Tim Olson
Posted: Wed Nov 21, 2007 12:10 pm Post subject: RV-10 Door Incidents |
Sorry to not post just all good cheer before a holiday, but
a safety message well received should be cheery, right?
A former RV-10 owner saw the write up I did from early this
week and that prompted him to call me today. He's a
professional pilot, with many many thousand hours of experience,
and is a CFI (and more). He said he hadn't posted anything
previously because it is indeed embarrassing to tell a story
of poor preparation...things like missing something on a
checklist and then having an incident. But reading the
write up he felt compelled to share his story. He's not
involved in our online community any more, but asked me
if I'd mind telling it for him. (And no, to make sure this
isn't mis-attributed, it was not the famous red/white
plane of Vic's)
The basic story is simple. A passenger was along, and as
they taxied along, they were less "sterile cockpit" than
what you may prefer. This caused them to overlook the
checklist item of verifying the doors closed and latched.
They got their VFR takeoff clearance, and as they rotated,
the door came up. His headset was twisted sideways, as
your body's edge is a little in the air stream when this
happen, so he quickly moved to put his headset back on,
and as he looked up at the door, it departed the aircraft.
With 8000' of runway, there was room to do a gentle
landing, and taxi back to grab the door. The issue is,
he said it was an extremely rattling event...much like
an "explosion" to use his words, when that door opened.
He believed that it was startling enough that some day,
a door opening event would cause a bad accident....not
because the plane flew poorly (he said it flew just
great without the door), but because the pilot will
be too startled and may react inappropriately.
Now, although not much has been written on forums about
RV-10's and doors, it's pretty well known to some that
there have indeed been a handful of RV-10 door incidents
where the door was either torn off or nearly torn off,
due to improper latching. I'm not sure how many...probably
under 10, but over 5. This is just a guess, but I'd
have to say that I believe this is about the only mechanical
type issue we've seen that has caused damage to a plane.
So, it's something to absolutely take seriously with your
checklist. Does the RV-10 need a door redesign? Well,
it would be a lie to say you couldn't design a better door
system, but, it is what it is. In reality, although
the doors have this potential, if the pilot is diligent
you'll very likely never see an incident, and this pilot
knows that. He knew he screwed up. Van's also knew their
design wasn't perhaps as ideal as a Cirrus, for instance,
but it is a simple design that a homebuilder can handle
easily. Van's has known this for a long time, and they
came out with their door latch warning system just to
combat this problem with inattentive pilots. It monitors
the door pins and there are lights and a buzzer to let
you know if the pins aren't secured properly. Given
that addition, there's no reason you should have to
have as much worry. This pilot did not have that system
installed because he felt he may become too reliant on
the sensing hardware, rather than a good checklist
procedure....and hardware fails too. Well, as is easy
to guess...pilots probably fail more often than hardware
does, and that's what happened here. It's something
that could happen to any of us.
I write this all here as a reminder from him to pay
attention to this item very closely in your piloting.
It is the one known issue that you really have to
watch for. But once those doors are latched and the
roll pin is seated tightly in the latch mechanism,
it is also true that there is no reason you should
have a door come off, so you should not be overly
alarmed at the mere potential.
Please, as you flying RV-10 owners take to the skies both
this Holiday season and beyond, check the doors, and
instill it in your families to all participate in the
door pin check. Install the latch warning system and
use it. Admittedly, since the system came out after I
was flying I have not yet installed my kit, but this is
quickly helping me to move it higher on the to-do list,
and I need to be extra cautious. Also, thanks to our
former RV-10 pal who was willing to share his story
and a learning experience with you all.
Happy Thanksgiving!
rtitsworth
Posted: Thu Nov 22, 2007 12:43 am Post subject: RV-10 Door Incidents |
Tim, etal
I'm a Lancair builder, but lurk here because of all the good experimental
dialog, much of which still applies regardless of the airframe. For those
RV'ers taking your door message to heart, we Lancair builder/flyers share
the same door importance/fate. FYI, attached are a few personal photos of a
Lancair Columbia that had a door open in flight near Indianapolis.
