dual sticks in 601XL
Goto page 1, 2  Next
waj(at)quik.com
PostPosted: Sat Sep 30, 2006 12:01 pm    Post subject: dual sticks in 601XL Reply with quote
Hello group ,I have a question . Is it worth the effort to add dual control sticks to this design .What are your thoughts pro & con on this issue . Thanks Wade Jones
bryanmmartin
PostPosted: Sat Sep 30, 2006 12:16 pm    Post subject: dual sticks in 601XL Reply with quote
I wasn't worth the effort to me. It didn't  take any time at all to get used to the center Y stick even though I had always flown aircraft with a control yoke before. The center stick also makes it easier to get in and out of the plane. I find it no trouble to change hands on the center stick to adjust radios and such. The dual sticks will be heavier and more complicated also.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
Bryan Martin
do not archive.
dredmoody(at)cox.net
PostPosted: Sat Sep 30, 2006 1:08 pm    Post subject: dual sticks in 601XL Reply with quote
I am using the dual stick option. I found it awkward in the demo plane to change hands to check my ability to reach across the panel with the inboard side hand. I'm sure it would not be a deal breaker either way. With dual sticks the center console area is freed up for the placement of fuel selector valve, switches, whatever.
Ed Moody II
Sigmo(at)aol.com
PostPosted: Sat Sep 30, 2006 1:11 pm    Post subject: dual sticks in 601XL Reply with quote
I went with the dual sticks because I am used to that configuration and like to fly with it.
I have flown both configurations and prefer the stick although there are some disadvantages.
Some of the drawbacks to the dual sticks on this aircraft are:
The loss of foot space in front of the pilot and passenger.
It is harder to enter and exit the aircraft.
The wiring and placement of some items require much more thought.
The seats must be configured for the sticks.
The stick interferes with the passenger seating comfort.
It is harder to carry cargo in the passenger seat without interfering with the stick.
Some of the advantages of the dual stick are:
The console area can be configured for instruments and other items.
The right hand is free to set radios and other instruments. The right hand is free to write.
The aircraft can be flown with the left hand when you wish.
The stick can be configured with switches that can be operated with either hand.
I personally find it easier to fly with the stick than the center control.
The legs can also be used when necessary.
My two cents worth.....
Mike Sigman
N7092N 601XL
Jaybannist(at)cs.com
PostPosted: Sat Sep 30, 2006 1:20 pm    Post subject: dual sticks in 601XL Reply with quote
Wade, I actually held off starting the Zodiac until they offered dual sticks. I am not a mancho "left hand on throttle, right hand on stick" type. I learned in your everyday spam can, with my right hand on the throttle and left on the yoke. Beyond that, my other problem with the center stick is that I am right handed.  I could not envision grabbing the stick with my left hand in order to write something down (with my right hand) and I can't write with my left hand.
That's my 2 cent's worth, Jay in Dallas, working on XL canopy [quote][b]
craig(at)craigandjean.com
Well, I'm doing it for a few reasons:
- it mimics the planes I have trained in (172, Katana, Evector, 601XL): left hand on the stick, right on center throttle.
- all the 601xls that I have seen that have been purchased for flight instruction have dual sticks. So if you need time in an XL before flying yours you will probably need to use dual sticks
- I am right-handed and wanted that hand free for things that require manual dexterity: writing, fiddling with the GPS, radio, transponder, microwave over, etc.
Certainly the center Y stick is a cleaner design. Others will say that it is not a big deal to grab the Y stick with your left hand to temporarily free your right for other tasks.
-- Craig
PostPosted: Sat Sep 30, 2006 1:23 pm    Post subject: dual sticks in 601XL Reply with quote
One way to address some of these problems is to make the upper portion of the passenger-side stick removable.
-- Craig
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Sigmo(at)aol.com
Sent: Saturday, September 30, 2006 3:11 PM
Subject: Re: Zenith-List: dual sticks in 601XL
Mike Sigman
N7092N 601XL
p.mulwitz(at)worldnet.att
PostPosted: Sat Sep 30, 2006 2:40 pm    Post subject: dual sticks in 601XL Reply with quote
I was surprised to hear so many listers say they didn't like the center stick because they couldn't write left handed. I haven't flown my XL yet, but it seems to me there are two obvious answers to this particular problem. First, you could configure the plane to fly from the right seat. OK, I realize this is sacrilege, but it would allow the left hand on stick, right hand on throttle.
