Headliner Install
thane
PostPosted: Mon Feb 19, 2007 4:16 pm    Post subject: Headliner Install Reply with quote
Hello to you all. I am new to posting on this site, but I thought I would share something about the headliner install debacle.
I will be using the flight line interior from Abby. As many of you know it is difficult to get a good finished look around the windows.
Here is what I did: After carefully installing my headliner, trimming around edges, and then using a soldering iron to seal the edges. I used "Style Guard" Door trim, for automobiles, purchased from Pep Boys; 25' roll,(Black) I carefully put it around the window edges, using a putty knife to help it over the edge and keep the fabric from pushing out. I then used a heat gun to set the glue and it turned out beautiful. For the tight corners, I applied some heat to the trim to help it bend around. Once you do this, the glue will want to close up the trim, so again I just ran a putty knife between it to help it over the edge.
If anyone would like any further info, I would be happy to share what worked for me. I don't know if anyone else used this technique, but I am very pleased with the result.
Working on finish kit: I hate fiberglass!!
jwt(at)roadmapscoaching.c
PostPosted: Mon Feb 19, 2007 4:41 pm    Post subject: Headliner Install Reply with quote
Can you post some photos?
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Thane States
Sent: Monday, February 19, 2007 7:14 PM
Subject: Re: Headliner Install
-- No virus found in this Edition.
2/18/2007
thane
PostPosted: Mon Feb 19, 2007 6:56 pm    Post subject: Headliner Install Reply with quote
Here are the pictures from my Headliner Installation.
 Filesize:  108.79 KB
 Viewed:  224 Time(s)
 Filesize:  99.24 KB
 Viewed:  214 Time(s)
 Filesize:  95.2 KB
 Viewed:  233 Time(s)
 Filesize:  127.42 KB
 Viewed:  241 Time(s)
flysrv10(at)gmail.com
PostPosted: Tue Feb 20, 2007 4:37 am    Post subject: Headliner Install Reply with quote
Can you provide pictures?
         - The RV10-List Email Forum - class="Apple-converted-space"> --> http://www.matronics.com/Navigator?RV10-List              - NEW MATRONICS WEB FORUMS - class="Apple-converted-space">   --> http://forums.matronics.com
