Don G
Joined: 10 Jan 2006 Posts: 156 Location: Central Illinois
Posted: Wed Jun 06, 2007 5:20 pm Post subject: need Elevator travel limits for speedster mk4 |
Gents,
I am re-assembling N85KF after transport and I am concerned about elevator rigging. As I have no builders manual I need the Elevator travel limits for a Model IV speedster...80 hp
I see that there were a series of spacers/washers on each of the 2 bolts where the horizontal mounts under the vertical stab. The count on these seems to move the horizontal aft..increasing clearance on the bellcrank and elevator stop. thereby increaseing down travel as the horizontal goes aft.
IS this typically the method of adjusting the elevator travel?
What does or did SkyStar call for?
ANd while we are taking rigging, I will need the flaperon limits also I guess when I get the wings on!
Thx Gents!
_________________ Don G.
Central Illinois
Kitfox IV Speedster
Luscombe 8A
RV9A |
kitfoxmike
Posted: Wed Jun 06, 2007 5:48 pm Post subject: Re: need Elevator travel limits for speedster mk4 |
Elevator travel limits, is that for when you have down stick it hits something to keep the stick from going close to the floor. Well if that is what you are talking about I took my limit out. Now the stick goes way forward, this allows me to get in the airplane better. But you need to have a limit somewhere or the bushing on the floor that holds the control assy. will break. What I did was glue a piece of wood on the right side of the cabin to stop the control assy from binding and breaking the nylon bushings. Don't ask my how I know you will break the bushing.
Tom Jones
Posted: Wed Jun 06, 2007 7:00 pm Post subject: Re: need Elevator travel limits for speedster mk4 |
| Quote: | | I need the Elevator travel limits for a Model IV speedster...80 hp |
Don,
The washers have nothing to do with elevator adjustment. The builder must have needed to put them in as spacers to be able to tighten the mounting bolts without bending the horizontal stab assembly. I have one washer as a spacer on the rear bolt to make a snug fit on my Classic 4.
If you did not loosen the check nuts and did not turn the rod ends on any of the control rods when you dissassembled the plane, you should be able to put everything back together without making any adjustments. Assuming it was correct to begin with.
If you need to adjust the elevator limits: For up elevator limit, adjust the rod ends in the elevator tube assembly so that the rear rod end contacts the tail post at the same time the stick contacts the seat. Should be 30 to 35 degrees compared to the horizontal stab. You will have plenty of down elevator. The down elevator stop is a small tube welded across the fuselage a couple inches ahead of the tail post. No adjustment on that.
Rigging the flaperons requires you build some jigs. You really are going to need a manual. Did the builder not have one to go with the plane?
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Don G
Posted: Wed Jun 06, 2007 7:48 pm Post subject: Re: need Elevator travel limits for speedster mk4 |
Tom,
I did not get a builders manual with the plane. Only engine manuals
I bought it from the 3rd owner.
I Understand the config you describe that your horizontal is in.
I remember when I disassembled the tail...several washers being in place, probably 5 thick ones. I would guess 3/8 of an inch worth.
I thought at the time it was just a builders mistake. Now, upon re-assembly, I see that with one washer at the rear fitting..it will fit fine and the front fitting will be flush not needing any spacer/washers.
As I was contemplateing the washers that were there before, I see that the effect of these could only be to move the horizontal aft. When wondering why that would be needed, it occoured to me that possibly the lower limit of the elevator was not enough, and this was the fix the builder chose as moving the horizontal increases the clearance between the cross tube stop and the elevator crank.
I did not measure it as I did not have a protractor at the hangar tonite, but by eye, the upper travel is more than the lower with one washer in place. Hence, my question about the needed travel limits.
(I guess I am kinda sensitive about this being a Luscombe owner, and reduced up elevator limits are one of the few AD's on it.)
tomorrow I will have a protractor and see if it is 30 to 35 degrees.
Do you know what the down angle should be? IN case something is screwed up here?
AS to those ailerons..yes, I can understand why a jig might be needed to measure them, considering their shape and distance from the trailing edge.
no control rod ends have been changed, but I still would like to have the peace of mind in knowing they are correct.
Central Illinois
Kitfox IV Speedster
Luscombe 8A
RV9A |
Guy Buchanan
Posted: Thu Jun 07, 2007 6:50 am Post subject: need Elevator travel limits for speedster mk4 |
At 06:20 PM 6/6/2007, you wrote:
| Quote: | I see that there were a series of spacers/washers on each of the 2
No. You should put the minimum number of washers in each location.
Otherwise the bolt shear induced by air loads will tend to bend the
brackets. You should put washers in either location so they both
bottom at the same time. (I.e. you don't tend to bend either one when
you tighten the bolts.)
I had 30+ up and 20 down on my elevator. The aileron rigging is more
complex. I have attached a page from the manual rendered barely
legible by the reduction process. Let me know if you need a larger
view and I'll send it direct. Note there's no measurement for the
flaperon. It's installed horizontal with the wing true chord, (LE to
TE,) horizontal, measured at the flaperon mid-span. I've set my flap
system so I can reflex the flaperon up a little, though I've not been
able to discern any speed difference doing so.
Guy Buchanan
San Diego, CA
92.89 KB |
705 Time(s) |
Deceased K-IV 1200
A glider pilot too. |
kitfoxmike
Posted: Thu Jun 07, 2007 7:42 am Post subject: Re: need Elevator travel limits for speedster mk4 |
The small tube that is in the back to limit the down movement is the piece I removed, like I said, real nice now that the stick goes all the way forward(can get in and out of the airplane), you just need to make a stop on the floor that keeps the control assy from binding and breaking the nylon block.
lcfitt(at)sbcglobal.net Guest
Posted: Thu Jun 07, 2007 10:29 am Post subject: need Elevator travel limits for speedster mk4 |
When I was building, a friend had built a couple of Kitfoxes - early
models - told me I had to put a metal strap over the plastic block between
the bolts for strength. I did, but doubted the need. I doubt no longer.
Lowell Fitt
Cameron Park, CA
Model IV-1200 R-912 UL Warp
1998 870 hrs.
kitfoxmike
Posted: Thu Jun 07, 2007 11:34 am Post subject: Re: need Elevator travel limits for speedster mk4 |
I'm trying to remember the exact spot the block broke on me, but if you remove the stop in the back, which was a great idea, you end up with the control assy hitting the floor and putting undue pressure on the nylon blocks and they will break, seems to me mine broke in half and it could have been along the top, might of been on the bottom along the floor. Easy fix was to put in a piece of left over wood from the wings, from between the ribs and hysol to the floor, made it so the clearance from the control assy to the floor when pushed all the way forward was about 1/8 inch then glued the wood piece in place. Now I can push forward on the stick when getting in or out of the plane and not worry about anything breaking.
Renaud
Posted: Thu Jun 07, 2007 1:45 pm Post subject: Re: need Elevator travel limits for speedster mk4 |
Don,
The manual of the Kitfox Classic IV says up +29° down -24° for the elevator.
One mine, the upward travel stopped when the push/pull rod hit the little transverse tube normally used to stop downward travel. (See the attached skecth). I checked with John McBean (Kitfoxaircraft) who confirmed that the upward travel normally stops against the rear vertical.
I built a little part fixed on the lever of the elevator that now hits the rear vertical of the fuselage.
At the end, I have a travel of ~35° up, just what I need for 3 points landing (and I sealed the elevator / stab gap). Downward travel is about 25°, but of course I never had to use it completely.
Maybe this can help.
89.83 KB |
695 Time(s) |
_________________ Renaud
KitFox IV - 1200. Rotax 582. |
