antenna analyzer? Antennas
finn.usa(at)gmail.com
PostPosted: Sun Sep 27, 2020 4:20 pm    Post subject: antenna analyzer? Antennas Reply with quote
Finally got around to playing with nanoVNA and DDRR antenna.
I don't see that it can be used for a Comm antenna (118-136MHz). Too narrow bandwidth. Tried different things like changing gap, tap point, height and length. Formulas seem to be off. Found needed smaller circle (circumference). Also tap location closer to 0.5" that the 2.5 to 2.8" calculated points. I used a relatively thin wire as opposed to the recommended 1/4" to 1/2" tubing, hoping it would broaden the bandwidth (according to this remark:"The larger D is the higher efficiency is"). Bob tried to answer that for me but I'm still not sure if "efficiency" is related to bandwidth ("Q"). Perhaps I misunderstood that and should try 1/4" tubing?
[img]cid:part1.FBC49696.FA16FC0C(at)gmail.com[/img]
With a whip antenna, the bigger the diameter, the broader the bandwidth.
However, for an ELT antenna it will be perfect under engine cowling or on turtle deck. Saw SWR below 1:1.10 while fiddling with it. Some have installed their ELT antenna in their RV-4 under the canopy between pilot and passenger. Obviously without measuring SWR. A hand (much less a head or the rollover structure) severely affect SWR. Of course ground plane is very much in question in that location.
I also tried a 3/32" brass tube originating at very rear of canopy (ground contact to turtle deck) extending forward and up along the canopy. Very odd frequency response and very SWR sensitive to a hand near the tip.
At this point I'm looking at designing a streamline base for my 3/32" brass tubing in Solidworks and 3D printing it, mounting the antenna traditionally just behind the aft canopy skirt. Perhaps squeezing the tubing into a somewhat streamline and/or stepping down to 1/8" after the first 12" piece.
Finn
On 7/15/2020 11:47 PM, Robert L. Nuckolls, III wrote:
At 04:36 PM 7/15/2020, you wrote:
I ordered this https://www.ebay.com/itm/283898850600  ten days ago. Will probably be several weeks before I get it.
You can get them a lot cheaper, but I wanted one that'll also be useful checking transponder (and ADS-B) cable and antenna. (1GHz)
Still haven't given up on the idea of putting VHF comm antenna under the RV-4 canopy. Other than vertical polarization, ground plane will probably be the biggest issue (and impedance matching if I can't get the ground plane right). Got three 12"  5/32"OD brass tubes from Hobby Lobby. Should give a reasonably wide bandwidth.
Finn
  Check out this article from a 1971 issue of QST Magazine
http://www.aeroelectric.com/articles/Antennas/DDRR_Antenna.PDF
  A 2 meter (146 Mhz) version of this antenna
  is 6" in diameter and sets about 1" off the
  ground plane. An aviation version would be
  about 7" in diameter.
  It's bandwidth is probably pretty narrow . . .
  you'd have to build one and sweep it to
  see if it's usable. Would this fit on
  the deck just behind the rear seat?
  I've got one of those analyzers but haven't
  had time to make it sing, dance and do dishes.
  I've been using the VNA Tiny which is a good
  bit more expensive. It seems to work well.
  Let us know how that 'baby' VNA works for you!
 Filesize:  150 KB
 Viewed:  9318 Time(s)
ceengland7(at)gmail.com
PostPosted: Sun Sep 27, 2020 4:52 pm    Post subject: antenna analyzer? Antennas Reply with quote
I can't imagine a smaller dia wire spreading the freq peak, but then I've never seen that style antenna, either. Smile Maybe 'efficiency' in this context means usability across more of the frequency spectrum (lower Q). Certainly seems worth trying with 3/8 or 1/2 tubing, or 1/2" copper tape wrapped around something. Don't know if you care, but most ELTs require using their dedicated antenna to be 'legal', somewhat analogous to the silliness in FAA rules for GPS for IFR operations. I don't worry about the FAA that much, but if you insure the plane, it could give the ins co an out after an accident.
I assume you're using an old style 121Mhz ELT, right? The new dual freq models seem to require highly specialized antennas.
RE: brass for antenna. If you're talking about outside the canopy, you might want to re-think it. My 1st RV4 had the stainless wire whip ELT antenna mounted there, until it didn't. It broke off at the stress riser where it entered the long composite mounting cone. Behind the canopy is a really 'dirty', turbulent area. Maybe you could silver-solder a length of stainless tubing? Or 1/2" copper tape wrapped on a 'glass arrow shaft. I bet it'll still need some kind of support a few inches above the skin.
