It also could
save
your life by helping to avoid the classic base-to-final stall/spin accident.
Paul Hartl, N414PZ, 601 HDS, Jab 3300A
82 hours, 96 landings - lots of fun!
Hailey, Idaho
http://members.cox.net/paulhartl/
RURUNY(at)aol.com
PostPosted: Thu Jan 04, 2007 5:15 pm    Post subject: what to do with my pitot Reply with quote
Hey Skip,
I purchased that Dynon pitot tube for my D10-A and it is a solid and heavy installation compared to the stock pitot with the kit. My 701 did not come with any static port parts or a pitot with a static port. You will also need a pitot mast and plumbing to finish this installation, they are both available at http://www.safeair1.com .I did purchase a pitot with a static port before I decided on a Dynon. But I wanted the option to not install the Dynon pitot tube If I wanted. I had made an access panel for inspection of the strut attachment on my 701, but also made the access the mounting point for the pitot. I made 2 exact panels and then installed the dynon on one and the dual pitot static on the other. This way I can change them out easily. I also installed static ports on the fuselage, so I have a static port while using the dynon pitot(got that from safeair also). The AOA blue tube becomes another static port with the other pitot.
The pitot mast is steel. If someone bumps into this hard enough I could see it ripping open my .016 wing instead of breaking off. Just make sure you run 2 tubes to your pitot area. I'm sure this could be an option for you to do. If your getting a Dynon it would be kind of a waste not taking advantage of this feature, but it costs a couple bucks to do. See pics attached.
Brian
 Filesize:  43.31 KB
 Viewed:  614 Time(s)
 Filesize:  22.84 KB
 Viewed:  598 Time(s)
 Filesize:  23.75 KB
 Viewed:  591 Time(s)
 Filesize:  34.36 KB
 Viewed:  610 Time(s)
 Filesize:  50.47 KB
 Viewed:  608 Time(s)
 Filesize:  73.48 KB
 Viewed:  600 Time(s)
gfmjr_20(at)HOTMAIL.COM
PostPosted: Fri Jan 05, 2007 2:12 pm    Post subject: what to do with my pitot Reply with quote
Skip
I'm flying with both the Dynon D100 and D180 with the Dynon pitot. I use
a split feed to both units for the AOA and Pitot. In addition I installed 2
Static ports on the rear of the fuse T'd along the lower longeron just in
front of the stab and split to the two Dynon units. I mounted the Dynon
pitot in the center of a round inspection plate. I like the set up very
much and would recommend it for your VFR needs. With 40 flight hours so far
all is working well.
George May
601XL 912s 40 hours
Reply-To: zenith-list(at)matronics.com
To: <zenith-list(at)matronics.com>
Date: Wed, 3 Jan 2007 21:33:43 -0500
own
not
appreciated.
Skip Perry
601XL (quick-build with all the first run faults:-))
Fort Myers, Florida
DO NOT ARCHIVE
Communicate instantly! Use your Hotmail address to sign into Windows Live
Messenger now. http://get.live.com/messenger/overview
PostPosted: Fri Jan 05, 2007 8:56 pm    Post subject: what to do with my pitot Reply with quote
Gig,
I put my static port about mid way between the
trailing edge of the wing and the leading edge of the
horizontal stab. It is pretty much centered between
the vertical stiffening ribs, and the upper and lower
longerons. This is the approximate location of the
static port on the T-34c, so I just went with it. My
EFIS requires calibrating the airspeed indicator,
which I did with GPS. It is tracking very nicely now.
disclaimer: You should follow the plans. If you
don't, this location worked for me.
VR/
Brandon
HDS / 46 hours
