graeme bird
Posted: Thu Jan 28, 2021 12:03 am Post subject: Vents |
Any suggestions on cockpit vents. I am not far off painting my fuselage but haven't added any vents yet. The supplied ones are not durable. I tried to get the ones Ivan was looking for but they are no longer made. Tempted by the square piper ones from aircraftspruce.
_________________ Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk |
Martin Olliver
Posted: Thu Jan 28, 2021 3:29 am Post subject: Re: Vents |
Hello Graeme.
I have the same situation re air vents in my current Europa.
I fitted the round type in my previous Europa and they worked very well. As they are no longer an option I think the best solution is the square type used by the RV builders.
Has anyone any experience of how efficient they are and what position were they fitted?
In my last Europa I fitted the round type [Ultimate Ventilator] in the side wall aft of the panel. However the down side of this position was that on occasion my headset mike would pick up wind whistle.
Has any one fitted the square RV type of vent in the overhead position? What if any problems were found? I imagine Rain/water ingress could be a problem if the aircraft is parked outside without a cover.
Hitchflight
Joined: 22 Feb 2018 Posts: 94 Location: Derbyshire, England
Martin Olliver
Posted: Fri Jan 29, 2021 6:56 am Post subject: Re: Vents |
Thanks for the info Bob. I will look into them.
ward.t(at)xtra.co.nz Guest
Posted: Fri Jan 29, 2021 11:35 am Post subject: Vents |
Thanks Bob. Very interested in the vents as getting hot here now. Particularly taxying at airports on a hot day, I usually open and hold a door to ventilate.Will zoom in on the 6th Feb.
Sent from my iPadTim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand.
021 0640221
peterz(at)zutrasoft.com Guest
Posted: Fri Jan 29, 2021 1:25 pm Post subject: Vents |
better than the originals, having and O-ring! Nice!
I'd like to get a pair....
Pete Z
On Fri, Jan 29, 2021 at 2:43 PM timward <ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)> wrote:
| Quote: | Thanks Bob. Very interested in the vents as getting hot here now. Particularly taxying at airports on a hot day, I usually open and hold a door to ventilate.Will zoom in on the 6th Feb.
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand.
021 0640221
m(at)grassfam.com Guest
Posted: Fri Jan 29, 2021 2:02 pm Post subject: Vents |
I would be interested in a pair as well.
Michael Graß
| Quote: | On Jan 29, 2021, at 4:29 PM, Pete Zut <peterz(at)zutrasoft.com> wrote:
Pete Z
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand.
021 0640221
Griffo
Joined: 18 Mar 2021 Posts: 70 Location: The Oaks, NSW, Australia
Posted: Wed Mar 24, 2021 3:08 pm Post subject: Re: Vents |
Check out the NACA Vents from Peter Anson
capilopl(at)bigpond.com.au
_________________ 46 |
kjburns(at)btinternet.com Guest
Posted: Thu Mar 25, 2021 12:27 pm Post subject: Vents |
Graeme, I found the Naca vents did not flow enough air for me on hot summer days so went down the standard aircraft practice used for Sailplanes and Motorgliders
( derived from a ww2 requirement of all aircraft supplied to military to have a direct view panel in case of oil coverage or icing ).
I enjoy flying in the winter and during a dawn takeoff from Elverum in Norway snow covered strip , the canopy totally iced over as we climbed out , we were able to use open DV panel to circle the field as the rising sun melted the ice and restored full view..
Window needs to conform to shape of screen ,
Mould taken from exterior of screen before I laser cut the window aperture .
The location is high enough so the ram air vent clears the door handle.
And is as far forward as the slide rails will go against door frame .
https://www.afeonline.com/shop/mecaplex-dv-panel-scoop.html?osCsid=6b2332ad4f6f025eb953f910786112fe
[img]cid:48119686-0540-4C4A-96EC-682C9928E191[/img]
On 28 Jan 2021, at 08:03, graeme bird <graeme(at)gdbmk.co.uk (graeme(at)gdbmk.co.uk)> wrote:
359.99 KB |
17242 Time(s) |
Griffo
Posted: Thu Mar 25, 2021 4:04 pm Post subject: Re: Vents |
Nice work KJ.
I am surprised that the NACA vents do not deliver copious quantities of fresh air
I live in Australia (very hot) and have always found them to be very effective when made to correct dimensions , located appropriately and sized -
I see I gave the wrong information for Peter Anson Engineering - hope this works:
http://www.ansoneng.com/
He makes a nice selection of different NACA vents & ducting
Duncan McFadyean
Posted: Fri Mar 26, 2021 2:12 am Post subject: Vents |
I found that small NACA vents in the standard position didn't flow any air at all, without the addition of a VG in front of the vent (after which the vent makes a blast, and is quite noisy too).
Which suggests there's a bubble forming at the aft edge of the cowling. But I've not been able to detect a bubble using oil-streak.
Perhaps there's a Reynolds number limitation on how NACA vents work??
Duncan McF.
| Quote: | On 26 March 2021 at 00:04 Griffo <scangriffin(at)bigpond.com.au> wrote:
Nice work KJ.
46
http://forums.matronics.com/viewtopic.php?p=501098#501098
Griffo
Posted: Fri Mar 26, 2021 1:27 pm Post subject: Re: Vents |
Hi Duncan,
First rule of effective venting is: Location, location, location --------
Then comes design, as in shape & proportions NACA vents must be correctly proportioned to work effectively, not just look the part (as in may auto types)
Then comes size.
