kentk
Joined: 03 Jan 2007 Posts: 25 Location: College Station
Posted: Fri Jan 05, 2007 6:28 pm Post subject: Rear spar attach reinforcement |
OK, this is my first post here on Matronics, so please forgive me if I break some cardinal rule. I tried to make my first part #22003 Rear Spar Attach Reinforcement (for Model 4-1200) and I think I may have shaved off a wee bit too much metal. I will try to attach a picture of the part so that some of you experts can give me some guidance. At this point I am thinking that the part may still be used, but will have to be checked at every pre-flight.
Thanks in advance,
Kent
301.2 KB |
1027 Time(s) |
_________________ Kent Knudsen
College Station, TX
K-IV 1200 / no engine / 25% done |
smokey_bear_40220(at)yaho Guest
Posted: Fri Jan 05, 2007 7:12 pm Post subject: Rear spar attach reinforcement |
Hi Kent,
--- kentk <kentk25(at)yahoo.com> wrote:
| Quote: | OK, this is my first post here on Matronics, so
No problem. Here we have 1 Pope, 2 cardinals and a
whole lot of sinners.
| Quote: | Reinforcement (for Model 4-1200) and I think I may
Thanks in advance,
Kent
Right or wrong on this part will depend upon what you
have left, of course. I think I built 1.3 Kitfox's to
cover the "not quite good enough" parts I remade.
Some are remade just for looks, but if it is critical,
you don't want to be flying wondering if it is good
enough. Make a new one and be sure. To me, the rear
attachment falls into the "make sure" category rather
than the preflight check category.
Let's see what others say.
But go ahead and attach a pic, if nothing else than
for practice, and confirmation from all on what they
would do. We like to discuss stuff here....
Kurt S. S-5
kentk
Posted: Fri Jan 05, 2007 8:33 pm Post subject: Re: Rear spar attach reinforcement |
| smokey_bear_40220(at)yaho wrote: | Hi Kent,
Hah, good one! At least I wasn't accused of making a bad aircraft pun.
I send my question to the Kitfox company, but last time I asked them for info it took something like 2 weeks to get a reply. Does anyone know if I can purchase part #22003 (or have a spare for sale)? If not, I guess will seriously consider those spar inserts from Blueskyaviation.
Thanks again, Kurt for the response and insight.
Kind Regards,
Kent
College Station, TX
roncarolnikko(at)hotmail. Guest
Posted: Fri Jan 05, 2007 8:53 pm Post subject: Rear spar attach reinforcement |
Kent please hit the attach button and show us the part. May or may not be a
problem, but we like to over analyse. Ron NB Ore
| Quote: | From: "kentk" <kentk25(at)yahoo.com>
Subject: Re: Rear spar attach reinforcement
Date: Fri, 5 Jan 2007 20:33:52 -0800
> Hi Kent,
Kind Regards,
Kent
kentk25[at]yahoo
http://forums.matronics.com/viewtopic.php?p=85804#85804
Type your favorite song. Get a customized station. Try MSN Radio powered
by Pandora. http://radio.msn.com/?icid=T002MSN03A07001
kentk
Posted: Fri Jan 05, 2007 9:42 pm Post subject: Re: Rear spar attach reinforcement |
| roncarolnikko(at)hotmail. wrote: | Kent please hit the attach button and show us the part. May or may not be a
Is the image not showing up for anyone but me? If that is the case, here is the link to the photo:
http://forums.matronics.com/download.php?id=3526
Kent
College Station, TX
rexinator(at)gmail.com Guest
kitfox(at)ida.net Guest
Posted: Fri Jan 05, 2007 11:03 pm Post subject: Rear spar attach reinforcement |
Hey Kent
I wish I would have used the inserts. They look like a lot better way to do
it. If not just build some new parts. Spar attach points tend to be
important.
Good luck
Albert
Joined: 24 Oct 2006 Posts: 89 Location: Damascus, Maryland, USA
Posted: Sat Jan 06, 2007 4:58 am Post subject: Re: Rear spar attach reinforcement |
It's an important part, not too hard to remake, and someday there will be a "next" owner who may not know to check this on pre-flight. If your A&P or FAA inspector see an example of workmanship like this, they'll start looking a lot closer, too. Besides, when it does crack, probably at the second hole, do you want to have to try to get it out once assembled? Easier to just re-make it now. Tip for next time: use the file lengthwise along the edges, not across it, and the edge will stay straight.
A&P
_________________ Remember that internet advice may only be worth what you pay. |
lcfitt(at)sbcglobal.net Guest
Posted: Sat Jan 06, 2007 7:29 am Post subject: Rear spar attach reinforcement |
Thanks for the direct link to the image. First congratulations on your
choice of airplane - the best Kitfox ever in my opinion for all the things
Kitfoxes are designed to do.
My suggestion would be to replace the part. A taper on a fitting like that
is designed to spread the forces evenly to the end. By essentially cutting
a notch on this one it creates a stress riser which could result in a
premature failure.
Where are you? Tell us about your project.
Lowell
kentk
Posted: Sat Jan 06, 2007 8:31 am Post subject: Re: Rear spar attach reinforcement |
| lcfitt(at)sbcglobal.net wrote: | Thanks for the direct link to the image. First congratulations on your
premature failure.
