marksorenson(at)sprintpcs Guest
Posted: Sat Jan 28, 2006 7:12 am Post subject: Iris Instead of Grills |
Hello all,
Can anyone tell me if it is practical to replace the grills on the front of my Yak with an Iris type grill. Thanks.
Best Regards,
Mark-
678-GO-FLY-HI
This message was sent from a Sprint PCS Phone.
Get a Sprint PCS Wireless Mail account!
Sign up via the Wireless Web Browser on your Sprint PCS Phone
or at http://www.sprintpcs.com.
rvfltd(at)televar.com Guest
Posted: Sat Jan 28, 2006 8:48 am Post subject: Iris Instead of Grills |
Mark,
It is done more now than in the past because of the rising cost of the
individual gill shutters has made the rather high price of the titanium iris
system more in line. I have brought in 6 sets so far and all were installed
on CJ6's. I have no stock right now but have some on order and should see
them in 60 days or so. You have a CJ, or 52 or? Contact me off list if you
need more info r give me a call at 509-826-4610.
Always Yakin,
Doug Sapp
dsavarese(at)elmore.rr.co Guest
Posted: Sat Jan 28, 2006 4:47 pm Post subject: Iris Instead of Grills |
Only one question. Why?
Dennis
HawkerPilot2015
Posted: Sat Jan 28, 2006 9:18 pm Post subject: Re: Iris Instead of Grills |
Mark,
I have an Iris setup on my Yak-50. Main reason is the airplane did not come with the gills when I bought it. I wanted something so I could control the temps and decided on the Iris. It has quite a few less parts and in the long run, was cheaper. I DO NOT have the titanium Iris. Mine are stainless steel.
I am still working on a way to "control" them as they are fixed right now. My temps are right where they should be. The only thing I deal with is longer warm up times.
Something else to think about. The gills add structure to the engine cowling where the Iris does not. Mark Bitterlich can add more to this. I have not had any issues with it so far but have quite a bit less time without the gills than Mark does. Mine is ROCK solid without the gills but I am not under the impression that that will remain true and am taking steps to prevent that.
As to Dennis's question why, I think it is a simpler system with less parts. It may also be cheaper. Dennis or Doug can answer that question though..
Doug, I am interested in talking to anyone who has mounted this system. Can you put me in touch with them?
Posted: Sun Jan 29, 2006 6:18 am Post subject: Iris Instead of Grills |
My interpretation was Mark was considering changing the standard cooling
louvers over to the iris type. I was just wondering why someone would want
to do that unless their existing cooling louvers were severely damaged and
cost prohibitive to repair.
Dennis
HawkerPilot2015
Posted: Sun Jan 29, 2006 6:53 am Post subject: Re: Iris Instead of Grills |
| dsavarese(at)elmore.rr.co wrote: | My interpretation was Mark was considering changing the standard cooling
Dennis
Ahhh...yeah I would agree that it would not be worth the effort if the existing system is intact.
If it aint broke...dont fix it.
BitterlichMG(at)cherrypoi Guest
Posted: Mon Jan 30, 2006 3:27 pm Post subject: Iris Instead of Grills |
Hello Mark,
This is ANOTHER "Mark" so this is bound to get confusing. Tim mentioned my experience in regard to flying without gills, so I thought I would bring my experiences in this regard to light.
There have been a number of people who have replaced the gill system with the IRIS system, and the conversion is fairly simple. One thing to keep in mind is that there are two different types of systems for controlling the IRIS. The original system found on most Sukhoi 26's and their ilk used two cables in semi hard tubes that each fed to a round wheel on the IRIS itself. In the cockpit there is a control LEVER that pulls on one cable at a time... obviously as you pull on one cable (and put it into tension) the other moves backwards and is slack and at that point the wheel on the IRIS pulls keeping it taught. Just picture two cables attached 180 degrees apart to the outer rim of a wheel and you'll get the picture.
The newer method (and more preferable by far) is found on the newer SU-31's, and uses a HARD TUBE PUSH/PULL ROD very close to what controls the original YAK prop and gills. If you get the NEWER IRIS, you should be able to use the existing YAK control that comes on the aircraft that used to control your gills.
