john(at)leptron.com Guest
Posted: Sat Aug 19, 2006 10:37 am Post subject: tail wheel |
Hi Guys,
While we are still on the tail wheel thing, I would like to say that the best single item I replaced in 1000 hours in fox’s was the tail wheel. I went to a matco pneumatic wheel last year and can say that is as close to a easy and straight run out I have ever had. Any one else change things?
John Oakley
lcfitt(at)sbcglobal.net Guest
Posted: Mon Aug 21, 2006 12:21 pm Post subject: tail wheel |
John, I went to the Homebuilders special dual fork. I like it.
Lowell
mike Guest
Posted: Mon Aug 21, 2006 1:20 pm Post subject: Re: tail wheel |
About 750 hrs on the fox and I can't say I've done much to the tail wheel other than look at it, day in and day out. Although I will say I need to be careful with the tail at the big airport, seems the lights down the center and on the sides like to give the tail wheel a good bounce if I hit one. My skill has to come in so that I land just to the left of center about a foot and that puts it just about right to miss both the light in the center and on the left. If I hit the lights on the left they make the airplane move just a little hitting the main wheel.
Posted: Mon Aug 21, 2006 1:52 pm Post subject: tail wheel |
Lowell,
I also had my CAP rebuilt with the new hub last winter and it is much
smoother that ever. Works way better.
| Quote: | Hi Guys,
best single item I replaced in 1000 hours in fox's was the tail wheel. I
a
John Oakley
Posted: Mon Aug 21, 2006 3:36 pm Post subject: tail wheel |
Lowell,
The tail wheel you used was the one I really wanted, but, no one had them
when I bought. I am not unhappy with the matco though.
I am looking at buying a new set of mains and have seen some from Italy and
grove also, any one else try something different?
Lowell
| Quote: | Hi Guys,
a
John Oakley
ruebd(at)skymail.csus.edu Guest
Posted: Tue Aug 22, 2006 9:18 am Post subject: tail wheel |
John:
I fly in and out of hard surfaced runways primarily, so am not
blessed with the forgiveness that grass can give, which usually allows
more side slip to the mains than does a rough asphalt, which is quite
grabby, and not inclined to give a pilot a break, or should I say it is
inclined to cause a break in the intended straight, forward path. I
have been thinking that a larger tailwheel rolling radius, together with
the resilience of a pneumatic tire that is not a continuous, hard edge,
could very well cause the whole system to have better manners.
Your thread is the first confirming input that I have had on
this topic, and I am encouraged by it. I assume that you previously
were using a smaller diameter, hard rubber tired assembly similar to
mine.
Thanks, Duane Rueb
Posted: Tue Aug 22, 2006 10:02 am Post subject: tail wheel |
Duane,
My original tail wheel was the maule, yuk, I would never fly one again. My
matco looked funny when first installed but I sure do love it. You are right
about the larger and narrow tread.
john
Posted: Thu Aug 24, 2006 9:15 am Post subject: tail wheel |
For those that asked, the matcomfg.com tail wheel I installed on my fox, is a WHLT-8 PNEU. It still shows up as 217.72 dollars from them. It showed up in 2 days.
John Oakley
jleathem(at)cogeco.ca Guest
Posted: Sat Aug 26, 2006 8:32 am Post subject: tail wheel |
We have been flying a IV in SW Ontario out of a grass strip for about 6 years now. After going through a period of groundloops, none of which thankfully damaged the plane, we eventually removed the full castoring function from the tail wheel and replace the springs to the rudder with compression springs. We have never had a ground loop in the 2 years since but we do need to devise a manual method to disengage the tail wheel tracking and restore full castoring for handling the plane in the hangar and on the ramp. The plane now tracks straight on the grass on landing without a lot of rudder input and x-winds are not a problem. However, she is still definitely twitchy on paved surfaces regardless of the wind conditions and we need to be very alert and very quick but smooth on the rudders to avoid exciting roll-outs. Result is where I have the option at an airfield, I will land on grass with a x-wind rather than in to wind on pavement.
J. Trevor Leathem
Oakville, Ontario
dave(at)cfisher.com Guest
Posted: Sat Aug 26, 2006 8:58 am Post subject: tail wheel |
Trevor,
I have a IV in Ontario as well and my tailwheel locks straight ahead and I also has the compression springs. Mine will breakway on turns unless you don't grease it often then it becomes hard to break free.
I had to fly in a strip this morning to do some service for a guy.I landed on his runway 17 on grass wind 100 (at) 9 knots, when I left it was 13 gust 18 knots 090 and when i took off the tailwheel has no tendacy to kick out on the TO roll at all.
Dave
mike Guest
Posted: Sat Aug 26, 2006 11:29 am Post subject: Re: tail wheel |
this is the best pic of my wheel, not sure what it is, but it works great. Just for a tip, on landing with a tail wind, I know somebody mentioned having troubles doing such a thing. When I land with the wind at my back, you fly in as normal, don't slow up more, cause the landing speed will be faster, you maintain normal glide and decent and when your ready to flair, put in an extra amount of power, just a little, cause if you don't, chances are you will drop out about 5 ft off the ground, at least in my plane you do. Another thing, be ready on the rudder, cause your going to be a little faster than normal on the roll out, so correct as soon as it's needed.
524.48 KB |
472 Time(s) |
