weird bumping (thumping noise) sound from the Jet??? Help
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List
Dawg
PostPosted: Mon Sep 10, 2018 12:33 pm    Post subject: weird bumping (thumping noise) sound from the Jet??? Help Reply with quote
Iron count up? Do you use a pump to put oil in?What kind of oil?
Stops bumping with tail off, fly with tail off! LOL.
IS IT MORE bumping at around 80%?
On Mon, Sep 10, 2018, 12:02 skidmk <skidmk(at)gmail.com (skidmk(at)gmail.com)> wrote:
--> L29-List message posted by: "skidmk" <skidmk(at)gmail.com (skidmk(at)gmail.com)>
Folks,
anyone experience this issue?
Low time engine
Mike &quot;Skidmk&quot; Bourget
Ottawa, Ontario
http://forums.matronics.com/viewtopic.php?p=483074#483074
List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?L29-List
- The Matronics L29-List Email Forum -
Dawg
Dawg
PostPosted: Tue Sep 11, 2018 10:08 am    Post subject: weird bumping (thumping noise) sound from the Jet??? Help Reply with quote
Did you get any of my questions via this site?
On Sep 11, 2018, at 11:23, Alekh <lekhkar(at)telus.net> wrote:
Is turbine stop time no change/variance from when it was normal?
Andy
http://forums.matronics.com/viewtopic.php?p=483108#483108
Dawg
skidmk
PostPosted: Wed Sep 12, 2018 10:09 am    Post subject: Re: weird bumping (thumping noise) sound from the Jet??? Hel Reply with quote
Hey Dawg,
Got the questions, we use oil from the can direct. Mobil. As for the thumping noises,, not really noticed at 80% or not. Most prevalent during take-off (100%) less so in cruise 85-90. It seems that it is getting more prevalent, up to and including the bumping on shut down this time.
there is no variation in any op specs on the T's and P's.
there is no evidence of flaming, or pop flames coming our of the tail.
there is what I feel maybe more than normal soot on the tailcone (in the vicinity of the antenna's)
what might you be thinking about the 80%?
I will change the fuel filter tomorrow, aerate (bleed) the fuel system and see if that cures it.
Mike "Skidmk" Bourget
Ottawa, Ontario
skyking76t(at)verizon.net
PostPosted: Wed Sep 12, 2018 10:16 am    Post subject: weird bumping (thumping noise) sound from the Jet??? Help Reply with quote
Have u cleaned the injectors? Had a thumping when power back in decent at 80-85%. Cleaned injectors and went away
On Sep 12, 2018, at 2:09 PM, skidmk <skidmk(at)gmail.com> wrote:
Hey Dawg,
Ottawa, Ontario
http://forums.matronics.com/viewtopic.php?p=483146#483146
skidmk
PostPosted: Wed Sep 12, 2018 10:21 am    Post subject: Re: weird bumping (thumping noise) sound from the Jet??? Hel Reply with quote
yes sir ultrasonically cleaned, about 3 hours ago. symptoms went away for about 3 hours, and are now back with a vengeance.
Ottawa, Ontario
l29delfin(at)yahoo.com
PostPosted: Wed Sep 12, 2018 10:36 am    Post subject: weird bumping (thumping noise) sound from the Jet??? Help Reply with quote
What exact oil are you using in the M701p?
On September 12, 2018 13:11:53 "skidmk" <skidmk(at)gmail.com> wrote:
Hey Dawg,
Ottawa, Ontario
Dawg
PostPosted: Wed Sep 12, 2018 12:34 pm    Post subject: weird bumping (thumping noise) sound from the Jet??? Help Reply with quote
Stock engine uses a mineral oil. Royco 481. (or Shell sp3 or 3sp, can’t remember which) Mobile jet and 2380 are synthetic. May cause metal in your sample.
Had several airplanes that rumbled around 80% never had any other issues.
Is the thumping a metallic sound? Had one of those. Required new engine to stop the thumping.
> Hey Dawg,
> Ottawa, Ontario
Dawg
migfighter42(at)gmail.com
PostPosted: Wed Sep 12, 2018 10:06 pm    Post subject: weird bumping (thumping noise) sound from the Jet??? Help Reply with quote
My previous L-29 would make that kind of noise (hollow thumping) at cruise settings 80-90% power. Not engine related, I believe it was just the inlet ducting. I inspected it numerous times and found no issues. Normal.
Bill Culberson
Red Star Aero Services
251/716/8119
> Sent from my iPhone
>> Hey Dawg,
>> Ottawa, Ontario
skidmk
PostPosted: Thu Sep 13, 2018 8:09 am    Post subject: Re: weird bumping (thumping noise) sound from the Jet??? Hel Reply with quote
Use Mobil jet. I’ll change it at the next oil change <5 hours.
New this am I saw today. Start up only 540 on the get, goes to 38%, then the get drops down to 370 and stabilized there. (To low imho) Upon shut down loud bump. I’ll try and record it.
The manual talks about an air filter?? Never heard of that
Ottawa, Ontario
cslamuseum(at)gmail.com
PostPosted: Thu Sep 13, 2018 10:13 am    Post subject: weird bumping (thumping noise) sound from the Jet??? Help Reply with quote
Mobil is absolutely wrong and damaging for m701p.
Only mineral oil.
Ottawa, Ontario
http://forums.matronics.com/viewtopic.php?p=483161#483161
Dawg
PostPosted: Thu Sep 13, 2018 2:45 pm    Post subject: weird bumping (thumping noise) sound from the Jet??? Help Reply with quote
It might scrub the engine a little to much maybe creating a little iron in the stew.
Ottawa, Ontario
Dawg
skidmk
PostPosted: Wed Sep 26, 2018 5:52 am    Post subject: Re: weird bumping (thumping noise) sound from the Jet??? Hel Reply with quote
so, an update.
noise on shutdown isolated to the bottle left burner can. It sounds like the injector, or the liner has broken/come loose. The EGT on start up goes to 575, then settles at 325 which is too low.
Taking the can off to inspect the can, and the blades. Evidence of scorching on the outside of the can. I'm hoping a simple burner/injector replacement will solve the issue.
Otherwise a new engine is in order I would suspect
 Filesize:  1.92 MB
 Viewed:  19421 Time(s)
Ottawa, Ontario
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List All times are GMT - 8 Hours
