What did you use to mount B&C's LR3C controller
MauleDriver(at)nc.rr.com
PostPosted: Sun Sep 21, 2008 2:10 pm    Post subject: What did you use to mount B&C's LR3C controller Reply with quote
I'm getting ready to mount 2 of these in an RV10 - There are (6) 9/32"
holes in them for mounting and I just can't figure out what hardware
should be used. Or what was intended.
Bill Watson
n223rv(at)wolflakeairport
PostPosted: Sun Sep 21, 2008 3:54 pm    Post subject: What did you use to mount B&C's LR3C controller Reply with quote
I used 4 AN3 bolts with nut plates.
partner14
PostPosted: Sun Sep 21, 2008 6:20 pm    Post subject: What did you use to mount B&C's LR3C controller Reply with quote
I made this bracket to support both lr3C's and a dimmer in the middle. Kind of hard to picture where this is, but the pic is the upper forward instr panel, flipped over.
Don
--- On Sun, 9/21/08, MauleDriver <MauleDriver(at)nc.rr.com> wrote:
Subject: What did you use to mount B&C's LR3C controller
Date: Sunday, September 21, 2008, 3:09 PM
--> RV10-List message posted by: MauleDriver <MauleDriver(at)nc.rr.com>
Bill Watson
 Filesize:  122.14 KB
 Viewed:  355 Time(s)
Don A. McDonald
40636
ricksked(at)embarqmail.co
PostPosted: Sun Sep 21, 2008 6:45 pm    Post subject: What did you use to mount B&C's LR3C controller Reply with quote
OMG!!! That picture is HUGE!!! AGGGHHH...it's taking over my computer....sorry...couldn't resist. Smile do not archive
PostPosted: Mon Sep 22, 2008 7:23 am    Post subject: What did you use to mount B&C's LR3C controller Reply with quote
I'll probably use a couple of AN3 bolts too.
I called Bill at B&C and he explained that the 6 large holes are there
to facilitate replacement installations in various other aircraft.
I just wanted to see if I was missing something - I wasn't.
and thanks for the pic Don.
