Dawg
Posted: Mon Sep 10, 2018 12:33 pm Post subject: weird bumping (thumping noise) sound from the Jet??? Help |
Iron count up? Do you use a pump to put oil in?What kind of oil?
Stops bumping with tail off, fly with tail off! LOL.
IS IT MORE bumping at around 80%?
On Mon, Sep 10, 2018, 12:02 skidmk <skidmk(at)gmail.com (skidmk(at)gmail.com)> wrote:
| Quote: | --> L29-List message posted by: "skidmk" <skidmk(at)gmail.com (skidmk(at)gmail.com)>
Folks,
anyone experience this issue?
Low time engine
Mike "Skidmk" Bourget
Ottawa, Ontario
http://forums.matronics.com/viewtopic.php?p=483074#483074
List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?L29-List
| | - The Matronics L29-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?L29-List |
_________________ Dawg |
Dawg
Posted: Tue Sep 11, 2018 10:08 am Post subject: weird bumping (thumping noise) sound from the Jet??? Help |
Did you get any of my questions via this site?
skidmk
Joined: 19 Nov 2007 Posts: 171 Location: Ottawa, Ontario
Posted: Wed Sep 12, 2018 10:09 am Post subject: Re: weird bumping (thumping noise) sound from the Jet??? Hel |
Hey Dawg,
Got the questions, we use oil from the can direct. Mobil. As for the thumping noises,, not really noticed at 80% or not. Most prevalent during take-off (100%) less so in cruise 85-90. It seems that it is getting more prevalent, up to and including the bumping on shut down this time.
there is no variation in any op specs on the T's and P's.
there is no evidence of flaming, or pop flames coming our of the tail.
there is what I feel maybe more than normal soot on the tailcone (in the vicinity of the antenna's)
what might you be thinking about the 80%?
I will change the fuel filter tomorrow, aerate (bleed) the fuel system and see if that cures it.
_________________ Mike "Skidmk" Bourget
Ottawa, Ontario |
skyking76t(at)verizon.net Guest
Posted: Wed Sep 12, 2018 10:16 am Post subject: weird bumping (thumping noise) sound from the Jet??? Help |
Have u cleaned the injectors? Had a thumping when power back in decent at 80-85%. Cleaned injectors and went away
| Quote: | On Sep 12, 2018, at 2:09 PM, skidmk <skidmk(at)gmail.com> wrote:
Hey Dawg,
Ottawa, Ontario
http://forums.matronics.com/viewtopic.php?p=483146#483146
skidmk
Posted: Wed Sep 12, 2018 10:21 am Post subject: Re: weird bumping (thumping noise) sound from the Jet??? Hel |
yes sir ultrasonically cleaned, about 3 hours ago. symptoms went away for about 3 hours, and are now back with a vengeance.
Ottawa, Ontario |
l29delfin(at)yahoo.com Guest
Posted: Wed Sep 12, 2018 10:36 am Post subject: weird bumping (thumping noise) sound from the Jet??? Help |
What exact oil are you using in the M701p?
On September 12, 2018 13:11:53 "skidmk" <skidmk(at)gmail.com> wrote:
Hey Dawg,
Ottawa, Ontario
Dawg
Posted: Wed Sep 12, 2018 12:34 pm Post subject: weird bumping (thumping noise) sound from the Jet??? Help |
Stock engine uses a mineral oil. Royco 481. (or Shell sp3 or 3sp, can’t remember which) Mobile jet and 2380 are synthetic. May cause metal in your sample.
Had several airplanes that rumbled around 80% never had any other issues.
Is the thumping a metallic sound? Had one of those. Required new engine to stop the thumping.
| Quote: | On Sep 12, 2018, at 12:16, Anthony Royal <skyking76t(at)verizon.net> wrote:
> Hey Dawg,
> Ottawa, Ontario
migfighter42(at)gmail.com Guest
Posted: Wed Sep 12, 2018 10:06 pm Post subject: weird bumping (thumping noise) sound from the Jet??? Help |
My previous L-29 would make that kind of noise (hollow thumping) at cruise settings 80-90% power. Not engine related, I believe it was just the inlet ducting. I inspected it numerous times and found no issues. Normal.
Bill Culberson
Red Star Aero Services
251/716/8119
| Quote: | On Sep 12, 2018, at 3:22 PM, William Geipel <l129bs(at)gmail.com> wrote:
> Sent from my iPhone
>> Hey Dawg,
>> Ottawa, Ontario
skidmk
Posted: Thu Sep 13, 2018 8:09 am Post subject: Re: weird bumping (thumping noise) sound from the Jet??? Hel |
Use Mobil jet. I’ll change it at the next oil change <5 hours.
New this am I saw today. Start up only 540 on the get, goes to 38%, then the get drops down to 370 and stabilized there. (To low imho) Upon shut down loud bump. I’ll try and record it.
The manual talks about an air filter?? Never heard of that
Ottawa, Ontario |
cslamuseum(at)gmail.com Guest
Posted: Thu Sep 13, 2018 10:13 am Post subject: weird bumping (thumping noise) sound from the Jet??? Help |
Mobil is absolutely wrong and damaging for m701p.
Only mineral oil.
Dawg
Posted: Thu Sep 13, 2018 2:45 pm Post subject: weird bumping (thumping noise) sound from the Jet??? Help |
It might scrub the engine a little to much maybe creating a little iron in the stew.
skidmk
Posted: Wed Sep 26, 2018 5:52 am Post subject: Re: weird bumping (thumping noise) sound from the Jet??? Hel |
so, an update.
noise on shutdown isolated to the bottle left burner can. It sounds like the injector, or the liner has broken/come loose. The EGT on start up goes to 575, then settles at 325 which is too low.
Taking the can off to inspect the can, and the blades. Evidence of scorching on the outside of the can. I'm hoping a simple burner/injector replacement will solve the issue.
Otherwise a new engine is in order I would suspect
1.92 MB |
19422 Time(s) |
Ottawa, Ontario |