The slipstream "tore" the left (pilot) door off, after it became unlatched
in-flight. The door then struck the top of the right wing - yes, up over
the top of the aircraft and down into the wing while in-flight. The damage
to the wing skin was significant, into the core, much more than cosmetic,
but not catastrophic. Note: that area is the fuel tank on a Lancair. The
door then, struck the right Hstab. I'd guess it would be hard to do that
much damage with a good full sledge hammer blow (significant). As a result
of that impact, the fuselage was cracked under the tail. The longitudinal
crack is at the fuselage 1/2 mold joining line (joggle). The
circumferential crack(s) are through the outer skin, core, and inner skin.
The entire tail was loose/wobbly to the touch. From seeing it myself, I
can't imaging the tail would have stayed on too much longer or in a stiff
crosswind landing. The pilot was able to declare an emergency and land, but
was "very" lucky. Also keep in mind this was a Columbia which is certified
in the utility class and VNE of 235 kts - quite strong - perhaps even more
so than either our RV or ES birds.
Now a door latch annunciator (and checklist) believer,
Rick Titsworth
Lancair ES, part of the fixed gear fraternity
1000+ hrs, Mutli, Com, IFR, land & sea
p.s. Tim, I'd love to read your N289DT post, but do not have an RV#.
178.69 KB |
793 Time(s) |
181.43 KB |
803 Time(s) |
171.28 KB |
766 Time(s) |
171.67 KB |
785 Time(s) |
msausen
Joined: 25 Oct 2007 Posts: 559 Location: Appleton, WI USA
Posted: Thu Nov 22, 2007 8:43 am Post subject: RV-10 Door Incidents |
Rick,
Thanks for sharing this, it is indeed valuable information and shows the potential damage our gull wing doors can cause from a sudden departure in flight. I have/am considering a strap that limits the doors opening to 6 inches or so for a combination of safety, ability to leave the door "cracked" in hot climates while on the ground, and as a strap to grab to shut the door. I'll probably do some experimenting once I get the doors installed.
I think it's great that our list is considered not only civil enough, but also informative enough to attract pilots and builders from other aircraft ranks. Thanks for contributing to our greater knowledge!
Michael Sausen
wcurtis(at)nerv10.com Guest
Posted: Thu Nov 22, 2007 9:24 am Post subject: RV-10 Door Incidents |
I always suspected this is why Cirrus hinged their doors forward rather than at the top as a classic gull wing. Hinged at the front an adjar door will tend to be pushed closed by the slipstream, rather than get ripped off by it.
William
http://wcurtis.nerv10.com/
robin1(at)mrmoisture.com Guest
Posted: Thu Nov 22, 2007 10:26 am Post subject: RV-10 Door Incidents |
| Quote: | >I always suspected this is why Cirrus hinged their doors forward
get ripped off by it."
Yes and no. I have a D-35 Bonanza that had a difficult latching
mechanism (doors hinges forward as we all know). Heck it's a 1952 plane
designed in the 40's. Between the latch mechanism and the goofy door
handle the only door on the plane looked closed but on two (2) occasions
the door unlatched in flight. Both times the door unlatched on takeoff.
Because the door hinges in the front there was no concern of the door
ripping off but there was NO possibility of closing the door in flight
either. The slipstream pulled the door open. I know, I was in the PAX
seat. Great idea to include "Seatbelts Secure" in the checklist! It took
all my strength to hold the door in MOST OF THE WAY while we went around
and landed. If I released the tension the door would open a bit more but
not much more. So I was fighting to hold the door 2-3" closed vs. where
it would have naturally been had I applied very little pressure to the
door handle. Also note holding the door like that is very awkward with
little leverage. After the second time the door popped we completely
removed & serviced the door and replaced the door latching mechanism.
All good after that.
On my Turbo Lance II (AKA Land Lance) our rear baggage door once was not
fully closed. Again a misaligned mechanism. The misalignment was minimal
but about 8 minutes after takeoff we heard a buzzing sound. The sound
was the battery style home CO sensor I had placed in the plane. We could
hear it over the engine/Comm sounds. I was on a short flight (14
minutes) with a couple of friends to attend a BBQ so I nosed down,
throttled back and coasted into PRB. Again we completely removed &
serviced the door and replaced all the door latching mechanism. As most
know the Turbo Lance II is a long plane with the exhaust on the right
side and the baggage door on the rear left side. One might think that
the CO might dissipate in the slipstream but there was enough to set off
my detector. Truly a silent killer. My -10 will include a remote CO
detector that will alarm on the G900X.