The more obvious answer is that when the plane is properly trimmed up you should be able to let go of the controls long enough to adjust the radios or write something down. Is there some reason this doesn't work?
Paul
XL fuselage
Paul Mulwitz
32013 NE Dial Road
Camas, WA 98607
Tim Juhl
PostPosted: Sat Sep 30, 2006 3:25 pm    Post subject: Re: dual sticks in 601XL Reply with quote
All the opinions I've read are good and worthy ones. In my case, as a CFI I'm used to switching hands and going between wheels and sticks and having to stretch across the cockpit to reach things. For most of my career I owned a Cessna and an Aeronca Champ (still have the Champ.)
I chose to go with the center stick for 1.) Simplicity 2.) Comfort (nice armrest leading up to the stick instead of curling your hand in your lap.)
3.) Easier entry and exit. To deal with the other issues I will simply design my panel for easy placement of controls (and duplicate some on the right) and install a single axis autopilot to do the flying when I need my hands or am otherwise engaged. Anyone who has flown single pilot IFR and tried to copy clearances, twist radios and the like while in IMC knows the value of an AP. If you don't want an AP, remember the "poor man's auto pilot" (rudder pedals) which can be used to keep the wings level on an otherwise properly trimmed AC.
In the end, there is no best choice..... just go with what works for you.
Tim Juhl
______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring!
zodierocket(at)hsfx.ca
PostPosted: Sat Sep 30, 2006 3:33 pm    Post subject: dual sticks in 601XL Reply with quote
Paul there is no reason whatsoever, Chris Heintz designed the center stick and for nearly 22 years it has been nothing short of a great system. It is truly the best way to fly the 601 of any series. However, many who have never flown with the system wanted something more conventional as dual leg smackers or if you have wet shoes then they are called ball breakers. If you’re panel is laid out properly then in the first and last 1000ft everything you need can be accessed by your left hand. If you need to write down information then I sure hope you got it before you entered the circuit like you’re supposed to a properly trimmed Zodiac can fly for large amounts of time hands off. It is funny anyone who has built there second Zodiac still retains the “Y” stick and any seasoned 601 owner can easily modify the system to a dual stick but never seem to. All arguments over changing from a “Y” stick configuration are simply those who are afraid to get used to something different. But it is a personal choice, and to each there own The 601’s in Canada owned by Flypass were used for a great many years as flight training planes and retained the Y stick plus when many of those students built there own planes they didn’t install a dual stick configuration either. This is not an argument, I won’t have a dual stick setup in my plane, it is a personal decision and preference, amazingly enough I find the Y stick more social then a dual stick ( never could figure that one out but it is true to me anyways). Any debate of one being better then the other is totally false and wrote with personal preference. Below is an early picture of my panel for the 601XL. Let the scotch bright pads fly !! Remember I did say personal preference !
Mark Townsend Alma, Ontario
Zodiac 601XL C-GOXL, CH701 just started
www.ch601.org / www.ch701.com/ www.Osprey2.com
-----Original Message-----
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Paul Mulwitz
Sent: Saturday, September 30, 2006 6:37 PM
Subject: Re: dual sticks in 601XL
Paul
XL fuselage
At 01:00 PM 9/30/2006, you wrote: <![if !supportLineBreakNewLine]> <![endif]>
Paul Mulwitz
32013 NE Dial Road
Camas, WA 98607
  - The Zenith-List Email Forum - -->   - NEW MATRONICS WEB FORUMS - -->   - NEW MATRONICS LIST WIKI - -->   - List Contribution Web Site - Thank you for your generous support!     -Matt Dralle, List Admin. -->
 Filesize:  54.01 KB
 Viewed:  636 Time(s)
 Filesize:  63.59 KB
 Viewed:  645 Time(s)
PostPosted: Sat Sep 30, 2006 5:18 pm    Post subject: dual sticks in 601XL Reply with quote
Which is what I plan to do also.
Ed Moody II
David X
PostPosted: Sun Oct 01, 2006 2:26 pm    Post subject: Re: dual sticks in 601XL Reply with quote
Yes you can trim it, but the stick is so sensitive that you really can't swap hands without some sort of jiggle. Also, the act of reaching across my body with my left hand to operate the radios will shift my body and the pressure on the stick. It's just a touchy affair.
