btucke73(at)yahoo.com Guest
Posted: Tue May 02, 2006 4:17 pm Post subject: Paint |
Lynn,
I am using PPG one coat urethane. I just painted
one wing, and will start on the other wing when I
return from All Red Star on Sunday. I am not a very
good painter, but results can be deceiving with this
product. It goes on like silk, and is almost as tough
as powder coat. I'll never shoot acrylic enamel
again. As soon as I get the other wing painted, I
will update my website with fresh pics. I am doing it
very differently from most guys and painting as I
build. For me, it is much easier, and breaks up the
painting task. I painted the underside of the center
wing and aft fuselage before joining them together
(pic on website), and painted the tail, side fuse, top
fuse, cowling, and wings all separately. It could be
prettier, but then it could be a whole lot more
expensive too. I just don't let anyone within 5 feet
of the plane so they can't see the paint defects!
Nothing wet sanding and buffing can't fix, but I'll
save that for after it is flying...
I'll get anyone the part numbers of the paint if
you are having problems finding it, but PPG one coat
urethane should suffice. It is quite expensive, but
worth it. I think I am down $800 for paint, but I
can't remember, and really don't want to know.
R/
Brandon
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
frank.hinde(at)hp.com Guest
Posted: Wed May 03, 2006 6:11 am Post subject: Paint |
What are you using for breathing protection Brandon?
I am assembling parts to make a closed breathing air sysytem as I
understand this is mandatory for urethane paints due to the cyanide.
Frank
Posted: Wed May 03, 2006 9:32 am Post subject: Paint |
Are you thinking of painting the airplane yourself larry?....I'm getting
close on the RV and am debating whether the learning process is a good
investment vs the screw up potential.
Frank
I'm in the process of disassembling the plane and bringing parts home,
so insulation, and the like will be added after the paint process is
finished.
p.mulwitz(at)worldnet.att Guest
Posted: Wed May 03, 2006 11:41 am Post subject: Paint |
Frank,
I did the commercial metal painting thing for a while after I stopped
doing electrical engineering. Let me offer a little wisdom on the
effort of learning to paint metal.
Painting is relatively easy to do poorly. It isn't really hard to
get reasonably good at it if you devote yourself to the
effort. Excellent work takes years to learn. The hard part of spray
painting is not the spraying - it is the preparation of the surface
to paint. This is a lot of very hard work making the surface smooth,
clean, and in the proper condition to grab onto the paint.
The really important thing for you to consider is the incredible
danger involved in painting. The paint is deadly - particularly the
solvents used to keep it liquid until applied to your work
piece. You need to take serious precautions in the handling and
protect your skin and lungs from the toxic chemicals. These problems
are well documented so it is not rocket science to learn proper
safety precautions. If you ignore any of them it may well kill
you. Even worse it could turn you into a drooling idiot who lives a
worthless life for many years.
There are other dangers too - risk of explosion and fire and other
similar things.
I am not trying to talk you out of doing your own painting. I think
it can be done and you can save a lot of money doing it
yourself. You can also get very acceptable results. My point is you
need to devote serious attention to the safety issues and make sure
you are covering all of them.
Good luck,
Paul
XL wings
| Quote: | Are you thinking of painting the airplane yourself larry?....I'm getting
Posted: Wed May 03, 2006 12:16 pm Post subject: Paint |
Thanks Paul,
I agree with you in that the prep work is where the labour hours are...I
am currently finishing all the fiberglass parts on the RV. I have done
this numerous times (on steel) so that part is not difficult for me,
just time intensive.
The safety issue I think I have coverd.
The big question for me is...I know a guy who is an excellent painter
and I'm wondering if on a hideously expensive airplane like the RV is
this the place I should be learning or should I simply spend a grand or
so having my friend shoot the paint. He gave me some pointers on the
parts I had to paint before fitting the bubble canopy etc and they came
out OK...There is definatly some do's and don't when using a spray gun
vs a rattle can.
I have a '97 white Dodge neon and the paint is peeling off that...That
would be a far cheaper place to screw a paint job up on... , but ti
would also be a great skill to have...
Frank
Painting is relatively easy to do poorly. It isn't really hard to get
reasonably good at it if you devote yourself to the effort. Excellent
work takes years to learn. The hard part of spray painting is not the
spraying - it is the preparation of the surface to paint. This is a lot
of very hard work making the surface smooth, clean, and in the proper
Posted: Wed May 03, 2006 2:17 pm Post subject: Paint |
Frank,
Yes, I'm painting the plane with Aircraft Finishing Systems product.
They have a good instruction manual for applying
the single coat primer/sealer and 2-part topcoats. The paint is a water
thinned polyurethane and catalyst mix that is safe to
spray with an organic charcoal filter like the 6001 3M product. No
odor, HPLV gun per Harbor Freight and water cleanup.
It meets the EPA requirements and with water in lieu of a VOC thinner,
the isocyanate component doesn't go after you because
it neutralizes the dangerous side of polyurethane. I've painted before,
but this is a first in water and polyurethane paints.
My cost is going to be about $1500 including the paint booth versus
$3500 to $5000 for hiring it done.