Ok, now the bad news.
My YAK-50 came with the Les Crowder big spinner mod. (I mean as in HUGE.. looks good though, and I have been told that this is really a YAK-18T spinner, but I don't know for sure). Anyway, this mod required all the gills to be removed.
So, when I originally bought the aircraft, it had 110 hours on it since new, and away I went... no gills, no problem, who cares anyway?
After about 150 additional hours or so, I started getting all sorts of cracking on the cowling leading edges. Then the hollow tubes that the front of the top and bottom cowling are riveted to, started cracking too. This problem became more serious as time went on, because at the same time, the little red tubes/struts that hold the cowl MOUNTING ring in place started to crack and break TOO! These are the little adjustable things that bolt to the front of each cylinder and go straight out to the cowl mounting ring.
At the time, I could not imagine what was causing all this. When my cowl was closed, it closed fairly firmly on the front cowl ring I just described above. I thought this might be the problem so I loosened everything up. Wrong Answer. The problem got worse.
I put soft fabric material between the mounting ring and the cowl ring.... this helped a little, but it could still easily be seen that things were just vibrating too darn much. I might also mention that my two bladed prop was also out of balance quite a bit. Balanced the prop.... and that helped, but did not STOP the problem.
I then got the chance to study a YAK-52 up close and personal, and could see that those gills added quite a lot of support to that front cowl ring. So, I made four adjustable struts out of stainless steel tubing.... identical in design and function to the ones coming straight out from the cylinder attachment points, but for these... I ran them out from the front of the engine supercharger cover (using the same mounting studs that the IRIS would attach to) HORIZONTALLY to the front cowl ring. Four of them, one every 90 degrees. These acted like spokes on a wheel, and gave back the support that the original gills had.
Result? Problem cured. No more cowling damage... problem is 100% FIXED.
This leads me to advise AGAINST putting an IRIS system on a YAK-50/52, UNLESS you also take additional steps to support that front cowl ring. There are a lot of other factors involved here... such as: "What condition are your engine mounting rubbers in?" Bottom line, the front of the cowls MUST MOVE WITH THE ENGINE, and if you take out the gills, you basically have a situation best pictured by imagining a person holding a HULA-HOOP out in front of himself with outstretched arms. Then picture something/ANYTHING, "hanging from the hula-hoop itself"... you can see, there just is not any structural strength in that kind of assembly. Put the gills in, and mount the gills to the engine itself, and you can see that the above picture regains all of its strength.
By the bye, this is yet another reason to keep those leather mounting pads in good condition that are located on the engine itself. These ALSO provide quite an amount of structural support to the whole upper and lower cowl.
Sorry for the long post, but the details were needed in my opinion.
Mark Bitterlich
N50YK
Here are some other interesting things that I learned the hard way about... last week!
p.s. Another tid bit for the YAK list. The YAK-52/50/55 and the Sukhoi-26/29/31 AND the CJ-6, all use the exact same piston in the air-compressor relief valve. This piston and seal are what you adjust to control the peak pressure in your air system in the aircraft. Doug Sapp sells the whole assy. for the CJ.... and you can take it right apart, take out the piston and spring (and locking nut) and put the whole mess into your YAK, if you want to do that instead of repair what you have with a new rubber bushing. Here's the TID BIT: The YAK-52W (and I am GUESSING the YAK-52TW as well) has a DIFFERENT PISTON in the pressure relief assy. It is slightly BIGGER and is NOT a direct replacement with all the others mentioned earlier. Why not? Go figure.
p.p.s. YAK-52W guys... did you know that there is an emergency pressure relief valve behind the seat that allows you to eliminate emergency air pressure to the landing gear without having to crack fittings and jack and cycle the gear, if you ever do happen to open the emergency bottle valve?
p.p.p.s. For those aircraft with the manual engine starting valves (YAK-55, Sukhoi's) be aware that the rubber replacement tab for the starter valve MUST have a whole cut in the middle of it. Ignore that fact, and the lever will work a few times and then fail forever. Trust me on this and save yourself a lot of head scratching.
