kenryan
Posted: Fri Aug 07, 2020 9:02 am Post subject: two fuses in a circuit |
There has been some discussion about possible issues related to having two fuses in the same circuit. I'm not sure if this was ever resolved.
My situation has to do with the indicator lights that tell me whether or not each of my two fuel pumps is getting power. Of course the wire that powers each pump is fused. But the wire that powers each indicator light is tied to the same circuit as its respective pump, and that wire is protected separately by a 2 amp fuse.
I have attached a picture of my wiring diagram. Wiring is 100% complete, but airplane has not flown yet. Limited testing has not uncovered any issues.
If the existence of these two amp fuses in my system could cause me to lose power to a fuel pump, I would remove them, unless removing them causes other problems.
See attached and as always, thanks!
Ken
390.11 KB |
11933 Time(s) |
alec(at)alecmyers.com Guest
Posted: Fri Aug 07, 2020 9:11 am Post subject: two fuses in a circuit |
Noob question... why is a separate fuse for the indicator light a good idea, if the circuit is already protected?
Ken
<wiring-diagram.jpg>
Posted: Fri Aug 07, 2020 9:24 am Post subject: Re: two fuses in a circuit |
Those 2 amp fuses are not a problem. If you want to experiment, you could short out
an indicator light to make sure that the fuel pump fuse does not blow along with the 2 amp fuse.
_________________ Joe Gores |
kenryan
Posted: Fri Aug 07, 2020 9:29 am Post subject: two fuses in a circuit |
If the indicator light shorts out I would not want that to take down the pump itself.
On Fri, Aug 7, 2020, 09:18 Alec Myers <alec(at)alecmyers.com (alec(at)alecmyers.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: Alec Myers <alec(at)alecmyers.com (alec(at)alecmyers.com)>
On Aug 7, 2020, at 13:03, Ken Ryan <keninalaska(at)gmail.com (keninalaska(at)gmail.com)> wrote:
Ken
david(at)carter.net Guest
Posted: Fri Aug 07, 2020 9:42 am Post subject: two fuses in a circuit |
It's not the circuit that is protected by the breaker or fuse, it's the *wire*. If the wire running to the indicator lamp is smaller than the 16 gauge running to the pump, the fuse is appropriate. I don't see the wire size labeled. That fuse should be as near as possible to the junction of the pump wire & the smaller indicator wire. If it's wired according to the diagram, I don't see any way the fuse to the indicator could take out the pump, because that fuse is not in the path of the electrons going through the pump. ---
David Carter
david(at)carter.net (david(at)carter.net)
On Fri, Aug 7, 2020 at 1:13 PM Alec Myers <alec(at)alecmyers.com (alec(at)alecmyers.com)> wrote:
Ken
ceengland7(at)gmail.com Guest
Posted: Fri Aug 07, 2020 9:49 am Post subject: two fuses in a circuit |
On 8/7/2020 11:58 AM, Ken Ryan wrote:
| Quote: | There has been some discussion about possible issues related to having
Ken
If you move the lamp connection point (and fuse) back to the source, any
issue disappears. Unless you're using the CB to control the pump, of course.
What pumps are you using? Facets run on about 2-3A; Walbro injection
pumps expect a 15A protection device (startup surge). The Wabros are
marked right on the pump.
kenryan
Posted: Fri Aug 07, 2020 11:17 am Post subject: two fuses in a circuit |
Thanks everyone.
On Fri, Aug 7, 2020, 09:36 user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)>
Joe Gores
http://forums.matronics.com/viewtopic.php?p=497559#497559
finn.usa(at)gmail.com Guest
Posted: Fri Aug 07, 2020 4:50 pm Post subject: two fuses in a circuit |
My GSL393 is marked "20 amp fuse".
Finn
On 8/7/2020 1:45 PM, Charlie England wrote:
<ceengland7(at)gmail.com>
> resolved.
> Ken
any issue disappears. Unless you're using the CB to control the pump,
of course.
Posted: Fri Aug 07, 2020 5:52 pm Post subject: two fuses in a circuit |
Thanks Finn; I'm having a bad memory day (as you probably saw over on
the rotary list).
On 8/7/2020 7:45 PM, Finn Lassen wrote:
Finn
>> resolved.
>> Ken
> of course.
> Charlie
kenryan
Posted: Fri Aug 07, 2020 6:30 pm Post subject: two fuses in a circuit |
Charlie, the pumps are Walbro. I believe they are GSL395. I was advised to use 10 amp fuse but I will double check. I did go to the Walbro website but couldn't find specs.
On Fri, Aug 7, 2020 at 9:56 AM Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)>
> Ken
kenryan
Posted: Fri Aug 07, 2020 6:31 pm Post subject: two fuses in a circuit |
I will check the pump and see if it is marked.
On Fri, Aug 7, 2020 at 6:26 PM Ken Ryan <keninalaska(at)gmail.com (keninalaska(at)gmail.com)> wrote:
| Quote: | Charlie, the pumps are Walbro. I believe they are GSL395. I was advised to use 10 amp fuse but I will double check. I did go to the Walbro website but couldn't find specs.
> Ken
Posted: Fri Aug 07, 2020 7:22 pm Post subject: two fuses in a circuit |
Found a link showing the 395 along with the other Walbro gerotor pumps. It shows 130 lph (at) 15 psi, so the 10A fusing sounds more plausible.
https://walbrofuelpumps.com/walbro-gsl-series-universal-inline-fuel-pumps
I was expecting either 3-6 psi for a carb, or 40-60 psi for electronic injection.
Sent from BlueMail
On Aug 7, 2020, at 9:36 PM, Ken Ryan <keninalaska(at)gmail.com (keninalaska(at)gmail.com)> wrote: | Quote: | Charlie, the pumps are Walbro. I believe they are GSL395. I was advised to use 10 amp fuse but I will double check. I did go to the Walbro website but couldn't find specs.
> Ken
johnbright
Joined: 14 Dec 2011 Posts: 167 Location: Newport News, VA
Posted: Fri Aug 07, 2020 11:06 pm Post subject: Re: two fuses in a circuit |
Walbro 395 flow and current... the Walbro page I found had broken links to the jpg graphs but those broken links contain file names and with the file names one can google and get https://walbrofuelpumps.com/images/flow-charts/
In that file space is "GSL395-Flow-Chart.jpg"... attached.
118.75 KB |
11904 Time(s) |
_________________ John Bright, RV-6A
Single battery, wound-field alternator on main bus, MZ-30 PM generator on engine/essential bus.
N1921R links |
Posted: Sat Aug 08, 2020 6:57 am Post subject: two fuses in a circuit |
If you use an LED indicator, the obligatory
current limiting resistor for the LED can
be installed at the 'head end' of the indicator
feeder where the fuse would be located . . .
putting the resistor there limits current
in that feeder to milliamps even when shorted
to ground. The fuse goes away.
kenryan
Posted: Sat Aug 08, 2020 7:28 am Post subject: two fuses in a circuit |
Thanks for that Bob, and thanks Charlie for the fusing advice.
On Sat, Aug 8, 2020 at 7:01 AM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
| Quote: | If you use an LED indicator, the obligatory