Have fun...
Finn
Finn
PostPosted: Sun Sep 27, 2020 5:26 pm    Post subject: antenna analyzer? Antennas Reply with quote
Or even a radiator fabricated from flat sheet?
The larger the diameter, the greater the bandwidth.
Efficiency has to do with ohmic losses (how much
energy goes off in heat) and again, a larger surface
area of the radiator has lower resistance. Recall that
currents at these frequencies flow on the skin
of the conductor. At DC, there is a substantial
difference between say a 1" diameter rod and a 1"
thin wall tube. At 100 MHz there is virtually
no difference 'cause all the 'happening' is at
the surface.
Exactly . . .
Interesting observation . . .
Also interesting . . . let us know
what you discover.
I am pleased that you've availed yourself
of this unusual piece of test equipment. You're
gaining knowledge and experience in a manner
that you will not forget . . . and will become
valuable information source for those who
follow.
PostPosted: Mon Sep 28, 2020 5:43 am    Post subject: antenna analyzer? Antennas Reply with quote
I guess ideally a tapered carbonfiber tube (perhaps wrapped with copper
table within another tapered carbonfiber tube).
I wonder if the carbon material is conductive enough for our purposes.
Finn
PostPosted: Mon Sep 28, 2020 6:59 am    Post subject: antenna analyzer? Antennas Reply with quote
At 08:43 AM 9/28/2020, you wrote:
--> AeroElectric-List message posted by: Finn Lassen <finn.usa(at)gmail.com>
I guess ideally a tapered carbonfiber tube (perhaps wrapped with copper table within another tapered carbonfiber tube).
Can you easily conduct the experiment? Sounds
interesting.
No. Antennas on our carbon aircraft at Hawker-Beech
required a beefed up ground plane. We also had to add
a distributed ground system for electrics . . . super pain
in the you know what . . .
PostPosted: Mon Sep 28, 2020 11:54 am    Post subject: antenna analyzer? Antennas Reply with quote
Tried with bigger "tubing" (Did not want to spend $ and time going to local hardware store to pick up 1/2" soft copper tubing and elbow.)
Size of wire or tubing does not appear to influence bandwidth.
So, my conclusion is unchanged: good compact vertically polarized antenna for single-frequency use, like ELT or 144-146MHz "band".
Not usable as wideband antenna. 118-136MHz certainly is wideband. (18/127 = 14%).
Would love to have someone else experiment with it and see if they somehow could get 1:3 SWR over 118-136MHz.
[img]cid:part1.9223A322.93ACD30A(at)gmail.com[/img]
[img]cid:part2.B888D8DB.B870AD98(at)gmail.com[/img]
118-137MHz, 1:4 SWR at top.
[img]cid:part3.AC576CD0.797E1988(at)gmail.com[/img]
[img]cid:part4.2F227B3F.402B8D8D(at)gmail.com[/img]
100-137MHz, 1:4 SWR at top.
You can definitely tune it to much better SWR at center frequency, but that was not the purpose here.
Finn
   the surface.
  Exactly . . .
  what you discover.
  follow.
 Filesize:  161 KB
 Viewed:  9305 Time(s)
 Filesize:  154.5 KB
 Filesize:  157 KB
 Filesize:  143 KB
PostPosted: Wed Sep 30, 2020 1:07 pm    Post subject: antenna analyzer? Antennas Reply with quote
It's been some years since I built one of these
(back in the days before vna's) and a similar
interval since I reviewed the literature.
Poked around on the 'net and my archives a bit
and I think I can confidently offer an explanation
for the fruitlessness of your endeavors.
The DDRR is a vertically polarized antenna wherein
the very short vertical mast is the radiator.
All that other stuff is a loading reactance for
the antenna . . . or 'top hat' in some circles.
Given that the radiation from an antenna is
proportional to the current flowing in the radiator
then it follows that this diminutive antenna
must have some bodacious currents. Further, where
the currents are high, losses need to be low
to minimize energy lost to heating.
My assertion about larger diameters improving
bandwidth was incorrectly applied to this
discussion. L/d ratio as it goes to bandwidth
works only in the resonant radiating portions of the
antenna . . . in this case, the mast. All
that stuff setting on top has a rapidly
diminishing current flow and besides, that
part doesn't radiate.
