Mudfly
Posted: Wed Apr 26, 2023 3:54 pm Post subject: Re: Which Oil Pressure Switch? |
Will do Bob. I'll try and get that set up tomorrow and post what I find.
Thanks.
Shawn
Shawn,
Could you set this hourmeter up on the bench
and measure the current draw on the enable
pin in the pull-up configuration? I think
I have a simple solution using p-lead
signal from a mag to drive the enable pin
but having that current value would facilitate
optimization of the components.
(o o)
===========o00o=(_)=o00o=========
<Go>
< show me where I'm wrong. >
In the interest of creative evolution
of the-best-we-know-how-to-do based
on physics and good practice.[/quote]
argoldman(at)aol.com Guest
Posted: Wed Apr 26, 2023 5:27 pm Post subject: Which Oil Pressure Switch? |
Whatever you choose for a transducer for any liquid pressure, make sure you install a restrictor in line to prevent major fluid loss in case of physical sensor leakage or breakage.
| Quote: | On Apr 26, 2023, at 6:54 PM, Mudfly <shawntedwards(at)hotmail.com> wrote:
Thanks.
Shawn
Shawn,
(o o)
on physics and good practice. |
http://forums.matronics.com/viewtopic.php?p=510710#510710
[/quote]
Mudfly
Posted: Thu Apr 27, 2023 4:41 pm Post subject: Re: Which Oil Pressure Switch? |
Ok Bob here's what I did to check the hourmeter.
I connected a power supply to the positive and negative pins on the
hourmeter. This illuminated the LCD digits but elapsed time was not recorded. I then added the enable pin to the positive lead from
the power supply and elapsed time began recording.
Unfortunately, I was unable to measure any current draw with the
equipment I have. Probably too low I guess?
The placard on the hourmeter says 1/2W max.
Anything else I can do?
I took a video but didn't turn out too good. Attached a pic of my power supply.
Shawn
[quote="nuckolls.bob(at)aeroelect"]--> AeroElectric-List message posted by: "Mudfly" <shawntedwards>
[quote="nuckolls.bob(at)aeroelect"]At 07:56 AM 4/21/2023, you wrote:
[quote]--> AeroElectric-List message posted by: "Mudfly"
Shawn,
(o o)
<Go>
30.4 KB |
17218 Time(s) |
Posted: Sun Apr 30, 2023 6:56 am Post subject: Which Oil Pressure Switch? |
At 07:41 PM 4/27/2023, you wrote:
| Quote: | --> AeroElectric-List message posted by: "Mudfly" <shawntedwards(at)hotmail.com>
Anything else I can do? |
No, I've got an approach in mind. Let
me rummage around in the 'junk box'.
(o o)
< Go ahead, make my day . . . >
Posted: Tue May 02, 2023 1:35 pm Post subject: Which Oil Pressure Switch? |
Got all the parts I need but one . . .
piggybacked it onto an order for
another project. I'll be able
to provide you a plug-n-play
adapter to trigger your hour-meter
using the p-lead signal off
your mag.
(o o)
Mudfly
Posted: Mon May 08, 2023 5:38 am Post subject: Re: Which Oil Pressure Switch? |
Not sure if this is relative to my Hobbs meter "Enable" situation or
or not. I haven't had a chance to do my homework yet.
I will be using a SureFly and a Slick mag for my ignition setup. I discovered
the Surefly will not provide RPM output to the G3X system when the
Slickmag is switched off or inop. Surefly does have a Tach signal
converter that will solve this issue but, from what I understand, the
UMA T1A9-1 (see attachment below) will also solve the issue.
Again, I haven't had a chance to research the UMA T1A9 information yet but
wanted to bring this up in case it may be useful to my hobbs meter enable
function.
Shawn
 Download |
| Filename: |
mag-pickup-wires.pdf |
105.06 KB |
| Downloaded: |
1176 Time(s) |
Posted: Mon May 08, 2023 8:11 am Post subject: Which Oil Pressure Switch? |
Slickmag is switched off or inop. |
Hmmm . . . how does the SureFly know anything
about the magneto condition?
| Quote: | Surefly does have a Tach signal
UMA T1A9-1 (see attachment below) will also solve the issue. |
This is a powered, hall-effect sensor that
watches the magneto's magnet thus providing
a nice, clean square wave signal
completely independent of the magneto's
operating condition.
function. |
Yes, it WOULD provide a signal compatible with
the proposed hour-meter enable interface. Unlike
my original idea, the hour-meter would continue
to run whether or not the magneto was 'active'.
It's a lot more expensive. My proposed interface
looks at the p-lead noise of a active magneto.
Of course, it the mag is "off", the hour meter
doesn't run. Errors for recording engine run time
should be very small to non existent . . . how
often and for how long would you plan to fly with
the magneto off?