Ernie
Posted: Mon Jan 30, 2006 4:23 pm Post subject: Iris Instead of Grills |
Dont apologize, thank goodness for Yak/CJ related posts
On 1/30/06, Bitterlich GS11 Mark G <BitterlichMG(at)cherrypoint.usmc.mil> wrote:
Hello Mark,
your gills.
Mark Bitterlich
N50YK
last week!
Posted: Mon Jan 30, 2006 5:12 pm Post subject: Iris Instead of Grills |
Mark B,
The Les Crowder spinner is purely a Les Crowder spinner and is not an 18T spinner. The 18T spinner retains the original cooling louvers. Here's a photo of an 18T with spinner.
Dennis
9.8 KB |
1077 Time(s) |
Posted: Mon Jan 30, 2006 5:55 pm Post subject: Iris Instead of Grills |
Mark,
You comment -
"YAK-52W guys... did you know that there is an emergency pressure relief valve behind the seat that allows you to eliminate emergency air pressure to the landing gear without having to crack fittings and jack and cycle the gear, if you ever do happen to open the emergency bottle valve? ", this also applies to the TW. However, regardless of the fact that you can depressurize the actuator AND the shuttle valves by opening these bleed valves, a shuttle valve can stick or not properly seal when the main air pressure is re-applied to the now depressurized actuators and shuttle valves. Therefore it is a very good idea to perform a normal gear retraction after any emergency gear system activation/operation, including the depressurization. It's better to be safe than sorry.
Also, for those that did not know, the standard Yak 52, (which of course does not have the additional bleed valve on the right side rear console like the W and TW), you can discharge the air pressure in the actuators and shuttle valves by squeezing and releasing the brake handle until all the air is depleted in the actuators and shuttle valves as long as both the main and emergency air valves are closed beforehand.
Dennis
cjpilot710(at)aol.com Guest
Posted: Mon Jan 30, 2006 6:20 pm Post subject: Iris Instead of Grills |
I had iris on my CJ/ M14p for several years. I personally didn't like them. I could never get the engine warm enough. Even full closed there was 1 to 1 1/4 inch gap opening.
They looked terrible unpainted so I painted them. Than the paint scraped off while opening or closing them.
Also they rattled when curious folks would move them with their hands. They sounded cheap and looked cheap.
I ended up buying a 55's system and totally rebuilt it. I made my own vanes (.020 T-3 bent over and than cut to shape. Spot welded along the trailing edge.) I had to weld up worn out holes in the outer ring and cam. I than made a simple jig and re-drilled them. The only things original was the outer ring, nose plate and cam. I've had mine on now well over 300 hours showing minor wear.
Jim "Pappy" Goolsby
cpayne(at)joimail.com Guest
Posted: Tue Jan 31, 2006 4:00 am Post subject: Iris Instead of Grills |
| Quote: | engine supercharger cover
Hmmm, could that be the engine gearbox cover?
| Quote: | attach to) HORIZONTALLY to the front cowl ring. Four of them, one every 90
I too have removed the gills but left the gill outer ring in place with the original mounting rods. Since I have the Crowder spinner in place now, I'm watching it all very closely. Another problem I have noticed on cowls without gills is that the cowl skin UNDER the lower mounting brackets tend to crack through around the bracket that holds the "donuts" the pins go through. Doublers on the skin are required.
Craig Payne
gus.fraser(at)gs.com Guest
Posted: Tue Jan 31, 2006 5:40 am Post subject: Iris Instead of Grills |
Un the Sukhoi and my SP the whole cowl is MUCH stronger than the standard 50/52 cowl. For example, the front of the cowl is shaped like a wing there is baffling on the inside of the cowl that gives great strength. Also there are support arms from all cylinders to the cowl (see attached picture) I bet you have wondered what those bolts on the front of the cylinder were for, well guess no more because they are the mounting for the support arms.
The diameter of the cowl opening is also slightly smaller hence the gap on a 52 cowl when the flaps are closed.