More surface area (diameter) helps this antenna
only in the radiator . . . the mast supporting
the top hat. Increasing surface area in the loading
portion goes to increased Q which means narrower
bandwidth.
The governing triad is profoundly demonstrated
in the magnetic loop antennas used on the HF
ham bands. There are very useful loop antennas crafted
for the 80M (3.5 to 4.0 Mhz) ham band where
the radiator is built from 1-2" copper pipe with
soldered joints in 45 degree elbows employed
to make an 8-sided 'circle'. The Q of these
antennas is very high which means hi currents
at the feedpoint, high voltages at the tuning
gap. The bandwidth of these antennas is very
narrow. The operator has to tune the antenna
in lockstep with his transceiver in order to
'cruise' that band for contacts.
http://www.oh2gqc.com/wp-content/uploads/2017/09/20170911_160930.jpg
Several sages in the design and fabrication
of antennas have noted, "one can strive for
(1) efficiency, (2) size and/or (3) bandwidth
with one overpowering caveat. Optimizing any two
qualities calls for degrading the third. So pick
two goals and live with consequences for the
third."
Therefore, your experience with the DDRR was
predictable. Yeah, you can get a really useful,
small profile antenna but because SIZE was
diminished, bandwidth suffers.
I thank you for sharing the results of your
experiment.
PostPosted: Wed Sep 30, 2020 2:36 pm    Post subject: antenna analyzer? Antennas Reply with quote
"mast"  Coax to ring or ring to ground plane?
So increasing ring to ground plane to a maybe 3/4" piece of tubing would increase bandwidth?
But probably not significantly enough to say 1:3 SWR over the 188-136MHz band?
Finn
  bandwidth.
  third."
  experiment.
PostPosted: Wed Sep 30, 2020 4:30 pm    Post subject: antenna analyzer? Antennas Reply with quote
the ring to ground plane . . .
no . . . that radiator is a fraction of a wavelength.
It resonates based on the reactive (capacitive)
effects of the ring.
But probably not significantly enough to say 1:3 SWR over the 118-136MHz band?
Interesting experiement . . . it might get
wider but probably way short of design
goals.
Finn
bandwidth.
third."
experiment.
Virus-free. www.avast.com[url=#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
PostPosted: Wed Sep 30, 2020 5:35 pm    Post subject: antenna analyzer? Antennas Reply with quote
I did a bit of web browsing on the DDRR. This thread is about a 2 meter version (above our comm band):
https://forums.qrz.com/index.php?threads/2m-ddrr-antenna-for-vehicle-some-questions.368057/
 The thread contains this sentence:
"The DDRR is an inverted-L. A 3" tall, 146 MHz DDRR has a radiation resistance of 3.0 ohms. The 2:1 VSWR bandwidth is 1.5 MHz."
  goals.
Finn
  bandwidth.
  third."
  experiment.
PostPosted: Thu Oct 01, 2020 5:05 am    Post subject: antenna analyzer? Antennas Reply with quote
Fairly typical. Radiator height is 3/21 or 15% of the
full size 1/4 wave. They cited a vswr 2:1 bandwidth
of 1.5/146 or 1% . . . 3:1 would be a bit wider
but still far short of that necessary for our
VHF comm bandwidths.
I'm still thinking I'd like to build one for our
local fire/ems services where 1% bandwidth is
plenty. The thing could reside under a plastic
radome and sit on a dedicated ground plane held
to the vehicle with magnets in each corner. Just
one of many PITS (pie-in-the-sky) projects in
someday bucket.
This still doesn't solve Finn's problem.
Remind me sir, what airplane are we talking
about?
Eric Page
PostPosted: Thu Oct 01, 2020 8:52 pm    Post subject: Re: antenna analyzer? Antennas Reply with quote
Perhaps not helpful to the antenna design y'all are pursuing in this thread, but I came across this paper today...
http://www.jpier.org/PIERM/pierm78/11.18102701.pdf
...thanks to the guys at DarkAero...
https://www.darkaero.com/
...who are experimenting with this antenna for their all-carbon fiber aircraft.
The paper describes an interesting printed circuit board antenna of meandering design. It looks very useful for builders looking to avoid long external antennae, and if the bandwidth shown for a ~160MHz design can be duplicated at ~120MHz, it should work well.