Photos of both planes attached.
Robin
142.22 KB |
703 Time(s) |
84.06 KB |
742 Time(s) |
rtitsworth
Posted: Thu Nov 22, 2007 10:28 am Post subject: RV-10 Door Incidents |
Some ES guys have built such a strap. One thought/caution is to build it
strong. My understanding (second hand), is that the Columbia pilot had the
strap in hand at the time of his door incident, and the strap was tore out
of the door (unconfirmed). The simple math might be something like 0.05 psi
differential (conservative est) times the size of the door (~1,000 sqin) =
50 lbs. The actual force could be much more (> couple hundred lbs??).
Tim Olson
Posted: Thu Nov 22, 2007 11:04 am Post subject: RV-10 Door Incidents |
That's what I was thinking too...unless the strap kept it from opening
more than 1 inch or so, and the strap was extremely tough AND pulled the
door in a forward direction, I don't think there's much you could do
to keep the door on. The force would just be too great. The thing
is, if that pin isn't in the proper place on the rear of the door,
it's going to torque and twist backwards and rip the hinges anyway.
I think, but am not positive, we've already seen hinges ripped in half,
so that will give an indication of the force. The only real worthy
protection I believe will be making sure the pins are both latched
fully. Once you have that, I think it would take a real breakage
to have a problem.
scottmschmidt(at)yahoo.co Guest
Posted: Thu Nov 22, 2007 1:11 pm Post subject: RV-10 Door Incidents |
Does anyone know of a door coming off that was sure it was latched on takeoff?
The system that Vans has developed works great. It is very sensitive and my light on my dash is off only when the latches are locked. My only concern would be fatigue on the doors where they attach to the hinges on the top.
Scott Schmidt
scottmschmidt(at)yahoo.com
to have a problem.
Posted: Thu Nov 22, 2007 1:33 pm Post subject: RV-10 Door Incidents |
Just make sure the lock pin is fully in place on the inner tube that
connects to the button on the door latch. If it is not, and your knee
or something hits the handle a little, it can come open. Once it
starts, the pressure on the door makes it want to continue going open
until it releases. Fortunately, when that happened to me I was able
to grab the door and close it (it wasn't too hard to close, but
without a handle on the back of the door as in the attached picture it
would have been impossible) before any damage was done to it. I would
say the first thing to do if that happens would be to get off the
power (unless you are on takeoff, maybe) and slow down. I know of two
cases where the door came open and didn't come off, one of which was
on takeoff and one of the hinges broke. Even with the hinge broken,
the pins held the door closed during flight.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
on takeoff?
hinges on the top.
Scott Schmidt
the
half,
to have a problem.
build it
had the
tore out
0.05 psi
sqin) =
321.98 KB |
728 Time(s) |
kearney(at)shaw.ca Guest
Posted: Thu Nov 22, 2007 8:30 pm Post subject: RV-10 Door Incidents |
Hmmm
This discussion of inadvertent door openings in flight is quite interesting.
In my PA28, I have had the door pop open a couple or four times (usually
because I didn't latch it properly and once because an examiner leaned on
the handle when I was doing an instrument ride.
IN a PA28, this is a pretty benign event, the door only opens a few inches
and then stays put. It is closable in flight - a technique I have mastered.
It is the forward hinges on a PA28 that make this a non event.
I was wondering if a latch on the forward edge of the door, engaged when the
door is locked would give the same sort of protection to the -10 gull wing
doors. I must admit the thought of shedding a door at 10k because a
passenger accidentally operated the door mechanism is not a pleasant one. It
would seem that the key to keeping the door in place would be to prevent the
forward edge entering the slipstream and being strippedd away from the
fuselage.
Alternatively, is there a simple way to prevent the door mechanism from
being accidentally operated while in flight?
Inquiring minds need to know.
