jindoguy(at)gmail.com Guest
Posted: Thu Dec 28, 2006 8:57 am Post subject: Tail wheel strut |
Sorry for the delay, I was wrestling hay rolls for my buddy and didn't get around to the photography until this morning.
It was a good thing to take a look at the strut since I was once again reminded that I haven't gotten around to painting it, yet. One of those, I want to fly right now, I'll do it up proper this winter items. And now it's winter. Anyway.
The tubing size for the outer sleeve is 3/4" X .058, the inner is 5/8" X .065. Frankly, it's a bit heavier than I would like and I'll probably go back to aluminum when I do take it off. It is stout, though, and won't bend, at least so far, under the worst "arrival" loads.
Rick
Rick Girard
"Ya'll drop on in"
takes on a whole new meaning
when you live at the airport.
61.92 KB |
405 Time(s) |
jim
Posted: Thu Dec 28, 2006 9:21 am Post subject: Tail wheel strut |
Rick, is that a fully castering tailwheel in the photo? The TW on my
Firefly does not caster. If yours does caster, what is it and where can I
get one?
Jim
| Quote: | Sorry for the delay, I was wrestling hay rolls for my buddy and didn't get
_________________ Jim
N. Idaho |
Posted: Thu Dec 28, 2006 9:29 am Post subject: Tail wheel strut |
Hi Gang:
Couple things about tail wheel struts.
1-For my own purposes, I find the struts about twice as long as
necessary. The long strut also agrevates the problem with bending,
permanently.
2-I use 4130 tail wheel strut. However, I have it heat treated to 48
RC, which turns it into a spring. Normalized 4130 is very stiff, and
if it bends, it stays bent.
_________________ John Hauck
Titus, Alabama |
planecrazzzy Guest
Posted: Thu Dec 28, 2006 11:48 am Post subject: Re: Tail wheel strut |
Hi Rick,
I notice you have the springs like the prints say....
Alot of us have changed them to the screen door type set up...
Mine are home made , others have bought theirs...
Here's a picture of mine , ( made with TIG welding rod )
Gotta Fly...
Mike in MN
57.26 KB |
367 Time(s) |
Posted: Thu Dec 28, 2006 1:11 pm Post subject: Tail wheel strut |
Jim, I have the 6" full swivel from Aircraft Spruce. Travis has the 4" version, and may have the 6", too, at TNK.
Rick
On 12/28/06, Jim Dunn <jim(at)tru-cast.com (jim(at)tru-cast.com)> wrote: | Quote: | --> Kolb-List message posted by: "Jim Dunn" < jim(at)tru-cast.com (jim(at)tru-cast.com)>
get one?
Rick Girard
"Ya'll drop on in"
jim
Posted: Thu Dec 28, 2006 1:36 pm Post subject: Tail wheel strut |
Thanks. At Spruce I assume it's the one for 5/8" tubing and 10 degrees?
Jim
| Quote: | Jim, I have the 6" full swivel from Aircraft Spruce. Travis has the 4"
Rick
> I
> get one?
> Thanks,
> Jim
> get
Rick Girard
"Ya'll drop on in"
N. Idaho |
Posted: Thu Dec 28, 2006 2:17 pm Post subject: Tail wheel strut |
That's the one.
Rick
On 12/28/06, Jim Dunn <jim(at)tru-cast.com (jim(at)tru-cast.com)> wrote:[quote] --> Kolb-List message posted by: "Jim Dunn" <jim(at)tru-cast.com (jim(at)tru-cast.com)>
Jim
Rick
> I
> get one?
> Thanks,
> Jim
> get
Rick Girard
"Ya'll drop on in"
"Ya'll drop on in"
rap(at)isp.com Guest
Posted: Mon Jan 08, 2007 3:57 pm Post subject: Tail wheel strut |
John: My tail strut went ahead droke this weekend. I knew it would the way
it was bending.Can you go into more detail about the heat treating process?
Posted: Mon Jan 08, 2007 4:23 pm Post subject: Tail wheel strut |
Rick P:
I use 4130 heat treated to RC 48.
Think it is 3/4 X .120 wall.
You can cut the standard length in half and still have enough to do a
good job.
Any good heating treating plant in your area can do the heat treating
for you.
Titus, Alabama |