Larry McFarland at www.macsmachine.com
Hinde, Frank George (Corvallis) wrote:
Frank
finished.
webmaster(at)upac.ca Guest
Frank, there is a very good article on painting aircraft here:
http://www.ch601.org/resources/prep/surface_prep.htm
I studied this and researched a lot on the internet. Prep work is
essential as is the proper equipment. If you can rent or borrow an
HVLP turbine system is will make things a lot easier. Over-spray is
greatly reduced. Protect yourself with a good respirator and a forced
breathing system and if you can, paint it in a proper paint booth.
I did mine in my garage with filters and moistened the floor to keep
the dust down. Paint turned out pretty good. Not a super expensive
pro job but I get compliments so I'm satisfied. You can do it if
you're prepared to make the effort. Just take your time.
Oh, the paint I used was the Endura EX-2C system. Fairly affordable
and easy to work with. It's polyurethane. www.endura.ca
Lot of pictures of the painting process and final result at http://
pagefamily.homeunix.org/gallery/
Trev Page
C-IDUS 601HD R912
On May 3, 2006, at 1:29 PM, Hinde, Frank George (Corvallis) wrote:
(Corvallis)" <frank.hinde(at)hp.com>
getting
Frank
finished.
archermj(at)swbell.net Guest
Posted: Wed May 03, 2006 6:45 pm Post subject: Paint |
I am also planning on using AFS on the exterior. I did some trial painting
of the interior. It was tricky at first. The support from the AFS is
great. I finally got the hang of it and I was really happy with the
results. The trick it to get it thinned properly and getting the "mist"
proper. After the first coat or so gradually increase the volume so it
flows. I also tried to do it at about 55 degrees and it worked but it
turned to much better when it warmed up. It is nice to work with, easy to
clean up and very safe. I was glad I tried it before I tackle the exterior.
Cheers
Matt
www.zodiacxl.com
steveadams
Posted: Thu May 04, 2006 3:52 am Post subject: Re: Paint |
I also used the AFS paints, mainly for the safety issues, it's not flammable, and it's easy to clean up.
209.45 KB |
480 Time(s) |
Posted: Sun May 07, 2006 7:04 am Post subject: Paint |
Frank,
If you're still contemplating doing your paint job, I have to recommend
you contact Stewart's Hangar 21.
AFS was purchased by Stewart's Hangar 21 and they're making changes to
the website that has
all the information, but they still can be reached at 1-509-679-3021.
Ask for the AFS color chart
pricing and application guide as that's the most easily understood item
that was offered by AFS.
Nice people.
Also there are some good articles worth reading on the web about RVs
being painted with the AFS.
I had to print a few and keep referring to them for detail questions etc.
http://www.karmy.com/rv9a/reference/Primer%20Wars.htm
http://www.karmy.com/rv9a/pictures/Paint/AFS-Painting/afs-paint.htm
Have a good one,
Larry McFarland
Frank
finished.
naumuk(at)alltel.net Guest
Posted: Sun May 07, 2006 7:56 am Post subject: Paint |
Larry-
What did you wind up doing re: paint booth (Or aren't you to that stage
yet)? Being familiar with your work, I picture a filtered, temperature and
humidity controlled environment that doubles as a "Safe Room" in hayfever
season.
I think you know me well enough to accept that as a compliment rather
than criticism!!
Hello Larry,
Yes I am still deabating that as I spend hours and hours sanding
fiberglass...
The only question I have with the AFS (that's the water based stuff
correct?) is the durability and cost. I think I have the componentry to
make a fresh air breathing system (or I can buy a Hobby air for $400),
so the cost delta is one issue.
The durability is particularly relevant on the RV with a tip up
canopy...The roll bar I painted with refinsihing paint (non cyanide) and
where the flexiglass rubs against the roll bar it rubbed it right
off...So it has to be a tough paint, which I know the Eurethanes are,
but not sure about the AFS.
I'll have a look at it though, it could be a good solution.
I'm still debating spraying the non cyanide primer and having my expert
friend come over to spray the finish coats as that should be a pretty
small investment...But I'd also love to be able to spray paint too...
Choices, choices...
Thanks for yur thoughts Larry
Frank
Posted: Sun May 07, 2006 9:14 am Post subject: Paint |
Frank,
One way to toughen up any paint is to apply a clear urethane
overcoat. You need to check compatibility, but this sort of approach
may be possible.
Paul
XL wings
| Quote: | So it has to be a tough paint, which I know the Eurethanes are,
Posted: Sun May 07, 2006 11:21 am Post subject: Paint |
Bill,
See my Paint page on the website menu for a detailed description of a
paint booth with pictures.
Right, filtered and enclosed as to fit my home garage with plane inside.
One solution anyway,
Larry
Bill Naumuk wrote:
Larry-
season.
than criticism!!
Posted: Sun May 07, 2006 11:43 am Post subject: Paint |
Larry-
Wilco. Stored your link in my "Keepers" folder.
Almost ready to fit the strut tubes to the wing (Yuk-not looking forward
to it). Contractor is going to start the rough framing on the garanger
tomorrow- looks like I'll be moving soon. Think I'll just frame a 1'
extension on my existing "Floating" 4x8 table w/3/4" ply top, put casters on
it, then slap your coated fiberboard on top.Gonna put casters on one of my
other workbenches and take it upstairs, leaving the other for Ma to use as a
laundry table.