Les Kearney
#40643 - still singing the section 29 blues
Tim Olson
Posted: Thu Nov 22, 2007 9:13 pm Post subject: RV-10 Door Incidents |
IF....IF you ensure that the roll pin in the mechanism fits into
the slot, then there is no issue at all. The lock mechanism
is very secure on the standard kit. It's kind of like the
Air Force Symbol....a circle with a bar through it. When the
roll pin of the thing is rotated so it drops into that
slot, it is actually tough to get it to release. On my doors,
I have to tell the passenger that they may have to push down
slightly on the door lever while pushing the thumb button or
the rotational pressure will not let it release. It would be
almost impossible to release it in flight without doing
something pretty abnormal. So, it really isn't something to
get all worked up a bit. Unless someone wants to redesign
their doors with forward hinges, just resign yourself to the
fact that you'll definitely want to make sure they're latched
and use the warning mechanism.
Also, as a sideline comment, I'm not sure but I believe one of
the flush latch mechanisms was lacking the ability to have a
detent for it to lock into like that, which is the reason
some have stated for NOT using at least that particular
3rd party latch set. It may be that things can be improved
somehow, but if you're going that route it's just something
that you may want to watch for.
Les Kearney wrote:
Hmmm
fuselage.
Les Kearney
bcondrey
Posted: Fri Nov 23, 2007 5:10 am Post subject: Re: RV-10 Door Incidents |
Just for the record the flush exterior handles from Steve DiNieri (http://iflyrv10.com/) don't change the stock latching/locking mechanism. I have also heard of one that completely disables the lock part but this isn't it.
No affiliation, just clarifying.
Bob #40105
Tim Olson
Posted: Fri Nov 23, 2007 7:47 am Post subject: RV-10 Door Incidents |
The following was written by Russ Daves, who is diligently monitoring
the list from his daughter's house, but can't reply using that PC.
He asked if I could forward this to you all. The reply is in multiple
sections, so read them all...the're all great. The latches he was
referring to were the ones I thought I had heard were not locking
in positioning...not the ones Bob mentioned.
<in response to>
<Russ Daves writes...>
The Cross Aviation recessed door handles on N710RV DO NOT have a locking
indent. I installed a strap below the front part of the inside handle
an it slides over the inside handle when closed. I made the strap out
of heavy duty elastic material so that with a significant amount of
pressure the door could be opened from the outside in the event of a
crash/emergency landing. Not as good a design as the Van's indent and
if I had it to do over again I would not use the Cross Aviation recessed
handles.
Russ Daves N710RV
<in response to>
I'll probably
enough, but also
aircraft ranks.
> Michael Sausen
<Russ Daves writes.........>
I have a 12 inch strap installed at the bottom front of my doors that I
can reach up and grab while seated to pull the door closed. It is long
enough to slide the loop strap over my left thumb and I can keep the
door closed within about 3 inches while holding the stick and taxing.
In addition, after I land and my speed is down to about 40 mph I can
slide the strap over my left thumb and open the door and let in a
significant amount of fresh air while taxing to the hanger. See
comments below related to the door opening in flight about the
practaclity of the strap to hold the door closed during flight.
Russ Daves N-710RV
< In response to....>
pulled the
half,
to have a problem.
<Russ Daves writes>
I have absolutely no doubt that the strap would tear off the door if it
was attached inside the airplane and the door came open in flight. Not
that the strap is a bad idea, only that it should not be attached inside
the airplane. Read below for more reasons.
Last fall I posted to both the Matronics and the VAFWWW web sites my
first hand experience with a door opening in flight. When it happened
in August 2006 right after my 40 hour flyoff had been completed I was
initially ashamed of my stupidity and waited a few months to make the
post to get over it and let other builders know of the pitfall of not
having a physical check of all four locking pins as part of the takeoff
checklist.
It was my first flight with a passenger (my wife) after the flyoff hours
and on takeoff, maybe 500 feet in the air, at about 100 knots the
pilot's door opened, all the way. Naturally I first flew the airplane.
