eskflyer(at)lvcisp.com Guest
Posted: Wed Aug 09, 2006 7:41 pm Post subject: Flying without doors |
many very fun and exciting hours flying with them0 open and or off the plane .A lot of times I will take off then after climb out0 open doors and let them fly in the breeze then before landing shut them . I have0 also landed with them open I do not have the gas struts on them so therefor they0 start to shut when slowing down in the rollout .
Fly safe fly low fly slow
John Perry
Kitfox 2 N718PD
582 c box /GSC 3 blade
DO NOT ARCHIVE
7suds(at)Chartermi.net Guest
Posted: Wed Aug 09, 2006 7:50 pm Post subject: Flying without doors |
My experience flying with doors open in a Kitfox 4, my 10 year old son and I
did a short x-country a few years back. We stopped for lunch in Wisconsin,
landing was front left quartering x-wind 18 gusting to 22. I told my son to
eat light because it was going to be a bumpy ride home, just in case right
before we left I told him if he felt sick to pop the door open and let it
fly. About 1/2 way home at 4K feet and cruising 70, with no warning he
slipped his mic up on his headset, popped open the door and commenced to
hang out on the ends of the shoulder harnesses and let it fly. He then
gently rolled back in, slid his mic down and asked if I could get the door
for him, I did so (Had pull straps mounted on the center bar of the door).
We got home and his mom asked how the trip was, he said OK. The next day we
had some cleanup to do on the tail of the plane. Flying with doors open and
opening and closing in flight was no problem at the speeds my plane was
capable of. My door latches were twist latches at the bottom of the doors
so I made an extension that would allow me to either latch the door
completely closed or latch about 1/2" open, made for a nice breeze not to
much.
Lloyd
darinh
Posted: Wed Aug 09, 2006 7:56 pm Post subject: Re: Flying without doors |
Steve,
The bubble doors are the only way to go on a Fox! They add about 3" of shoulder room on each side and they give incredible visibility. You can get them from John McBean at kitfoxaircraft.com or direct from lpaero.com. The shipping is not cheap (neither are the doors) so be prepared. I just ordered a pair for my Series 7 and the doors were $217 each and shipping was $87! They are worth it in my mind. Below is a picture of my model III (not mine anymore...sold it).
Darin
254.38 KB |
530 Time(s) |
smokey_bear_40220(at)yaho Guest
Posted: Wed Aug 09, 2006 8:45 pm Post subject: Flying without doors |
Just some theoritical thoughts on - no turtledeck:
You stand the chance of turning the tail of your plane
into a big windsock, depending on the security of your
cargo compartment.
You can add a lot of turbulence to the tail and reduce
controlability.
You would probably lose 10-15% of your lift.
That would draw a lot of air thru the cockpit and put
more pressure on the windscreen. It could be very
windy inside.
Don't think you would like it on purpose, but you
could get home if it happened by mistake, long as it
didn't jamb in the tail somewhere.
Kurt S.
--- Randy Daughenbaugh <rjdaugh(at)rapidnet.com> wrote:
| Quote: | Wing nut,
I fly my series 5/7 with doors open. But I do try
to limit speed to about 85 mph.
There was a caution on the list a while back to NOT
fly without the turtle
deck. I don't have any experience with this, but
can believe that is not a good idea.
Randy
Posted: Wed Aug 09, 2006 9:02 pm Post subject: Flying without doors |
And then Lloyd said:
| Quote: | ..."so I made an extension that would allow me to
either latch the door completely closed or latch about
1/2" open, made for a nice breeze not to much."
It crossed my mind that you could add a snap strap, or
velcro strap to the bottom of the door and let it open
only a few inches in flight, if you want. Whatever
amount necessary for a nice breeze without it having
to be all or nothing.
Attach the strap to the door and the loose end to
another spot up the door frame when not in use. Add a
fastener to the front, bottom door sill or some other
convienent place and attach the end of the strap there
before you unlatch the door in flight. Let the strut
hold it out against the strap.
Now you've got big controllable vents without much
weight or hardware! No broken door glass from cracked
vent holes either.
Thanks Lloyd
Kurt S.
n981ms(at)yahoo.com Guest
Posted: Thu Aug 10, 2006 4:46 am Post subject: Flying without doors |
A couple of other things I just thought of and have not seen mentioned:
1. Opening and closing in flight has been no problem for me. Just open and close normally. Feels a little different but works just the same. No side slips or skids requierd to open or close.
2. If you land on a wet surface the stuff that normally spins off the tire onto the wing will be on the inside of your door.
