kelmonroe(at)comcast.net Guest
Posted: Sun Jan 22, 2006 6:27 am Post subject: oil filter for cj 285hp |
I am changing engines and am thinking about installing an oil filter on the firewall. What system of fittimgs, mount, filter and hoses should I be look for? Thanks Kelley
Posted: Sun Jan 22, 2006 7:48 am Post subject: oil filter for cj 285hp |
Airwolf has an intire sytem.
Doc
ggg6(at)att.net Guest
Posted: Sun Jan 22, 2006 7:57 am Post subject: oil filter for cj 285hp |
Kelly, Bill Blackwell has a filter sys he installs on the extreme right side of the firewall, about even with the start air solenoid, or just slightly above that level. I have had it on my CJ for about 350 hrs, and it works very well.. I do not remember the brand, but if you contacted Bill he could tell you who manfactures it, it is an industrial unit that has a screw on oil filter... if you need I could take a picture of the unit installed on my CJ and send it to you.. would be a few days befroe I could do that for you... Gary Gabbard
| Quote: | -------------- Original message from "Kelley Monroe" <kelmonroe(at)comcast.net>: --------------
wlannon(at)cablerocket.co Guest
Posted: Sun Jan 22, 2006 10:34 am Post subject: oil filter for cj 285hp |
Kelley;
I would recommend either ADC or Airwolf. My personal preference is the ADC micro screen unit rather than the spin-on. ADC provides both types, Airwolf is spin-on only.
I would avoid cheap non STC'd systems which invariably utilize spin-on filters that are not capable of safely handling high scavange oil pressures.
Like most other things in aviation you get what you pay for.
Walt
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Sun Jan 22, 2006 7:37 pm Post subject: oil filter for cj 285hp |
Kelley Monroe wrote:
| Quote: | I am changing engines and am thinking about installing an oil filter on
Several others have pointed you to both Airwolf and ADC. Both seem to be
good systems.
There was an excellent article in Light Plane Maintenance sometime
within the last 5 years (no, I don't remember when) comparing various
oil filters including the ADC microscreen. The result of lab testing was
that the standard paper spin-on filter did the better job of removing
crud from the oil.
Still, they said that the ADC filter did a good job of removing
particles from the oil but not down to the same fineness as the paper
filter. They did like that the ADC microscreen could be washed and reused.
Craig Payne had a non-aviation filtration system he was touting that
seems to be better than either an Airwolf/Champion system or an ADC
system. You should ask Craig for the information. (He will probably post
after reading this.)
Brian Lloyd 2243 Cattle Dr.
brian-yak at lloyd dot com Folsom, CA 95630
- Antoine de Saint-Exupery
_________________ Brian Lloyd
- Antoine de Saint-Exupery |
Posted: Sat Jan 28, 2006 6:07 am Post subject: oil filter for cj 285hp |
Can anyone send photos of their ADC systems installation? Thanks Kelley
