thane
Posted: Mon Feb 19, 2007 4:16 pm Post subject: Headliner Install |
Hello to you all. I am new to posting on this site, but I thought I would share something about the headliner install debacle.
I will be using the flight line interior from Abby. As many of you know it is difficult to get a good finished look around the windows.
Here is what I did: After carefully installing my headliner, trimming around edges, and then using a soldering iron to seal the edges. I used "Style Guard" Door trim, for automobiles, purchased from Pep Boys; 25' roll,(Black) I carefully put it around the window edges, using a putty knife to help it over the edge and keep the fabric from pushing out. I then used a heat gun to set the glue and it turned out beautiful. For the tight corners, I applied some heat to the trim to help it bend around. Once you do this, the glue will want to close up the trim, so again I just ran a putty knife between it to help it over the edge.
If anyone would like any further info, I would be happy to share what worked for me. I don't know if anyone else used this technique, but I am very pleased with the result.
_________________ Working on finish kit: I hate fiberglass!! |
jwt(at)roadmapscoaching.c Guest
Posted: Mon Feb 19, 2007 4:41 pm Post subject: Headliner Install |
Can you post some photos?
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Thane States
Sent: Monday, February 19, 2007 7:14 PM
Subject: Re: Headliner Install
| -- No virus found in this Edition.
2/18/2007
thane
Posted: Mon Feb 19, 2007 6:56 pm Post subject: Headliner Install |
Here are the pictures from my Headliner Installation.
108.79 KB |
204 Time(s) |
99.24 KB |
195 Time(s) |
95.2 KB |
212 Time(s) |
127.42 KB |
214 Time(s) |
flysrv10(at)gmail.com Guest
Posted: Tue Feb 20, 2007 4:37 am Post subject: Headliner Install |
Can you provide pictures?
On Feb 19, 2007, at 7:14 PM, Thane States wrote:
| Quote: | Hello to you all. I am new to posting on this site, but I thought I would share something about the headliner install debacle.