3. I have slipped to a landing with both doors open. Probably will not again after hearing the suggestion about the turtle deck blow out. Certainly will not slip an open door into the wind with the opposite door closed.
Maxwell S6/TD/IO240
Lowell Fitt <lcfitt(at)sbcglobal.net> wrote:
[quote]--> Kitfox-List message posted by: "Lowell Fitt"
This post brings to mind a flutter I had early this year. I attributed it
to weak gas struts. I ordered new ones and for the one most often open -
mine, I ordered a stronger strut. No problems since.
Lowell
av8rps(at)tznet.com Guest
Posted: Thu Aug 10, 2006 6:12 am Post subject: Flying without doors |
Regarding removing the turtledeck;
I would NEVER fly a Kitfox (or Avid) with the0 turtledeck removed. By removing it you have just eliminated the top0 half of the bearing surfaces that hold your flaperon in place. That means0 your flaperon is now going to be able to move up and down in flight. 0 That is really bad because it could create flutter in the flaperon itself. 0 And if that happens with enough speed you could also cause wing damage. In0 a worse case scenario wing separation...(yikes!) I don't know about you,0 but I don't need that much fresh air...
Regarding doors open in flight;
My float equipped Model IV with LP Aero bubble0 doors does not act like my old Avid Flyers or older Kitfoxes with the0 undercambered airfoil and the less bubbled doors do. The early0 airplanes flew just fine with the doors open or closed, or removed0 completely. In summer I rarely flew with doors0 closed. My Kitfox IV on the other hand needs to be slowed down to 800 mph or less in order to open the doors without them slamming up against the0 bottom of the wing (causing not only potential door glass damage,0 strut damage, and door frame twisting, but also the glass rubbing against the0 bottom of the wing fabric effectively scuffs [sands] the door0 glass). So I do not fly with the doors open on my Kitfox at this0 time. To correct this concern I am going to make a bracket that is0 held in place by the wing tank fuel drain fitting, that will let the0 door rest against it (probably will have a rubber pad where it touches0 the glass) when the door is completely open. Maybe it's just my Kitfox,0 but I thought I would share this with the group should someone else experience0 the same problem.
If my attachments go through (?), here are two0 photos that show how the bubble doors fit when full open against0 the bottomside of the laminar flow Riblett wing. The bubbles0 definitely limit your ability to get them up against the wing0 bottom.
213.5 KB |
503 Time(s) |
224.56 KB |
478 Time(s) |
Posted: Thu Aug 10, 2006 7:29 am Post subject: Flying without doors |
On the subject of fresh air;
The NACA scoops on the side of my cowl (see pics in0 previous post) really provide a lot of fresh air. So much in fact they0 will blow papers around in the cockpit if not stowed. And I don't mean a0 little, but a lot! A couple of days ago I had to retrieve a map from the0 back turtledeck area that was blown back there after I set it down on the0 passenger seat while flying. Even in the 97 degree 97% humidity0 weather we endured here in Wisconsin this summer, I was generally able to0 stay cool. (yes, I just had to go flying when it was that hot. I0 wanted to see how well my fox would perform off the asphalt, as well as the0 water under those conditions. I was pleasantly surprised...)
Opening the doors a half inch or so does seem0 to be an easy way to get a lot of fresh air, but overall I've found the0 NACA scoops to be equally effective. Not only do they give0 you a lot of air, but they blow it right on you. So if you are0 still building, or are considering modification, I highly recommend putting them0 in.
On a last note; A friend of mine with a model0 III Kitfox installed the rotating scoops that fit in the lexan. But he0 installed his on top of the cabin (right in the windshield lexan) right above0 the front carry through tube. Being they pointed directly into the0 slipstream, they worked well also. And if he didn't want them he just0 turned them backwards, or pulled them in altogether, closing them0 off. Just another idea. Would be an easy modification to any0 existing airplane.
Paul Seehafer
Model IV 912ul on Aerocet0 Amphibs
occom(at)ns.sympatico.ca Guest
Posted: Thu Aug 10, 2006 7:54 am Post subject: Flying without doors |
HI Paul. My IV has no static air system and I0 wonder about the high volume of air through the NACA vents affecting the instruments. Any experience?
Wilson(at)REinfo.org Guest
Posted: Thu Aug 10, 2006 8:45 am Post subject: Flying without doors |
Any contact info for L/P areo plastics?
Steve Wilson
darinh
Posted: Thu Aug 10, 2006 9:11 am Post subject: Re: Flying without doors |
www.lpaero.com
Click on the "Contact us" link and scroll down to the bottom. They have their phone numbers listed in the address in the middle of the page.