Either way works. But I'm mystified as to why
the SureFly would depend on Slick operations
to provide a tach signal . . .
(o o)
Ceengland
Posted: Mon May 08, 2023 8:43 am Post subject: Which Oil Pressure Switch? |
| I suspect that what he's saying is that the Surefly doesn't output a tach signal usable in the same fashion as the mag p-lead signal. Therefore, there's no signal to any electronic tach if the mag is off. Pretty common situation with aftermarket electronic ignitions for Lycs.
_________________ Charlie |
Mudfly
Posted: Mon May 08, 2023 9:26 am Post subject: Re: Which Oil Pressure Switch? |
Bob .
Charlie .
Yes Charlie. The Surefly doesn't output a usable tach signal to the G3X. So, during mag chk on run-ups, the rpm drops to zero when slick mag is selected off. Some don't mind this and just listen for RPM drop. Definitely the most simple approach. I just like to make things difficult so I looked at options to still have RPM visible. It appeared the SureFly Tach sensor
and the UMA T1A9-1 were the popular options. I went with the T1A9-1.
Shawn .
I purchased the T1A9-1 solely for the RPM function. It wasn't until I reviewed the documentation that I saw the "voltage out to hourmeter"
statement shown on pg2 of the document attached in my previous post.
Like you mentioned, I only want the hourmeter to record time when
the engine is running. Sounds like your method will accomplish that.
Thanks.
Shawn
Posted: Fri May 19, 2023 7:09 am Post subject: Which Oil Pressure Switch? |
At 11:43 AM 5/8/2023, you wrote:
Been out-of-pocket for a few days . . . returning
to the 'oil pressure switch thread' . . .
| Quote: |  Either way works. But I'm mystified as to why  the SureFly would depend on Slick operations  to provide a tach signal . . .
I suspect that what he's saying is that the Surefly doesn't output a tach signal usable in the same fashion as the mag p-lead signal. Therefore, there's no signal to any electronic tach if the mag is off. Pretty common situation with aftermarket electronic ignitions for Lycs. |
Aha! but of course. Given that a hall-effect
tach pickup has been added to the conversation,
making that signal activate the hour-meter as
well is easy. Of course, there's a further
benefit that the tach/hour-meter functions
are independent of conditions of either
ignition system.
I've sketched out an adapter circuit that would
interface the square wave output of your tachometer
pickup to the hour-meter.
The suggested transistor is hugely 'too-robust'
for the task but it's in a large package that
yields to 'spider-web' assembly of the components
directly to the transistor case before protecting
in some suitable encapsulant (E6000, JB Kwik, etc.)
Alternatively, this could be assembled on some
form of prototyping board in which case, ANY
logic level n-fet would be find.
If you wish, I can hammer this together out
of my junkbox. It would be fitted with flying
leads for interposition between your tach and
hour-meter.
(o o)
 Download |
| Filename: |
Taco-HrMeter_Signal_Conditioner.pdf |
72.14 KB |
| Downloaded: |
680 Time(s) |
Mudfly
Posted: Mon May 22, 2023 7:11 am Post subject: Which Oil Pressure Switch? |
Thanks Bob.
Sounds like your plan is exactly what I'm looking for. Not sure I fully understand what's going on though.
You lost me at "I've sketched out an adapter circuit that would interface the square wave output of your
tachometer pickup to the hour-meter." I can follow the diagrams basic
wiring, but still need some time in a dark corner to figure out the rest.
Slightly above my elctronical knowledge level.
I would happily accept/appreciate whatever you could come up with out of
your junkbox. Surely we can do some type of horse-trading to make it
worth your while.
Thanks again,
Shawn |
Very well sir. I'm mindful of the fact that
this forum is populated with a diversity
of experience and skills. It was not my wish
that you grasp the gritty details of my
proposal. But publishing the 'details'
affords opportunity for those interested
and willing to add the them to their
personal bag of tricks.
I'll scrape off a bit of space on the
workbench and hammer this thing together.
(o o)
Mudfly
Posted: Wed Jun 28, 2023 11:00 am Post subject: Re: Which Oil Pressure Switch? |
I've been off this topic for a while because I decided to install gear and
engine on my project. As always more new stuff to learn. Bob, let me
if you've had any luck with that adaptor circuit for the hobbs meter.
I hope to get back in the electrical game in a couple weeks.
Shawn
Posted: Fri Jun 30, 2023 3:22 pm Post subject: Which Oil Pressure Switch? |
I hope to get back in the electrical game in a couple weeks. |
Yes. I've been 'out of pocket' for a bit.
Just delivered a batch of camera door actuator
controllers to a old customer that surprised
me with an order.
Cleaning up my temporary 'production
line' off the dinning room table!
I can get to the adapter after this
weekend.
(o o)
Mudfly
Posted: Tue Mar 26, 2024 5:23 am Post subject: Re: Which Oil Pressure Switch? |
I've been away from electrical work on my project while I installed
engine and related accessories.
