MauleDriver(at)nc.rr.com Guest
Posted: Sun Sep 21, 2008 2:10 pm Post subject: What did you use to mount B&C's LR3C controller |
I'm getting ready to mount 2 of these in an RV10 - There are (6) 9/32"
holes in them for mounting and I just can't figure out what hardware
should be used. Or what was intended.
Bill Watson
Posted: Sun Sep 21, 2008 3:54 pm Post subject: What did you use to mount B&C's LR3C controller |
I used 4 AN3 bolts with nut plates.
partner14
Posted: Sun Sep 21, 2008 6:20 pm Post subject: What did you use to mount B&C's LR3C controller |
I made this bracket to support both lr3C's and a dimmer in the middle. Kind of hard to picture where this is, but the pic is the upper forward instr panel, flipped over.
Don
--- On Sun, 9/21/08, MauleDriver <MauleDriver(at)nc.rr.com> wrote:
| Quote: | From: MauleDriver <MauleDriver(at)nc.rr.com>
Subject: What did you use to mount B&C's LR3C controller
Date: Sunday, September 21, 2008, 3:09 PM
| Quote: | --> RV10-List message posted by: MauleDriver <MauleDriver(at)nc.rr.com>
Bill Watson
122.14 KB |
348 Time(s) |
40636 |
ricksked(at)embarqmail.co Guest
Posted: Mon Sep 22, 2008 7:23 am Post subject: What did you use to mount B&C's LR3C controller |
I'll probably use a couple of AN3 bolts too.
I called Bill at B&C and he explained that the 6 large holes are there
to facilitate replacement installations in various other aircraft.
I just wanted to see if I was missing something - I wasn't.
and thanks for the pic Don.