Darin
jdmcbean(at)cableone.net Guest
Posted: Thu Aug 10, 2006 9:33 am Post subject: Flying without doors |
Actually you can get them from us.... Model IV Clear are $217 ea. plus
shipping....
Fly Safe !!
John & Debra McBean
www.kitfoxaircraft.com
"It's not how Fast... It's how Fun!"
AMuller589(at)aol.com Guest
Posted: Thu Aug 10, 2006 9:38 am Post subject: Flying without doors |
I find that just the rotating vent on the lower part of the clear windo is0 sufficient in Houston, year round. Cheap simple reliable and water/rain0 proof.
Michel
Posted: Thu Aug 10, 2006 10:28 am Post subject: Flying without doors |
On Aug 10, 2006, at 5:53 PM, Dave G. wrote:
| Quote: | HI Paul. My IV has no static air system and I wonder about the high
experience?
Here is something very strange, Dave. My Kitfox 3 had also the NACA
vents and no static port. I didn't notice a difference with the vents
open. But one and half year ago, I installed a Jabiru (had a 582
before) and because of the Jabiru need for proper air cooling under the
cowling, and my extensive modification of the cowling, when I tested
the engine, I noticed a strong depression in the cockpit as, on the
ground, after setting the altimeter to QNH, I was ... above the
airfield. So I installed a static port going all the way back to the
tail and it is fine now. But I don't understand why the low pressure
since my firewall should be airtight.
Michel
Float Flyr
Float Flyr
Posted: Thu Aug 10, 2006 4:46 pm Post subject: Flying without doors |
Paul:
That's a very nice plane you0 have there. I was wondering about your prop. It looks like an0 Ivo. Is it in-flight adjustable?
I have the Aerocet straight0 floats on my 582 B box powered mod III-A. They are a hard act to follow on0 the water. I haven't tried the Full Lotus floats yet but I can't see0 how they would handle better on the water than the Areocets. I would love0 to have the amphibs. If you ever decide to sell those floats keep me in0 mind.
Noel [quote]
119.13 KB |
479 Time(s) |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Posted: Thu Aug 10, 2006 5:13 pm Post subject: Flying without doors |
John: do you have them for the model III?
Noel
[quote] --
Kitfox III-A
dave(at)cfisher.com Guest
Posted: Thu Aug 10, 2006 5:35 pm Post subject: Flying without doors |
Paul,
I fly with left door open lots and here is what i0 find ( also for the record I have the bowed doors with lexan but no bubble0 windows)
I lose a few mph in cruise and I say alot cooler on0 hot days.
My ASI reads lower that with door shut as I have no0 external static port.
My Left door at times opens on take off and0 in flight but really no big deal - ( if you have not experienced this,0 than you should as if is the cause of a quite a few accidents0 yearly. )
I will slip with out issues with door open or shut0 although the door does come unlatched at times from the fully open position and0 will hang in wind and even close at times. I do not have gas0 struts.
I would like to add a few points on turtle decks0 that I have seen. And none have blown off but I think it would be0 possible. On some after market turtledecks that I have seen 0 they have lacked an upper and lower bearing support for the flapperon horn (I0 hope this is the right word) I wold think that this bearing is very0 critical in ensuring that the horn is supported. With out that0 support could the flapperon horn come lose from the flapperon? 0 If so a flutter " could result" and could cause alot of control issues as0 well as wing failure.
Dave
KF IV
MichaelGibbs(at)cox.net Guest
Posted: Fri Aug 11, 2006 12:12 am Post subject: Flying without doors |
Paul sez:
| Quote: | By removing it you have just eliminated the top half of the bearing
surfaces that hold your flaperon in place. That means your flaperon
I don't know what model Kitfox you have, Paul, but that certainly
wasn't true of mine. My Model IV Speedster simply had a slot cut
into each side of the turtle deck to allow the flaperon horn to pass
through. The flaperons were completely supported by the wing
brackets and moved just fine with or without the turtle deck in place.
That said, there are plenty of other reasons not to attempt flight
Mike G.
N728KF
Lynn Matteson
Posted: Fri Aug 11, 2006 4:28 am Post subject: Flying without doors |
Or if like me, you taxi with the door open early in the morning on a
grass strip, the little living creatures that get spun up from the
tires wedge into the door tube/ window junction and are a bear to clean
out. One more reason to finish painting the wheel pants and get them on.
Lynn
On Thursday, August 10, 2006, at 08:45 AM, W Duke wrote:
| Quote: | 2. If you land on a wet surface the stuff that normally spins off the
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
