				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| kelmonroe(at)comcast.net Guest
				|  Posted: Sun Jan 22, 2006 6:27 am    Post subject: oil filter for cj 285hp |   |
				| I am changing engines and am thinking about  installing an oil filter on the firewall.  What system of fittimgs, mount,  filter and hoses should I be look for?  Thanks  Kelley
 | |  |  | - The Matronics Yak-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Yak-List
		| Back to top |  |
		| viperdoc(at)mindspring.co Guest
				|  Posted: Sun Jan 22, 2006 7:48 am    Post subject: oil filter for cj 285hp |   |
				| Airwolf has an intire sytem.
Doc
		| Back to top |  |
		| ggg6(at)att.net Guest
				|  Posted: Sun Jan 22, 2006 7:57 am    Post subject: oil filter for cj 285hp |   |
				| Kelly, Bill Blackwell has a filter sys he installs on the extreme right side of the firewall, about even with the start air solenoid, or just slightly above that level.  I have had it on my CJ for about 350 hrs, and it works very well.. I do not remember the brand, but if you contacted Bill he could tell you who manfactures it, it is an industrial unit that has a screw on oil filter... if you need I could take a picture of the unit installed on my CJ and send it to you.. would be a few days befroe I could do that for you...  Gary Gabbard
  	  | Quote: |  	  | -------------- Original message from "Kelley Monroe" <kelmonroe(at)comcast.net>: --------------
		| Back to top |  |
		| wlannon(at)cablerocket.co Guest
				|  Posted: Sun Jan 22, 2006 10:34 am    Post subject: oil filter for cj 285hp |   |
				| Kelley;
 I would recommend either ADC or Airwolf. My  personal preference is the ADC micro screen unit rather than the spin-on. ADC  provides both types, Airwolf is spin-on only.
 I would avoid cheap non STC'd systems which  invariably utilize spin-on filters that are not capable of safely handling high  scavange oil pressures.
 Like most other things in aviation you get what you  pay for.
 Walt
 [quote]   ---
		| Back to top |  |
		| brian
				|  Posted: Sun Jan 22, 2006 7:37 pm    Post subject: oil filter for cj 285hp |   |
				| Kelley Monroe wrote:
  	  | Quote: |  	  | I am changing engines and am thinking about installing an oil filter on the firewall.  What system of fittimgs, mount, filter and hoses should I
 Several others have pointed you to both Airwolf and ADC. Both seem to be
 good systems.
 There was an excellent article in Light Plane Maintenance sometime
 within the last 5 years (no, I don't remember when) comparing various
 oil filters including the ADC microscreen. The result of lab testing was
 that the standard paper spin-on filter did the better job of removing
 crud from the oil.
 Still, they said that the ADC filter did a good job of removing
 particles from the oil but not down to the same fineness as the paper
 filter. They did like that the ADC microscreen could be washed and reused.
 Craig Payne had a non-aviation filtration system he was touting that
 seems to be better than either an Airwolf/Champion system or an ADC
 system. You should ask Craig for the information. (He will probably post
 after reading this.)
 Brian Lloyd                         2243 Cattle Dr.
 brian-yak at lloyd dot com          Folsom, CA 95630
 +1.916.367.2131 (voice)             +1.270.912.0788 (fax)
 - Antoine de Saint-Exupery
 Brian Lloyd
		| Back to top |  |
				|  Posted: Sat Jan 28, 2006 6:07 am    Post subject: oil filter for cj 285hp |   |
				| Can anyone send photos of their ADC systems  installation?  Thanks Kelley
[quote]   ---
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