Lastly, exit air rout & size
Duncan McFadyean
Posted: Sat Mar 27, 2021 2:10 am Post subject: Vents |
All of which are compliant:
Duct proportioned as per NACA coordinates, positioned where all the other Europas have positioned theirs, and the fuselage 'sucks'.
So some other explanation is needed.
However,
I'd be interested to learn about the size effects; can you elaborate.
Duncan McF.
| Quote: | On 26 March 2021 at 21:27 Griffo <scangriffin(at)bigpond.com.au> wrote:
Hi Duncan,
Then comes size.
46
http://forums.matronics.com/viewtopic.php?p=501109#501109
Griffo
Posted: Sat Mar 27, 2021 3:28 am Post subject: Re: Vents |
I am looking for a flying Europa to purchase, so have little Europa specific information to give you however my current aircraft, an ATEC Zephyr, has NACA vents, on each side of the cockpit, just aft of the firewall - they perform very well. I will have to measure them to be sure but at a guess they are approximately 100 mm wide x 120 mm long. This suggests to me that your problem is not the vent (assuming correct design) but their location and/or possible alignment in relation to airflow – I think you have probably worked this out already.
Soooo perhaps” tufting” of possible locations to show air flow/direction but as you won’t be able to see how they move, a camera mounted on the wing might just get the information you need for best placement/alignment.
As for size – check out http://www.ansoneng.com/
Gilles
Posted: Sat Mar 27, 2021 9:36 am Post subject: Vents |
Le 26/03/2021 à 22:27, Griffo a écrit :
| Quote: | | Quote: | --> Europa-List message posted by: "Griffo" <scangriffin(at)bigpond.com.au> (scangriffin(at)bigpond.com.au)
Hi Duncan,
Then comes size.
Hi all,
This is what we did as a "defog" system :
http://contrails.free.fr/cellule_defog_en.php
Also I happened to perform a small study on NACA vents some time ago.
To support Ducan message, location, location !
The "NACA sumerged inlet" works only if the streamlines at its location are fairly parallel (ie no acceleration or especially no deceleration) and not too disturbed.
A clean inlet ramp, really square edges and a proper "lip" are required.
[img]cid:part1.E6A2674D.3B9F56CD(at)free.fr[/img]
Should craft a web page one of these days.
FWIW
Best regards,
Gilles
http://lapierre.skunkworks.free.fr
52.35 KB |
17174 Time(s) |
_________________ Best regards,
Gilles
http://contrails.free.fr |
John Wighton
Posted: Sun Mar 28, 2021 12:57 am Post subject: Re: Vents |
There has been a fair amount of discussion over the location of vents in the Europa, primarily due to interest in the round Ventomatic style of vent.
The location shown in this post , close to the waterline (WL) of the wing LE, is probably too low. The shown location differed from that indicated in the build notes that l have found.
The protruding exhaust disrupts the airflow at this WL, making it turbulen. Two effects: a) the NACA duct does not work efficiently. b) toxic gases from the exhaust stub can enter the cockpit.
My Europa has NACA ducts closer to the fuse split line and work very well. As do many other with the standard duct shape in or around this location.
The demisting of my cockpit is achieved with 2 off PC fans of around 60mmdiameter mounted in a carbon fibre plate fixed to the P1 side of the panel inner moulding. This picks up cabin air, slightly heated by the avionics and instruments and blows it onto the screen. I fitted it after leaving the aircraft parked outside for days in autumn, in flight it misted and the side vents were only effective in helping to demise the screen when flying above 100kts.
I have no DV panel and had to land with limited viz whilst mopping moisture off the screen. My (then) 11 year old son asking me “is this normal?”.
So, in my opinion other posts are correct, location, location is the key.
On the ACCEL electric aircraft the team decided to locate a very small NACA duct just in front of the vast screen and created a duct similar to the one shown linked in this post. The base of the screen at the centreline is a good taping point in the Europa, although it would need some surgery and a displaced cowling break line to make it a fixture. A ductING joint could be fashioned but Scat hose should not be used as it is high loss.
_________________ John Wighton
Europa XS trigear G-IPOD |
Patrick Tunney
Posted: Sun Mar 28, 2021 5:05 am Post subject: Re: Vents |
I am just in the process of installing the round style air o vents.
could i please get feedback on the best possible location and what worked well before i comit to the hole in the fuselage.
Images would really help.
Pat
budyerly@msn.com
Posted: Sun Mar 28, 2021 9:16 am Post subject: Vents |
I've had many discussions over the years on cockpit ventilation and I summarized them in a pdf for you guys to look at. I'm always interested in how to make things work.
My own aircraft is tolerable in the Florida heat, but frankly it too can be improved.
Best Regards,
Bud Yerly
 Download |
| Filename: |
Cockpit_Ventilation.pdf |
463.96 KB |
| Downloaded: |
903 Time(s) |
John Wighton
Posted: Sun Mar 28, 2021 2:57 pm Post subject: Re: Vents |
Reply to Pat Tunney
I will post a sketch of the preferred zone when l go to the office tomorrow.
Griffo
Posted: Sun Mar 28, 2021 3:23 pm Post subject: Re: Vents |
Very comprehensive article Bud - covered the topic very well.
Seems KJ might have his, very nicely finished, NACA vents to low down on the fuselage.
