david.steade(at)btinterne Guest
Posted: Sun Dec 10, 2006 2:14 pm Post subject: First Flight G-CDXY |
Just to let everyone know I finally flew my Mk 7 on Saturday 9th December after 3 1/2 years construction.
Here are some of the details.
100hp Rotax engine
VP 50 in flight variable pitch propeller
830 lbs empty
Take off run about 200 Yards
Rate of climb 1 up 1/3rd fuel 1200 fpm
Rate of climb 2 up 1/2 fuel 900 fpm
Cruise 60 to 70% power 90 knots (4800 rpm at 26 inches manifold)
Max straight and level 102 knots
3 flights total 2 hours
No adjustments needed
Elevator trim very powerful almost no rudder required at any cruise speed.
Much better than I hoped and a lot different to the Mk3 I had previously.
David Steade
50.12 KB |
481 Time(s) |
donpearsall Guest
Posted: Sun Dec 10, 2006 2:46 pm Post subject: First Flight G-CDXY |
David, congratulations on your first flight! You built a beautiful aircraft. Thanks for sharing it with us
Don Pearsall
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of David Steade
Sent: Sunday, December 10, 2006 2:14 PM
Subject: First Flight G-CDXY
100hp Rotax engine
830 lbs empty
David Steade
Michel
Posted: Sun Dec 10, 2006 2:59 pm Post subject: First Flight G-CDXY |
On Dec 10, 2006, at 11:13 PM, David Steade wrote:
| Quote: | Just to let everyone know I finally flew my Mk 7 on Saturday 9th
Congratulations, David.
| Quote: | Much better than I hoped and a lot different to the Mk3 I had
previously.
Please, let us know. I have a model 3.
Michel
dave
Posted: Sun Dec 10, 2006 3:31 pm Post subject: First Flight G-CDXY |
Way to go David !!
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
eskflyer(at)lvcisp.com Guest
Posted: Sun Dec 10, 2006 3:40 pm Post subject: First Flight G-CDXY |
YEEEEEEEHAWWWW way to go now go have fun and fly safe Congratulations
John Perry
Sjklerks(at)aol.com Guest
Posted: Sun Dec 10, 2006 4:15 pm Post subject: First Flight G-CDXY |
Nice looking 7 congrats
Jim
Guy Buchanan
Posted: Sun Dec 10, 2006 9:28 pm Post subject: First Flight G-CDXY |
At 02:13 PM 12/10/2006, you wrote:
| Quote: | Just to let everyone know I finally flew my Mk 7 on Saturday 9th December
Congratulations David! I'm looking forward to seeing you at the Desert Fox
Fly-in in March.
Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
Michel
Posted: Mon Dec 11, 2006 12:30 am Post subject: First Flight G-CDXY |
| Quote: | From: Guy Buchanan [bnn(at)nethere.com]
Fly-in in March.
Isn't the Desert Fox fly-in in the US? Isn't David in UK?
Just wondering,
Michel
jdmcbean(at)cableone.net Guest
Posted: Mon Dec 11, 2006 6:19 am Post subject: First Flight G-CDXY |
Congrats David !!!
<![if !supportEmptyParas]> <![endif]>
AUTOTEXTLIST \s "E-mail Signature" <![endif]-->Fly Safe !!
John & Debra McBean
208.337.5111
www.kitfoxaircraft.com
"It's not how Fast... It's how Fun!"
<![endif]--><![if !supportEmptyParas]> <![endif]>
-----Original Message-----
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of David Steade
Sent: Sunday, December 10, 2006 3:14 PM
100hp Rotax engine
830 lbs empty
David Steade
lcfitt(at)sbcglobal.net Guest
Posted: Mon Dec 11, 2006 7:23 am Post subject: First Flight G-CDXY |
David,
Very nice! congratulations.
Lowell
Posted: Tue Dec 12, 2006 10:58 am Post subject: First Flight G-CDXY |
Michel
There is much more inertia with the Mk7 due to the increased weight this makes it more stable. The simplified mixer for the flaperons together with the differential movement results in less rudder input than on the Mk3 and a lot more feel.
My Mk3 had a 582 so the increase in power with the 912S is very noticeable with a significant increase in cruise speed and climb rate.
There are lots of small changes that have added to the comfort. Good heater, no drafts from the doors, somewhere to put the coat and bags, a bit more width in the cockpit all in all quite a different aircraft.
In the UK there is only one other Mk7 flying with two more being built, most of the Kitfox fleet of about 50 aircraft are Mk2 and 3 versions with a handful of Mk1 and 4 and just one Mk5.
David
Michel
Posted: Tue Dec 12, 2006 12:55 pm Post subject: First Flight G-CDXY |
On Dec 12, 2006, at 7:36 PM, David Steade wrote:
| Quote: | There is much more inertia with the Mk7 due to the increased weight
Thanks, David. Of course, one would expect that the aircraft becomes
better and better in the later models. Now, I know better how.
Michel
skyring
Posted: Sun Dec 17, 2006 2:32 pm Post subject: Re: First Flight G-CDXY |
David that looks great. We have a similar S5 in Austria with 100 hp Rotax but with 8" tyres so maybe a bit more drag. Currently doing taxi tests and engine run-ups so it will fly very soon. Actually we had some short flights 12 months ago but then had to change the engine so basically a 12 month set back. We will one day fly to England in OE-MJU so will catch up with you. Or maybe meet in France or Germany? Anyway well done. I think the 5 will be a very good plane. Kerry.
john beirne
Posted: Mon Dec 18, 2006 12:51 pm Post subject: Re: First Flight G-CDXY |
Best of luck with your Mk 7 David,
Incidently is it the same demensions as the MK 3 with the wings folded.
John.
Posted: Tue Dec 19, 2006 9:06 am Post subject: First Flight G-CDXY |
No, its about 18 inches longer and 3 inches wider.
David Steade
