bakerocb
Posted: Mon Oct 23, 2006 10:44 am Post subject: antenna interference |
10/23/2006
Hello Bob Nuckolls and other antenna experts,
Some time ago a fellow builder installed an Advanced Aircraft Electronics
comm antenna in
the vertical stab of his composite (fiberglass) airplane. The antenna is a
straight one piece dipole with balun in center.
The reception was tested with a radio and found to be excellent. In
attaching the rudder, a full length aluminum piano style hinge was
installed. This is one of the builder's modifications to the original plans
that called for separate short segments of aluminum piano type hinge for the
rudder.
When testing the reception again with the same transmitter the reception was
practically nonexistent.
The builder would like to retain use of the antenna and come up with a
(nearly continuous) hinge solution that will permit adequate transmission
and reception. Various solutions have been proposed:
1) Use a continuous piano type hinge made out of plastic. (Guden makes
them).
2) Use a continuous piano type hinge made out of carbon fiber.
http://www.carbinge.com/index.html
3) Use a basically continuous full length piano type hinge made out of
carbon fiber, but cut it a number of times during its length into shorter
than full length segments.
4) Use a basically continuous full length piano type hinge made out of
aluminum, but cut it a number of times during its length into shorter than
5) Abandon the continuous hinge concept and install separate short segments
of metal hinge as the plans call for.
We would appreciate your inputs and advice. Thanks.
OC
nuckollsr(at)cox.net Guest
Posted: Mon Oct 23, 2006 11:25 am Post subject: antenna interference |
At 02:41 PM 10/23/2006 -0400, you wrote:
Quote: |
10/23/2006
comm antenna in
a straight one piece dipole with balun in center.
plans that called for separate short segments of aluminum piano type hinge
for the rudder.
was practically nonexistent.
Hmmmm . . . "adequate" is the operative word here. Without
laboratory data on the effects of current configuration and
any hypothesized solutions will be hip-shots . . .
Quote: | 1) Use a continuous piano type hinge made out of plastic. (Guden makes them).
As a structural part of the airplane?
I presume the rest of the structure is carbon fiber also. This
solution is relatively attractive but know that carbon fiber
while not an excellent conductor . . . it's also very unfriendly
to RF propagation. At least the hinge material would not be any
worse than structural components around it
Quote: | 3) Use a basically continuous full length piano type hinge made out of
Cutting a carbon fiber hinge would produce minimal
benefit once the shift from aluminum to carbon fiber is made.
Quote: | 4) Use a basically continuous full length piano type hinge made out of
This works . . . when driving past AM station towers
(tower itself is the antenna) one observes that guy wires
are broken up into short segments by strain insulators.
The rule of thumb is that a parasitic conductor's length
should not exceed 1/10th wavelength at frequency of interest.
In the case of VHF Comm, about .2 meters or 8 inches in length
or shorter.
Quote: | 5) Abandon the continuous hinge concept and install separate short
segments of metal hinge as the plans call for.
That works too . . . but probably no better than segmented
hinges of other materials.
douglist(at)macnauchtan.c Guest
Posted: Mon Oct 23, 2006 12:49 pm Post subject: antenna interference |
At 14:41 -0400 10/23/06, <bakerocb(at)cox.net> wrote:
Quote: | 4) Use a basically continuous full length piano type hinge made out of aluminum, but cut it a number of times during its length into shorter than full length segments.
It might be sufficient to cut it once only a few inches away from the center.
It might also be enough to cut just the rod into two pieces with an insulator between them
You might also try bonding both sides of the hinge to airframe ground. Well. . . that doesn't mean connecting it to the fiberglass. The idea is to move the resonance to longer wavelengths by making the hinge electrically longer as opposed to cutting it to make it shorter.
And the # 10 thought. . . . Remove the dipole antenna and put a BNC connector on the hinge.
--> If it's not on fire it's a software problem. <--
Posted: Mon Oct 23, 2006 5:20 pm Post subject: antenna interference |
Quote: |
<nuckollsr(at)cox.net>
> 10/23/2006
> Electronics comm antenna in
> antenna is a straight one piece dipole with balun in center.
> hinge for the rudder.
> reception was practically nonexistent.
> a (nearly continuous) hinge solution that will permit adequate
> transmission and reception. Various solutions have been proposed:
> makes them).
> of carbon fiber, but cut it a number of times during its length into
or shorter.
Or, he could break the AL hinge once in the middle & use it as the dipole.
(I haven't even stayed in a Holiday Inn recently; please don't take this
seriously.)
Posted: Tue Oct 24, 2006 5:27 am Post subject: antenna interference |
seriously.)
Actually, I considered that too . . . and it's quite doable. However,
it takes some time and understanding to do the system integration.
We have HF antennas on the bizjets that depend on certain structural
characteristics to be in place for optimum performance. Because
the HF system was an accessory added some 30 years after the
airplane was designed, there's no symbiotic relationship possible
between structure and antenna. The structure becomes as much an
"antenna" as the intended radiator wreaking havoc on numerous
on-board systems.
In this case, the proposed hinge-dipole is probably doable
within limits for structural integrity needed for keeping the
rudder attached!
Can the hinge be 40" or longer?
