		bakerocb
				 Posted: Mon Oct 23, 2006 10:44 am    Post subject: antenna interference |
				10/23/2006
 Hello Bob Nuckolls and other antenna experts,
  Some time ago a fellow builder installed an Advanced Aircraft Electronics
 comm antenna in
 the vertical stab of his composite (fiberglass) airplane.  The antenna is a
 straight one piece dipole with balun in  center.
 The reception was tested with a radio and found to be excellent.  In
 attaching the rudder, a full length aluminum piano style hinge was
 installed. This is one of the builder's modifications to the original plans
 that called for separate short segments of aluminum piano type hinge for the
 rudder.
 When testing the reception again with the same transmitter the reception was
 practically nonexistent.
 The builder would like to retain use of the antenna and come up with a
 (nearly continuous) hinge solution that will permit adequate transmission
 and reception. Various solutions have been proposed:
 1) Use a continuous piano type hinge made out of plastic. (Guden makes
 them).
 2) Use a continuous piano type hinge made out of carbon fiber.
 http://www.carbinge.com/index.html
 3) Use a basically continuous full length piano type hinge made out of
 carbon fiber, but cut it a number of times during its length into shorter
 than full length segments.
 4) Use a basically continuous full length piano type hinge made out of
 aluminum, but cut it a number of times during its length into shorter than
 5) Abandon the continuous hinge concept and install separate short segments
 of metal hinge as the plans call for.
 We would appreciate your inputs and advice. Thanks.
 OC
  |  | - The Matronics AeroElectric-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		nuckollsr(at)cox.net Guest
				 Posted: Mon Oct 23, 2006 11:25 am    Post subject: antenna interference |
				At 02:41 PM 10/23/2006 -0400, you wrote:
 10/23/2006
 comm antenna in
 a straight one piece dipole with balun in  center.
 plans that called for separate short segments of aluminum piano type hinge
 for the rudder.
 was practically nonexistent.
     Hmmmm . . . "adequate" is the operative word here. Without
     laboratory data on the effects of current configuration and
     any hypothesized solutions will be hip-shots . . .
  	  | Quote: | 	 		  1) Use a continuous piano type hinge made out of plastic. (Guden makes them).
     As a structural part of the airplane?
    I presume the rest of the structure is carbon fiber also. This
    solution is relatively attractive but know that carbon fiber
    while not an excellent conductor . . . it's also very unfriendly
    to RF propagation. At least the hinge material would not be any
    worse than structural components around it
  	  | Quote: | 	 		  3) Use a basically continuous full length piano type hinge made out of
    Cutting a carbon fiber hinge would produce minimal
    benefit once the shift from aluminum to carbon fiber is made.
  	  | Quote: | 	 		  4) Use a basically continuous full length piano type hinge made out of
    This works . . . when driving past AM station towers
    (tower itself is the antenna) one observes that guy wires
    are broken up into short segments by strain insulators.
    The rule of thumb is that a parasitic conductor's length
    should not exceed 1/10th wavelength at frequency of interest.
    In the case of VHF Comm, about .2 meters or 8 inches in length
    or shorter.
  	  | Quote: | 	 		  5) Abandon the continuous hinge concept and install separate short
 segments of metal hinge as the plans call for.
    That works too . . . but probably no better than segmented
    hinges of other materials.
		douglist(at)macnauchtan.c Guest
				 Posted: Mon Oct 23, 2006 12:49 pm    Post subject: antenna interference |
				At 14:41 -0400 10/23/06, <bakerocb(at)cox.net> wrote:
  	  | Quote: | 	 		  4) Use a basically continuous full length piano type hinge made out of aluminum, but cut it a number of times during its length into shorter than full length segments.
 It might be sufficient to cut it once only a few inches away from the center.
 It might also be enough to cut just the rod into two pieces with an insulator between them
 You might also try bonding both sides of the hinge to airframe ground. Well. . . that doesn't mean connecting it to the fiberglass. The idea is to move the resonance to longer wavelengths by making the hinge electrically longer as opposed to cutting it to make it shorter.
 And the # 10 thought. . . . Remove the dipole antenna and put a BNC connector on the hinge.
 --> If  it's not  on  fire  it's  a  software  problem. <--
				 Posted: Mon Oct 23, 2006 5:20 pm    Post subject: antenna interference |
				Robert L. Nuckolls, III wrote:
  <nuckollsr(at)cox.net>
 > 10/23/2006
 > Electronics comm antenna in
 > antenna is a straight one piece dipole with balun in  center.
 > hinge for the rudder.
 > reception was practically nonexistent.
 > a (nearly continuous) hinge solution that will permit adequate
 > transmission and reception. Various solutions have been proposed:
 > makes them).
 > of carbon fiber, but cut it a number of times during its length into
    or shorter.
 Or, he could break the AL hinge once in the middle & use it as the dipole.
 (I haven't even stayed in a Holiday Inn recently; please don't take this
 seriously.)
				 Posted: Tue Oct 24, 2006 5:27 am    Post subject: antenna interference |
 seriously.)
    Actually, I considered that too . . . and it's quite doable. However,
    it takes some time and understanding to do the system integration.
    We have HF antennas on the bizjets that depend on certain structural
    characteristics to be in place for optimum performance. Because
    the HF system was an accessory added some 30 years after the
    airplane was designed, there's no symbiotic relationship possible
    between structure and antenna. The structure becomes as much an
    "antenna" as the intended radiator wreaking havoc on numerous
    on-board systems.
    In this case, the proposed hinge-dipole is probably doable
    within limits for structural integrity needed for keeping the
    rudder attached!
    Can the hinge be 40" or longer?
    Bob  . . .