Hope this helps
Gus
[quote] From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Bitterlich GS11 Mark G
Sent: Monday, January 30, 2006 6:22 PM
To: 'yak-list(at)matronics.com'
Subject: RE: Iris Instead of Grills
Hello Mark,
Mark Bitterlich
N50YK
164.13 KB |
1159 Time(s) |
![sp91seal%20036[1].jpg](files/thumbs/t_sp91seal_20036_1__180.jpg)
marksorenson
Posted: Tue Jan 31, 2006 7:22 am Post subject: Re: Iris Instead of Grills |
Again thanks for all your responses to my question. My Grils are repairable I am sure They close fine but when open they shimmy quite a bit durring my routine. I do have the summer time ring, i guess that is what you call it, to install when it gets warmer. I haven't taken a close look at it yet to see exactly how it goes on, but I was assuming that the entire support ring would come off and this would go on in its place. My Yak is the 55M. However listening to some of your comments I am not sure if removing the support ring is the way to go for my summer flying. Currently I only use the grills for warm up and then once the power goes up it usually stays up for my routine and cooling temps isn't usually a problem as I don't have any enroute time to the box.
Where I notice most of my wear is on the inner ring close to the crank. The holes are so elongated that there are a couple that are almost worn through the edge. I was first wondering if there was a replace ring part available for rebuilding the grills. The Iris just seemed like a simple device and just as functional. Maybe that isn't exactly the case. Again, thanks for all the imput.
_________________ Mark Sorenson
Tigerbatics N921GRrrrrr |
pilot8kcab(at)hotmail.com Guest
Posted: Tue Jan 31, 2006 10:50 am Post subject: Iris Instead of Grills |
Mark,
I have the Sukhoi Iris on a Yak-55 without any problems. The second owner
installed them, I'm the 3rd owner and would guess they've been on the plane
for atleast 3 years or more. The Yak-55 and 55M cowls are very similar, the
only differences I noticed were some extra cooling gills as well as enlarged
cooling gills in the sides and an extra access panel. I have another friend
who flew a Yak-55M without any grills or Iris (in the Northeast during
Spring, Summer and Fall only) in airshows for years and he also had no
problems. In the Yak-55 with the iris fully expanded I would estimate there
is about 2 inches of clearance between the cowling and the iris.
That being said I've occasionally wondered if there is a differences in
terms of engine longevity between using the grills and the iris as I would
think the grills server to increase or decrease air flow to the engine
fairly uniformly over the length of the cylinders whereas the iris when
operated from fully closed to fully expanded would tend to increase the air
velocity at the upper ends of the cylinders as it decreased air at the lower
ends presumably resulting in a thermal gradient across the cylinder from the
base to the heads. At their extreme with the iris fully expanded in the
Yak-55 and 2 inches clearance from the cowl, the air is accelerated thru
that 2 inch space directed toward the tops of the cyliners only. Again this
is only an "hmmmm, I wonder...." on my part.
If you want more or need details such as photos, let me know and I'll see
what I can do.
Scott
----Original Message Follows----
From: "marksorenson" <marksorenson(at)sprintpcs.com>
Reply-To: yak-list(at)matronics.com
Subject: Re: Iris Instead of Grills
Date: Tue, 31 Jan 2006 07:22:00 -0800
all the imput.
Mark Sorenson
http://forums.matronics.com/viewtopic.php?p=8424#8424
Don’t just search. Find. Check out the new MSN Search!
http://search.msn.click-url.com/go/onm00200636ave/direct/01/
Posted: Tue Jan 31, 2006 10:52 am Post subject: Iris Instead of Grills |
Mark you can fix that inner ring by having all the holes welded up and then redrilled. Sounds like a pain in the rear, but it is not all that difficult really.
By the way, I have no experience with 55's. It is possible that their cowl is much stronger in design than the 52/50 design. For example the Sukhoi design is MUCH stronger than the YAK's.
Good luck,
Mark Bitterlich
Posted: Tue Jan 31, 2006 10:56 am Post subject: Iris Instead of Grills |
Yes, that would be the engine gearbox cover. Thanks for the correction.
Mark
[quote] --
