william(at)gbta.net Guest
Posted: Wed Feb 01, 2006 9:52 pm Post subject: Batteries |
I studied the archives a bit and found that several of you have installed dual batteries. I cannot find any pictures of how the mods were made. Does anybody have pictures of their battery mods??? I have not decided on which batteries I will use yet. Do I need to know this before I build the tray???
Also, this may not be the right list to post this question, but, to those who are considering the Egg H-6 for your -10, what are your battery thoughts/recommendations/locations???
RV-10 Tailcone
millstees(at)ameritech.ne Guest
Posted: Thu Feb 02, 2006 6:43 am Post subject: Batteries |
I am plannning on the Subaru H-6 for my -10, Eggenfellner recommends two Odyssey 680 batteries. As far as location is concerned, I have not reached that point, however since the H-6 is about 60 lbs lighter than the Lycosaur, it would be best from a weight and balance point of view to locate the batteries under the cowl. You can get additional information at Eggenfellners web site http://www.eggenfellneraircraft.com/
Steve Mills
40486
working on wings
bob.condrey(at)baesystems Guest
Posted: Thu Feb 02, 2006 2:28 pm Post subject: Batteries |
Here’s what I did, batteries are a pair of PC-680s. Not a problem to mod the tray later.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill and Tami Britton
Sent: Wednesday, February 01, 2006 11:48 PM
To: RV10-list(at)matronics.com
Subject: Batteries
RV-10 Tailcone
65.77 KB |
909 Time(s) |
86.55 KB |
926 Time(s) |
97.01 KB |
918 Time(s) |
pdwalter(at)bigpond.net.a Guest
Posted: Fri Feb 03, 2006 12:23 am Post subject: Batteries |
Hi Group,
As I am part way through the VS I have run into the same problem as I have read about previously.
Plans say to remove 1/8 inch from VS 1013, VS 1005 and VS 1006 so as not to crease VS 1001 Vertical stabilizer skin with the point of these mentioned ribs
Now, removing 1/8 has done nothing to solve the problem and at this point I have taken 1/4 inch off and when assembled and you look down through top of stabilizer the ribs do not sit flush in front of skin as I would like. It almost seems like these ribs have not be manufactured correctly.
Can the fronts be re fabricated to change the actual shape of the rib ?.
Thank you
Paul Walter.