You cannot believe how loud it was in the airplane. I reduced power
as much as possible, did a flat right turn slip of the airplane and
reached up with my left hand and grabbed the 12 inch loop strap, as the
flat slip turn reduced the pressure on the door, and pulled the door
back down to within 6 inches of closing. I continued the flat slop turn
back to downwind while announcing to the tower I was declaring an
emergency and returning to 17R for a landing. I could not make out the
tower's response because of the noise but continued to make the approach
downwind. on short final I could see an airplane still on the runway
from rolling out and did a 360 turn back around to final while again
telling the tower I could not hear them but was declaring an emergency
landing on 17R.
After landing I discovered that the rear door hinge had torn completely
loose from the fiberglass, the strut was broken, and the front hinge was
still attached but bent and had to be replaced.
I ordered a new front hinge set and a new strut. Epoxy Floxxed the rear
fiberglass where the hinge had torn completely off the cabin top and
repaired the door fiberglass where the hinge had partially tore out of
the door. In 3 days when the new hinge and strut arrived I installed
and was back in the air.
However I added to my takeoff checklist to physically check, by feel,
that all four door hinges were properly seated in the slots. Like Tim
my -10 had been completed before Van's shipped me the new door magnetic
pin system with a light on the panel so I did not have it installed at
the time of the incident. I have chosen to NOT install the light check
system since it would not change my takeoff checklist of physically
feeling that the pins are seated.
I now exactly what happened to cause the door to open. The back pin
slide outside the door frame instead of into the slot and on take off
the door torqued enough to allow the front pin to slide out. In my
opinion it will happen every time if both pins are not seated.
When the door was fully open, as I was continuing to fly the airplane, I
could just barely see the door strap out of the corner of my left eye,
otherwise I would probably have assumed the door had left the airplane.
What I found strange was that in over 30 flights during the flyoff hours
the door pins seated ever time, even though I had not been physically
checking the pins. I think the fact that it was the first passenger
flight and I was so concerned with the passenger door and getting my
wife comfortable for the first flight that I just blew it when I closed
the door. However it was a lesson which a couple of months after the
incident that I no longer regretted that it happened. Hopefully it has
made me and lots of other RV-10 builders more aware of a real danger
that has to be checked and is just as important as any of the other
items on the takeoff checklist.
Russ Daves N-710RV
bcondrey wrote:
Bob #40105
http://forums.matronics.com/viewtopic.php?p=148045#148045
Posted: Fri Nov 23, 2007 9:22 am Post subject: RV-10 Door Incidents |
As a person who loves to redesign things and spend too much time and too much money doing so, I have to say that I actually like the door latch mechanism. I originally had thought that i'd definitely replace it, or do something else cooler. when I got there, I built it per the plans, and I got kind of a kick out of how functional they really were. as tim said there's a positive latch that requires you to mean to open it, or it doesn't open. I didn't really understand how the door latch was supposed to work when I was putting it together, but as I got further into building them, and the confusion waned, I was a little impressed with the engineering of it. After it was complete, I made a few adjustments to make the latch action smoother, but that was it. the interior door handle is a bit ugly for sure, but I decided that I don't care for now. Something that I get a kick out of is when simple stuff just works. I will say that by far the best improvement that you could do on the door latch system is use the Rivethead door guides. I know, I know, lead time, slow shipping, whatever. All of this door departing in flight conversation has me really happy that I made that one change. The door opens and closes smoothly, and you really can't get it to a place where you think it's latched and it isn't. Of course now having said that, somehow my door will depart in flight anyway!
relevant links:
http://www.perfectlygoodairplane.net/Perfectlygoodairplane/Door_Handles.html
http://www.perfectlygoodairplane.net/Perfectlygoodairplane/Rivethead_Door_Guides.html
http://www.perfectlygoodairplane.net/Perfectlygoodairplane/Rivethead_Door_Handles.html
cj
#40410
Posted: Fri Nov 23, 2007 10:31 am Post subject: RV-10 Door Incidents |
Out of all the participants on the list you are probably the most
qualified to deal with a door coming off in flight. What's another jump
for you? Ohhhh sorry about that passengers!
I wonder if there is a way to design a thumb turn that engages the door
lock from the inside for the flush mount handles?
Robin
