First Flight G-CDXY
david.steade(at)btinterne
PostPosted: Sun Dec 10, 2006 2:14 pm    Post subject: First Flight G-CDXY Reply with quote
Just to let everyone know I finally flew my Mk 7 on Saturday 9th December after 3 1/2 years construction.
Here are some of the details.
100hp Rotax engine
VP 50 in flight variable pitch propeller
830 lbs empty
Take off run about 200 Yards
Rate of climb 1 up 1/3rd fuel 1200 fpm
Rate of climb 2 up 1/2 fuel 900 fpm
Cruise 60 to 70% power 90 knots (4800 rpm at 26 inches manifold)
Max straight and level 102 knots
3 flights total 2 hours
No adjustments needed
Elevator trim very powerful almost no rudder required at any cruise speed.
Much better than I hoped and a lot different to the Mk3 I had previously.
David Steade
 Filesize:  50.12 KB
 Viewed:  486 Time(s)
donpearsall
PostPosted: Sun Dec 10, 2006 2:46 pm    Post subject: First Flight G-CDXY Reply with quote
David, congratulations on your first flight! You built a beautiful aircraft. Thanks for sharing it with us
Don Pearsall
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of David Steade
Sent: Sunday, December 10, 2006 2:14 PM
Subject: First Flight G-CDXY
100hp Rotax engine
830 lbs empty
David Steade
Michel
PostPosted: Sun Dec 10, 2006 2:59 pm    Post subject: First Flight G-CDXY Reply with quote
Congratulations, David.
previously.
Please, let us know. I have a model 3.
Michel
Kitfox 3 - Jabiru 2200
dave
PostPosted: Sun Dec 10, 2006 3:31 pm    Post subject: First Flight G-CDXY Reply with quote
Way to go David !!
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube
eskflyer(at)lvcisp.com
PostPosted: Sun Dec 10, 2006 3:40 pm    Post subject: First Flight G-CDXY Reply with quote
YEEEEEEEHAWWWW way to go now go have fun and fly safe Congratulations
John Perry
Sjklerks(at)aol.com
PostPosted: Sun Dec 10, 2006 4:15 pm    Post subject: First Flight G-CDXY Reply with quote
Nice looking 7 congrats
      Jim
Guy Buchanan
PostPosted: Sun Dec 10, 2006 9:28 pm    Post subject: First Flight G-CDXY Reply with quote
Congratulations David! I'm looking forward to seeing you at the Desert Fox
Fly-in in March.
Guy Buchanan
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
Michel
PostPosted: Mon Dec 11, 2006 12:30 am    Post subject: First Flight G-CDXY Reply with quote
Fly-in in March.
Isn't the Desert Fox fly-in in the US? Isn't David in UK?
Just wondering,
Michel
jdmcbean(at)cableone.net
PostPosted: Mon Dec 11, 2006 6:19 am    Post subject: First Flight G-CDXY Reply with quote
Congrats David !!!
<![if !supportEmptyParas]> <![endif]>
AUTOTEXTLIST \s "E-mail Signature" <![endif]-->Fly Safe !!
John & Debra McBean
208.337.5111
www.kitfoxaircraft.com
"It's not how Fast... It's how Fun!"
<![endif]--><![if !supportEmptyParas]> <![endif]>
-----Original Message-----
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of David Steade
Sent: Sunday, December 10, 2006 3:14 PM
100hp Rotax engine
830 lbs empty
David Steade
lcfitt(at)sbcglobal.net
PostPosted: Mon Dec 11, 2006 7:23 am    Post subject: First Flight G-CDXY Reply with quote
David,
Very nice! congratulations.
Lowell
PostPosted: Tue Dec 12, 2006 10:58 am    Post subject: First Flight G-CDXY Reply with quote
Michel
There is much more inertia with the Mk7 due to the increased weight this makes it more stable. The simplified mixer for the flaperons together with the differential movement results in less rudder input than on the Mk3 and a lot more feel.
My Mk3 had a 582 so the increase in power with the 912S is very noticeable with a significant increase in cruise speed and climb rate.
There are lots of small changes that have added to the comfort. Good heater, no drafts from the doors, somewhere to put the coat and bags, a bit more width in the cockpit all in all quite a different aircraft.
In the UK there is only one other Mk7 flying with two more being built, most of the Kitfox fleet of about 50 aircraft are Mk2 and 3 versions with a handful of Mk1 and 4 and just one Mk5.
David
Michel
PostPosted: Tue Dec 12, 2006 12:55 pm    Post subject: First Flight G-CDXY Reply with quote
Thanks, David. Of course, one would expect that the aircraft becomes
better and better in the later models. Now, I know better how.
Michel
skyring
PostPosted: Sun Dec 17, 2006 2:32 pm    Post subject: Re: First Flight G-CDXY Reply with quote
David that looks great. We have a similar S5 in Austria with 100 hp Rotax but with 8" tyres so maybe a bit more drag. Currently doing taxi tests and engine run-ups so it will fly very soon. Actually we had some short flights 12 months ago but then had to change the engine so basically a 12 month set back. We will one day fly to England in OE-MJU so will catch up with you. Or maybe meet in France or Germany? Anyway well done. I think the 5 will be a very good plane. Kerry.
john beirne
PostPosted: Mon Dec 18, 2006 12:51 pm    Post subject: Re: First Flight G-CDXY Reply with quote
Best of luck with your Mk 7 David,
Incidently is it the same demensions as the MK 3 with the wings folded.
John.
PostPosted: Tue Dec 19, 2006 9:06 am    Post subject: First Flight G-CDXY Reply with quote
No, its about 18 inches longer and 3 inches wider.
David Steade
