Surface Corrosion?
kearney(at)shaw.ca
PostPosted: Wed Dec 27, 2006 6:13 pm    Post subject: Surface Corrosion? Reply with quote
Hi
This evening I was starting to prep my tail cone parts. When removing the vinyl wrap, one piece had some unusual surface discoloration. I thought it might be some adhesive and tried removing it with lacquer thinner but to no avail. It looks like a mineral deposit of some sort. Is this surface corrosion and if so how to handle this.
I have attached a couple of pictures.
Inquiring minds need to know
Les Kearney
RV10 # 40643 – Lost in the empennage
PS: I hope everyone had a fun Christmas and is looking forward to a great New Year!
 Filesize:  95.27 KB
 Viewed:  319 Time(s)
 Filesize:  98.89 KB
 Viewed:  324 Time(s)
DAVELEIKAM(at)wi.rr.com
PostPosted: Wed Dec 27, 2006 8:44 pm    Post subject: Surface Corrosion? Reply with quote
Looks like filiform corrosion. I would talk to Van's and maybe replace the part.
Dave Leikam
40496
kearney(at)shaw.ca
PostPosted: Wed Dec 27, 2006 10:18 pm    Post subject: Surface Corrosion? Reply with quote
HI Dave
Thanks for the info. It does look a bit odd and therefore troublesome. I will do as you suggest and speak to Vans and see what they have to say.
Cheers
Les Kearney
kearney(at)shaw.ca
PostPosted: Wed Dec 27, 2006 10:30 pm    Post subject: Surface Corrosion? Reply with quote
Hi Dave
Based on your description, I googled Filiform Corrosion and found this link. It has a very interesting time lapse movie showing Filiform Corrosion forming on aluminum as well as an explanation as to why it forms.
Cheers
Les
john_rv10(at)yahoo.com
PostPosted: Thu Dec 28, 2006 2:28 am    Post subject: Surface Corrosion? Reply with quote
Hi Les,
Yes, that looks very much like filiform corrosion. You will find that alodine won’t take to that area.
A relatively painless but time consuming solution I found for the same problem is to remove the filiform corrosion with a small grinder with a felt pad with some aluminum polishing paste. This preps the surface for alodining then painting as you prefer. Other methods of removing the filiform corrosion I tried left the surface too marked for my liking.
(wings)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney
Sent: Thursday, 28 December 2006 1:08 PM
Subject: Surface Corrosion?
Hi
Les Kearney
gommone7(at)bellsouth.net
PostPosted: Thu Dec 28, 2006 4:12 am    Post subject: Surface Corrosion? Reply with quote
Hi Les,I did recive one of my wings bottom skins in the same conditions,it is a no brainer,I ask them if my dollars have some kind of surface corrosion,don't even ask what to do ,ask only for a replacement,that simple,
Cheers ,Hugo #40456
Date: 2006/12/27 Wed PM 09:08:03 EST
Hi
Les Kearney
RV10 # 40643 - Lost in the empennage
New Year!
rleffler
PostPosted: Thu Dec 28, 2006 4:26 am    Post subject: Surface Corrosion? Reply with quote
Les’s issue with corrosion reminded me of a topic I wanted to solicit opinions from the list. I attended a RV builder’s class a couple weeks ago at Grov-Air in Indy. Troy Grover, the gentleman conducting the class stated that he has seen several RVs that have significant corrosion along the lines were the vinyl wrap was removed by a soldering iron. His conclusion was that dirt was collecting in the edge of the vinyl and absorbing moisture. He stated that he’s seen this in the last couple kits that have come through his shop.
Since my empennage kit is in route at the moment, I am thinking about the approach I want to take. My current desire is to leave the vinyl on as long as possible to minimize scratching.
Does anyone know of anyone that has experienced corrosion along the lines of the vinyl that were cut with a soldering iron?
It seems like the only way to prevent the issue that Les has discovered is to remove the vinyl when you inventory, but I would think would have disastrous effect of the quality of the surface.
I am very interested in hearing on how Van’s handles Les’s issue. I am optimistic that they will replace the part for Les.