Lowell
Well, first of all, thank you everyone for the excellent advice. I really don't want to use any inferior parts on my plane, but was also concerned about availability of replacement parts.
Last year I aquired this KitFox Model 4-1200 from a friend who originally purchased it back in '94. He had worked on the fuselage, but not much else. I live in College Station, TX and have an ASEL Private Pilot License. My flight experience is mostly Cessna 172 and 150s. I have some low wing hours, but prefer the high wing. I have zero tail dragger experience.
So, at this point I am focused on building the wings. The kit did not include the engine nacelle (nor anything FWF for that matter), so I am undecided as to which powerplant to use and which prop arrangement is best. I am very much in the research phase at this point.
Kent
College Station, TX
Joel
Joined: 06 Oct 2006 Posts: 57 Location: Bremerton, WA USA
Posted: Sat Jan 06, 2007 9:16 am Post subject: Rear spar attach reinforcement |
Hi Kent,
I used the BlueSky spar inserts on my model 5 and am very pleased with the
results. I thought that if any one area of the aircraft should be over
designed the spar attach point was it. My aeronautical engineer son agreed.
Joel
Model 5 912uls
Dave vs. Carl: The Insignificant Championship Series. Who will win?
_________________ Joel Mapes Kitfox 5 912 ULS Aerocomp amphibs |
jdmcbean(at)cableone.net Guest
Posted: Sat Jan 06, 2007 9:52 am Post subject: Rear spar attach reinforcement |
Regarding Spar Attach Reinforcement,
Not to say one way is better then another.. but remember that the aircraft
was load tested and flight tested with these reinforcements. The
reinforcements didn't fail and to date there has not been an in-flight
structural failure of a Kitfox..
Fly Safe !!
John & Debra McBean
208.337.5111
www.kitfoxaircraft.com
"It's not how Fast... It's how Fun!"
Lynn Matteson
Posted: Sat Jan 06, 2007 2:09 pm Post subject: Rear spar attach reinforcement |
I also bought a IV from Texas, without engine or cowl. I settled on a
2200 Jabiru engine and Skyfox cowl after doing a lot of engine
research. I'm very well satisfied with the way mine turned out, and
its performance, and ease of operation.
Lynn
Kitfox IV Speedster...Jabiru 2200
On Jan 6, 2007, at 11:31 AM, kentk wrote:
> your
> the things
> like that
> essentially cutting
> premature failure.
> Lowell
point.
Kent
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
kentk
Posted: Sat Jan 06, 2007 6:10 pm Post subject: Re: Rear spar attach reinforcement |
| Lynn Matteson wrote: | I also bought a IV from Texas, without engine or cowl. I settled on a 2200 Jabiru engine and Skyfox cowl after doing a lot of engine research. I'm very well satisfied with the way mine turned out, and its performance, and ease of operation.
Lynn
Lynn,
Do you know if anyone has documented the performance of various engines vs. various prop cominations? It would really be nice to help the homebuilder choose which configuration will most likely suit their aircraft and performance preferences. I suspect that such an animal does not exist, unless the EAA might have something along those lines.
Kent
College Station, TX
Mdkitfox(at)AOL.COM Guest
Posted: Sat Jan 06, 2007 9:18 pm Post subject: Rear spar attach reinforcement |
Kent,
After viewing the picture I would recommend remaking the attach bracket. While the one you made would 'probably' be okay, why take a chance. They're cheap parts and easier to do now rather than later. I used the 'cuff' thinking they would be an improvement, but the original design has never been an issue. I have a model V and probably have the original spar reinforcement pieces, but I recently moved and finding them may take a while. If you want them (and I can find them) they're yours, no charge. Does anyone know if the Series V(1400 lbs version) part is the same as the model IV part?
Rick
Series V Speedster - N39RW
Lynn Matteson
Posted: Sun Jan 07, 2007 3:22 am Post subject: Rear spar attach reinforcement |
Kent-
No, I don't know of any such documentation. When I referred to doing
engine research, I just read a lot about some people having different
problems with some Rotax's, other engines being too heavy, others too
low in horsepower, etc. I liked the looks, simplicity, lightness,
single carb, air-cooling (without additional liquid cooling), etc.,
of the Jabiru, and went that way. It may not be the high performance
choice of the field, but it gets me cruising at or near 100 mph, at
low...3.25-3.5 gph fuel burn.
Michel from Norway, of this group, once posted some documentation
about a fly-off between a Rotax-powered and a Jabiru-powered
plane...Michel?
Lynn
On Jan 6, 2007, at 9:10 PM, kentk wrote:
> Lynn
Lynn,
along those lines.
Kent
kentk25[at]yahoo
http://forums.matronics.com/viewtopic.php?p=85957#85957
N369LM |
Guy Buchanan
Posted: Sun Jan 07, 2007 7:46 am Post subject: Rear spar attach reinforcement |
At 06:28 PM 1/5/2007, you wrote:
| Quote: | I tried to make my first part #22003 Rear Spar Attach Reinforcement (for
No question. Replace it. I know it's discouraging but you'll probably make
many, many parts twice or even three times during the construction of your
aircraft. Calling it a "kit" was optimistic at best. It's more of an
"assisted plans-built" aircraft.
Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