I'm reviving this thread on ways to activate a hobbs meter without
using an oil pressure switch. I have an LED hobbs meter that I would
like to wire so that it will display the hours when the batt switch is on ,
but not count time. I would like the timer to begin when engine is started.
As a review from the previous threads above, I have a 3-terminal
hobbs (+, -, and Enable). The positive terminal is fed from the Main Power Bus when batt is switched, and negative to firewall ground bus. The LED
digits illuminate with Batt switch on. I now need a way to power the
Enable terminal to begin the timer.
I have an idea but not sure of the part I need or if it even exists.
Here the plan. The positive terminal will have the 12v input from the main power bus. Also, I will have a feed wire from the positive terminal to
the "Unknown Device". The wire will continue from the unknown
device to the Enable pin on the hobbs meter. The "Unknown Device"
will need to block power until volts are above batt voltage..
say 13V??. When the engine is started and alternator is switched on,
power will pass the unknown device and power the enable terminal of the
hobbs meter.
Does this "Unknown Device" exist, and does the plan seem feasible?
Links to PDF drawings of a simple wire diagram and also tech sheet of the
Honeywell LCD Hour meter.
Thanks for the help.
Shawn
 Download |
| Filename: |
Honeywell LCD Hour Meter.pdf |
667.93 KB |
| Downloaded: |
3090 Time(s) |
 Download |
| Filename: |
HOBBS METER.pdf |
13.66 KB |
| Downloaded: |
625 Time(s) |
kenryan
Posted: Tue Mar 26, 2024 7:34 am Post subject: Which Oil Pressure Switch? |
I have a battery charger that senses vibration caused when the engine is started, and uses that as a trigger. I wouldn't have any idea how to procure or implement a vibration sensor as a trigger for your Hobbs, but I'll bet some of the guys on this list do.
On Tue, Mar 26, 2024 at 5:28 AM Mudfly <shawntedwards(at)hotmail.com (shawntedwards(at)hotmail.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: "Mudfly" <shawntedwards(at)hotmail.com (shawntedwards(at)hotmail.com)>
hobbs meter.
Shawn
http://forums.matronics.com/viewtopic.php?p=513410#513410
http://forums.matronics.com//files/honeywell_lcd_hour_meter_173.pdf
http://forums.matronics.com//files/hobbs_meter_117.pdf
="noreferrer" target="_blank">https://matronics.com/contribution
Ceengland
Posted: Tue Mar 26, 2024 8:17 am Post subject: Which Oil Pressure Switch? |
On Tue, Mar 26, 2024 at 8:28 AM Mudfly <shawntedwards(at)hotmail.com (shawntedwards(at)hotmail.com)> wrote:
hobbs meter.
Shawn
| 1st thing that comes to mind is a comparator circuit. It looks at two inputs, and outputs when the trigger input exceeds the reference input. If you set the reference input to 13V using a voltage regulator, then the trigger input would go above that when the alternator comes on line. Potential downside is that the Hobbs will stop counting if the alternator fails.
If you don't know about it, a 'Tiny Tach' works in a similar manner but has an internal battery. The sense lead is normally wrapped around a spark plug lead; won't work with shielded leads. But you can make it work with a slight mod to the distributor cap on a mag.
Virus-free.www.avast.com[url=#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2][/url]
mike_tailwind
Posted: Tue Mar 26, 2024 8:26 am Post subject: Which Oil Pressure Switch? |
You could modify Bob's latest overvoltage module to do what you need. Change the trip point to 13.5 volts, and remove the SCR.
From schematic 9003-630-IP6:
Change R7 from 13.7K to 11K
Remove Q15
Add a wire from U11B pin 7 to the enable input of the hour meter.
What we don't know is how much current the enable input to the hour meter draws. To test, place a 2.49K resistor between the enable input of the hourmeter and 12Volts. If it starts counting, no additional changes to the OVM need to be made.
On Tuesday, March 26, 2024 at 08:34:33 AM CDT, Mudfly <shawntedwards(at)hotmail.com> wrote:
hobbs meter.
Shawn
_/Navigator?AeroElectric-List" rel="nofollow" target="_blank">http://www=====================
= --> https://matronics.com/co
Mudfly
Posted: Tue Mar 26, 2024 9:55 am Post subject: Re: Which Oil Pressure Switch? |
Thanks for the Ideas.
Kenryan, I have seen the vibration activated hour meters. Definitely
the most simple solution. Unfortunately, I already have the Honeywell
installed in my panel and will try and make that work if I can.
Charlie, I will do some studying of the comparator circuit. Looks like
it could work.
Mike, Thanks for the details on how to modify Bob's overvoltage module.
I haven't been able to locate schematic 9003-630-IP6 you mentioned. I
will keep searching.
Shawn