Sent: Wednesday, December 27, 2006 9:08 PM
Hi
Les Kearney
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
LIKE2LOOP(at)AOL.COM
PostPosted: Thu Dec 28, 2006 8:02 am    Post subject: Surface Corrosion? Reply with quote
In a message dated 12/28/2006 7:27:54 AM Eastern Standard Time, rvmail(at)thelefflers.com writes:
Find out more about the conditions of the parts that he described, as in where were they stored? How long (years)? Humidity, laying on bare concrete, etc.... i would be suspicous of moisture getting under the plastic, from repeated wiping with a wet cloth to clean the part or laying on bare cement floor or against a block wall. Maybe these cases involved a heavy hand that scratched the pure aluminum layer from the part as the plastic was being melted with the soldering iron? That would allow some damage to occur!   If too small of a soldering iron is used, there may be a temptation to press harder to cut the plastic. Use a big iron and move it only fast enough to cut passively and it wont mar the metal. Think of it like the tracking of a diamond needle on a plastic record. There is always a reason, and i don't buy the "dirt" concept. The dirt would be carbon residue from plastic melting, sitting on top of pure aluminum. Something else happened....
I am in FLA, very high humidity, with plastic film cut back with soldering iron. No signs of any change yet, and i am going very slow on my build. The film is very protective of the large outer surfaces. I did strip all of plastic away on everything internal of course, so you are only talking about the outer skins....
Steve
Stephen Blank   #40499
766 SE River Lane
Port St. Lucie, FL 34983
772-475-5556 cell - evenings and weekends
kearney(at)shaw.ca
PostPosted: Thu Dec 28, 2006 8:29 am    Post subject: Surface Corrosion? Reply with quote
Ooops
I forgot to attach the link.
It is: http://aluminium.matter.org.uk/content/html/eng/default.asp?catid=180&pageid=2144416691
Cheers
Les
AV8ORJWC
PostPosted: Thu Dec 28, 2006 2:53 pm    Post subject: Surface Corrosion? Reply with quote
Les, that’s an Excellent read of all eleven (11) web pages. This is what I play with every night while other builder’s sleep. It brings clarity to the issues of alodine, anodize and proper surface preparation including final topcoat application without a “declaration of war”.
The final corrective solution often involves Eddy Current, Ultra-sound or X-ray (all expensive diagnostics) and drives home the value of prevention rather than intervention due to poor preparation during initial construction.
John Cox
Sent: Thursday, December 28, 2006 8:25 AM
Subject: RE: Surface Corrosion?
Ooops
Cheers
Les
kearney(at)shaw.ca
PostPosted: Thu Dec 28, 2006 8:23 pm    Post subject: Surface Corrosion? Reply with quote
Hi Again
I spoke to Ken at Van’s who suggested I clean the filiform corrosion using a scotchbright pad. After some serious scouring, I got it off with the pad. That being said, I was most unhappy with the result as I was almost certainly well into the substrate and removed the ALCLAD layer. As a result I am concerned that it may lead to greater problems in the future especially if my priming is compromised during assembly. Van’s was quite happy to send out a replacement. As this is part of the forward tail cone bulkhead, this won’t have too big an impact on my build schedule.
Cheers
Les
RV10 #40643 – Lost in the empennage
jaybrinkmeyer(at)yahoo.co
PostPosted: Fri Dec 29, 2006 6:04 am    Post subject: Surface Corrosion? Reply with quote
The solution is to simply remove all of the plastic up front... Parts can't be
properly dimpled, riveted, or deburred with plastic in the way. In addition, if
you are planning to paint you'll end up buffing/sanding/scotch-briting every
inch of the surface anyway. So add lots of hours to an already long project by
oh-so-carefully removing plastic in nice straight lines?
If the corrosion is minor, just buff it out and move on. I had a few (one or
two) parts that also had this look and simply took a scotchbrite pad to it and
the primer did stick. No big deal as there are lots of other way harder things
to worry about.
Jay
Fuse panel ribs
Time: 04:26:00 AM PST US
Les's issue with corrosion reminded me of a topic I wanted to solicit
opinions from the list. I attended a RV builder's class a couple weeks
class
absorbing moisture. He stated that he's seen this in the last couple
kits
long
of
is
I am very interested in hearing on how Van's handles Les's issue. I am
