Cargo area?
bigboyzt0yz
PostPosted: Tue Jan 29, 2008 6:58 pm    Post subject: Cargo area? Reply with quote
I have looked at a couple of other planes (highlander Video on You tube) and on just Planes link. It shows them putting a dog in the back and a then a little scooter(not at the same time). I was wondering has any one found a GOOD way to use the space and if so how do you gain access to the area with out hurting the plane. And then there is the issue of having weight behind the CG to deal with.
Lee Fritz in Owings Mills Md. 2002 KitFox-IV Classic/912UL/Warp drive taper tip/100% Complete ( Extras Strut fairings08, Grove gear09,) 300 hrs since Aug 07 "Have your feet on the Pedals and keep reaching for the sky".
Guy Buchanan
PostPosted: Tue Jan 29, 2008 7:35 pm    Post subject: Cargo area? Reply with quote
I think it depends on the plane. My IV has a nice cubical
baggage compartment behind the seats good for 40 pounds of stuff.
It's probably 24"W x 24"L x 24"H, maybe a little wider. I think the
later models have even larger capacity, whereas the 1-3 models had
very little room due to the flaperon mechanism.
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
avidfox
PostPosted: Tue Jan 29, 2008 8:39 pm    Post subject: Re: Cargo area? Reply with quote
Attached are some pictures of access to the baggage\cargo compartment on a stock Series 5. Max weight is 150 lbs.
Steve
"5" 912UL
 Filesize:  199.88 KB
 Viewed:  735 Time(s)
 Filesize:  228.96 KB
 Viewed:  644 Time(s)
Lynn Matteson
PostPosted: Tue Jan 29, 2008 9:07 pm    Post subject: Cargo area? Reply with quote
I've got the baggage sack, which holds 40 lbs. I don't know whether
this is due to the velcro straps that hold the sack in place, or
whether it is a weight and balance thing. I've calc'd the weight for
my plane and I *could* add more than that, but I'd be afraid to,
because of the velcro. Mine is covered by a...again...velcro'd panel
of the same fabric as that used on the seats. I've loaded 39 lbs 10
oz's into this sack with no problems. Others have fabricated a metal
container back there.
As far as a "GOOD" way to use the space, I carry a tent, sleeping
bag, folding chair, air mattress, air pump, pillow, collapsible
cooler, tools...you get the idea.
Lynn Matteson
Grass Lake, Michigan
flying w/460+ hrs
On Jan 29, 2008, at 9:58 PM, bigboyzt0yz wrote:
<bigboyzt0yz(at)yahoo.com>
Have your feet on the Pedals and keep reaching for the sky.
http://forums.matronics.com/viewtopic.php?p=161253#161253
Lynn
Kitfox IV-Jabiru 2200
N369LM
dave
PostPosted: Tue Jan 29, 2008 9:23 pm    Post subject: Re: Cargo area? Reply with quote
Lynn, I have eyelets on my baggage sack and I use tie wraps to hold it in place. This I feel is more secure than Velcro. I have pondered making a alum bin behind seat, but not got to it yet.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube
Guy Buchanan
PostPosted: Tue Jan 29, 2008 10:44 pm    Post subject: Cargo area? Reply with quote
The question is, would your sack handle 3.8g's x 40 pounds
or 152 pounds? If not, you should seriously consider reinforcing it,
because your elevator pushrod is right below it, and a bent pushrod
might ruin your day. (Not to mention running afoul of the flaperon
system.) I suspect you could see well over 3.8g's in the baggage
compartment if you hit just the right kind of bump, I designed mine
for 6g's / 240 pounds. I tested it by jumping up and down on it with
my 195 pounds.
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
Guy Buchanan
I was wondering as well how you gain acess to that area do I need ot
make a trap door in the side.
Mine is accessed from the slope behind and above the seats.
The opening is small, probably 18 x 18, which limits what you can put
in. You certainly won't be putting in any folding bicycles! You can,
however, get camping gear in, as long as it's separated. (You can't
get a full size backpack in.)
I've attached three pictures. One shows the baggage opening
behind the seat. One shows half the baggage opening with the baggage
structure, but no side panels, and one good shot of the baggage
structure without the panels. Unfortunately I don't presently have
any shots with panels, but the panels are honeycomb glass on the
bottom and corrugated plastic on the sides. The baggage structure is
the silver aluminum angles. The white tubes are fuselage structure
and the silver tubes are fuel lines.
Guy Buchanan
San Diego, CA
 Filesize:  48.38 KB
 Viewed:  658 Time(s)
 Filesize:  49.4 KB
 Viewed:  633 Time(s)
 Filesize:  47.63 KB
 Viewed:  677 Time(s)
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
Guy Buchanan
PostPosted: Tue Jan 29, 2008 10:50 pm    Post subject: Cargo area? Reply with quote
At 08:39 PM 1/29/2008, you wrote:
Attached are some pictures of access to the baggagecargo compartment
Steve
"5" 912UL
What an ingenious idea, splitting the turtledeck so you have
hatch access as well as internal access! I wish I'd thought of it,
although I guess it isn't too late to make a new turtledeck.
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
Lynn Matteson
PostPosted: Wed Jan 30, 2008 4:15 am    Post subject: Cargo area? Reply with quote
I forgot all about the 3.8g thing. I did make a stiff bottom for it,
and have from time to time thought about a more rigid "sack", but no
plan in mind yet. Guess I'd better get to thinkin'.
Lynn Matteson
flying w/460+ hrs
it, because your elevator pushrod is right below it, and a bent
pushrod might ruin your day. (Not to mention running afoul of the
flaperon system.) I suspect you could see well over 3.8g's in the
baggage compartment if you hit just the right kind of bump, I
designed mine for 6g's / 240 pounds. I tested it by jumping up and
down on it with my 195 pounds.
Guy Buchanan
San Diego, CA
Lynn
N369LM
dave
PostPosted: Wed Jan 30, 2008 4:23 am    Post subject: Re: Cargo area? Reply with quote
I would like to make mine more like Guy's but with both inside and out side access.
Lynn Matteson
PostPosted: Wed Jan 30, 2008 6:56 am    Post subject: Cargo area? Reply with quote
Same here Dave...making an aluminum box, that is.
Lynn Matteson
flying w/460+ hrs
Rotax Dealer, Ontario Canada
Flying Videos and Kitfox Info
http://www.cfisher.com/
http://forums.matronics.com/viewtopic.php?p=161289#161289
Lynn
N369LM
Float Flyr
PostPosted: Fri Feb 01, 2008 5:21 am    Post subject: Cargo area? Reply with quote
I have a small cargo compartment in my plane, no interior access but a small
door behind the pilot door. It is a great place to put emergency gear,
fishing tackle or fly dope. The down side is the rear wall of the
compartment is not removable so installing an external antenna on the tab
designed for it is out of the question at this time. I might be able to get
back there under the compartment if I removed the seats and disconnected
some of the flight controls. I suppose I could cut another access panel
behind the compartment on the left side of the plane but I don't want the
plane to start looking like a Swiss Army Knife.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