If ATC calls you while your left hand is on the yoke, right hand on radio ... forget what you were doing because trying to push on the TX button with left hand is ridiculous. I lost track of how many times I pushed on the trim button instead and put the plane in a dive.
The center stick is just plain annoying, period. I've gotten used to it, but still don't like it.
Zodiac 601 XL - CZAW Built - Rotax 912S
DO NOT ARCHIVE
PostPosted: Sun Oct 01, 2006 2:47 pm    Post subject: dual sticks in 601XL Reply with quote
And all this "switching hands" business assumes that you only need your
right hand in a non-emergency situation (trimmed, straight, level, etc).
Almost all the fuel selectors I have seen on XLs are on the center console.
So you stupidly run a tank dry in some critical situation - no problem! Just
reach across in front of the stick with your left hand to turn the selector.
Or just switch hands and reach around or over the center stick to the tank
selector. I know - use the same solution used in the throttle - dual fuel
selector valves. Hmm, no thanks. Having climbed in and out of 601s with dual
and center sticks I think I'll bolt on my dual sticks.
-- Craig
waj(at)quik.com
PostPosted: Sun Oct 01, 2006 3:55 pm    Post subject: dual sticks in 601XL Reply with quote
I thank everyone who replied to my question on the dual sticks .Lots of comments on both styles .I am not at the point where I have to make up my mind anytime soon .At present I still have not decided ,lots of pros & cons .I think that as far as building is concerned I would prefer to keep it simple as in the plans .As far flying I would probably feel more at home with the dual sticks . Thanks again for your support . Wade Jones
PostPosted: Sun Oct 01, 2006 7:16 pm    Post subject: dual sticks in 601XL Reply with quote
Is it true that the seats have to be modified for the dual sticks? It wa my
impression that the dual sticks had been designed to fit the existing cabin
space (pardon my ignorance but I have not reached that point yet).
If so, does the modification also involve the seat upholstery?
If it does, will the upholstery option package from Zenith be dual stick
compatible or am I in a bind here?
Anyone been here and done that?
Ed Moody II
PostPosted: Sun Oct 01, 2006 7:55 pm    Post subject: dual sticks in 601XL Reply with quote
I wondered the same thing. I sat in Bob Archibald's XL (Dragonfly Aviation)
and ran the stick to all four extremes, shooting a movie with my digital
camera. It will hit the seat if pulled way back. But after flying the plane
I saw how sensitive the controls were. If you pulled the stick back a
quarter of that distance you would (with enough power) loop the plane.
The whole movie is 7.6 megabytes. If anyone wants it, let me know and I will
e-mail it to you.
-- Craig
 Filesize:  17.92 KB
 Viewed:  569 Time(s)
 Filesize:  16.53 KB
 Viewed:  570 Time(s)
Rmtnview(at)aol.com
PostPosted: Sun Oct 01, 2006 8:07 pm    Post subject: dual sticks in 601XL Reply with quote
I'd like a copy of that video please. Rog
rmtnview(at)aol.com (rmtnview(at)aol.com)
In a message dated 10/1/2006 11:57:03 P.M. Eastern Standard Time, craig(at)craigandjean.com writes:
e-mail it to you.
-- Craig
PostPosted: Sun Oct 01, 2006 8:26 pm    Post subject: dual sticks in 601XL Reply with quote
I'm sending the movie in a second message. Hopefully it won't be rejected by your mail server as too large. Let me know if you don't get it in 15-30 minutes.
-- Craig
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Rmtnview(at)aol.com
Sent: Sunday, October 01, 2006 10:07 PM
Subject: Re: Zenith-List: Re: dual sticks in 601XL
e-mail it to you.
-- Craig
Sigmo(at)aol.com
PostPosted: Sun Oct 01, 2006 9:07 pm    Post subject: dual sticks in 601XL Reply with quote
The stick movement in actual flight is very small but to get full movement the seat cusion needs to be relieved the same as an RV or other similar dual stick aircraft.
Mike Sigman
N7092N
 Filesize:  51.38 KB
 Viewed:  556 Time(s)
PostPosted: Sun Oct 01, 2006 10:19 pm    Post subject: dual sticks in 601XL Reply with quote
If you look through AMD's photo gallery you will see many pictures of dual-stick planes they have built without cut-outs in the cushions.
www.newplane.com/amd/amd/601_SLSA/photo_gallery.html
-- Craig
Goto page 1, 2  Next
Page 1 of 2