Eric
hairy_kiwi
PostPosted: Thu Oct 08, 2020 4:53 am    Post subject: Re: antenna analyzer? Antennas Reply with quote
Hi Group,
Long time lurker here. Hopefully, as the OP made the title rather broadband Wink a general discussion on aviation / aircraft antenna design and using antenna analyzers for verifying experiments is welcome here. Otherwise, apologies for further dragging the discussion away from the otherwise fascinating DDRR antenna design...
I recently bought a Rig Expert AA 230 ZOOM analyzer, primarily for helping to diagnose faults in antenna coax while doing the odd bit of experimental aircraft rewiring. Its been a great tool for quickly and easily finding poorly made BNC terminations for example (wire disconnected from center pin in a poorly made, screw-together style BNC connector) and checking SWR in a comm antenna epoxied into a composite aircraft is still acceptable years after construction.
As for using an analyzer for antenna design, the interesting, very detailed paper Eric posted a link to, titled 'Airborne VHF Printed Monopole Antenna for Platform Constrained Applications' looks like it could be a fun design to experiment with - possibly for installing inside the fin of the Kitfox I'm going to be building - especially as the ground plane is incorporated in the same plane as the antenna.
I have a basic understanding of antenna design, but its very basic - and with a few antenna issues and projects on the go, I'd be very interested in furthering my knowledge and doing some experimenting with the aid of the analyzer. What would be useful are some links to modern literature on aviation/aircraft antenna design - many thanks Eric for your post!
I had a browse through the ARRL Antenna Book which is a great tome of info, however the vast majority of that material is aimed at ground station antennas. So I'm still unclear on such things as by how much proximity to The Earth the SWR of an aircraft (comm) antennas is affected. Maybe a flight vs ground test comparison using an analyzer might be interesting to conduct, even if it proves 'no significant difference', particularly for 1/2 wave dipoles fitted internally to composite aircraft.
I've found some other recently published and interesting material with test results on (ground based) 2m 1/2 wave dipole designs that might be worth experimenting / adapting for aircraft use, but will save that for another post if there's interest.
Jim
Hamish 'Jim' Mead
Ledbury, UK
PostPosted: Thu Oct 08, 2020 11:45 am    Post subject: antenna analyzer? Antennas Reply with quote
At 07:53 AM 10/8/2020, you wrote:
--> AeroElectric-List message posted by: "hairy_kiwi" <hamish.mead(at)gmail.com>
Hi Group,
I think we're done with the DDRR for now.
It seems unlikely that a satisfactory fabrication
technique for increasing bandwidth will be
forthcoming.
The antenna gurus all seem to agree that the
perfect triad of size, efficency and bandwidth
is like finding a way to to resolve cube roots
with a pencil/paper. Unfortunately for the DDRR, the
primary driver (size) put the kibosh on at least
one of the other two, mainly bandwidth.
<snip>
I've seen those tools on the web . . . they seem
widely utilized with satisfaction.
On page 2 we find this statement, "The major constraint
in designing an airborne printed monopole antenna
in VHF/UHF band is achieving compactness and wide
bandwidth simultaneously, along with sufficient gain."
This assertion pays homage to the SEB triad with
the operative phrase being "sufficient gain".
Figure 6 shows that a very satisfactory bandwidth
was achieved while Figure 7 shows the sacrifices in
efficiency wherein the two test conditions demonstrate
losses of 6 to 15 dB over the bandwidth of interest.
That's 1/4 to 1/32 of the radiated energy offered
by the reference antenna. Sufficient? Maybe. Recall
that all VHF comm is line of sight . . . you don't
talk past the horizon and in any case, it's almost
never necessary to have conversation beyond 50
miles or so. So maybe, just maybe an antenna with
that efficiency profile would provide satisfactory
communications for some if not all builders.
The proof is in the pudding (I prefer vanilla-tapicoa
myself).
It's not . . . but proximity to conducting aircraft
structure (artificial ground) is. So ground vs.
airborne testing is probably not useful.
The flight test of intense interest would be with
perhaps a software driven receiver (SDR) on board
where you would fly 360s out 40 miles or so from a handy
ground station and plot comparative azimuth measurements of your
test antenna with respect to a more conventional vhf comm
whip. We used to do a good bit of this type testing
at Hawer-Beech . . . which requires another previously
expensive but now not so much spectrum analyzer/receiver
with signal strength display.
Let's look at them . . .
