Spark plugs and heat range
Goto page Previous  1, 2
dmasys2(at)gmail.com
PostPosted: Tue May 26, 2020 10:58 am    Post subject: Spark plugs and heat range Reply with quote
Sorry to be too lazy to go pull the cowl to check, but does anyone know if the same injector marking rules apply to the GAMI injectors?  Have been happily flying behind a set of them for more than a decade and never really thought about clocking them during reinstall after cleaning (or remember reading GAMI instructions that said to do that).
-Dan Masys
N104LD
On Mon, May 25, 2020 at 2:04 PM Bob Turner <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> wrote:
--> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
Thank you, Vol88, for reminding me of the actual instructions. Note the arrow doesn't have to point exactly down: anywhere within a 180 deg of arc of "not up" will suffice to minimize fuel  dripping out after shutdown. If you're concerned with ram air hitting the opening, you could point the arrow down and slightly forward.
Like Kelly, I didn't want to over torque these things. I stopped at 40 in-lbs if the arrow was down. If necessary I went to 60. If that didn't work, I removed the whole thing, cleaned the treads with a toothbrush and tried again. That usually worked!
Bob Turner
RV-10 QB
Kelly McMullen
PostPosted: Tue May 26, 2020 12:16 pm    Post subject: Spark plugs and heat range Reply with quote
I don't know...However, since they are just injectors with the restrictor more precisely drilled, I expect they would be the same.
Sent from my TRS-80 Model 100
On Tue, May 26, 2020 at 12:02 PM Dan Masys <dmasys2(at)gmail.com (dmasys2(at)gmail.com)> wrote:
-Dan Masys
N104LD
Bob Turner
RV-10 QB
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
Lenny Iszak
PostPosted: Tue May 26, 2020 2:43 pm    Post subject: Spark plugs and heat range Reply with quote
Dan,
This should help you out. Paragraph #2:
[url=https://gami.com/gamijectors/installation/GAMI IP-98-001 Rev B Lyc GL10.pdf]https://gami.com/gamijectors/installation/GAMI%20IP-98-001%20Rev%20B%20Lyc%20GL10.pdf[/url]
[img]cid:EB809DEF-DBCC-4749-A943-94F30665C4DC(at)localdomain[/img]
Lenny
On May 26, 2020, at 2:54 PM, Dan Masys <dmasys2(at)gmail.com (dmasys2(at)gmail.com)> wrote:
-Dan Masys
N104LD
--> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> Thank you, Vol88, for reminding me of the actual instructions. Note the arrow doesn't have to point exactly down: anywhere within a 180 deg of arc of "not up" will suffice to minimize fuel dripping out after shutdown. If you're concerned with ram air hitting the opening, you could point the arrow down and slightly forward. Like Kelly, I didn't want to over torque these things. I stopped at 40 in-lbs if the arrow was down. If necessary I went to 60. If that didn't work, I removed the whole thing, cleaned the treads with a toothbrush and tried again. That usually worked! -------- Bob Turner RV-10 QB
 Filesize:  125.96 KB
 Viewed:  8173 Time(s)
Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 500 hrs
PostPosted: Tue May 26, 2020 3:34 pm    Post subject: Spark plugs and heat range Reply with quote
Just what I needed, Lenny.  Thanks!
-Dan Masys
On Tue, May 26, 2020 at 3:50 PM Lenny Iszak <lenard(at)rapiddecision.com (lenard(at)rapiddecision.com)> wrote:
Dan,
[img]cid:17253525ecf5b2e86771[/img]
Lenny
-Dan Masys
N104LD
Bob Turner
RV-10 QB
 Filesize:  125.96 KB
 Viewed:  8171 Time(s)
rvdave
PostPosted: Wed Jun 10, 2020 3:59 pm    Post subject: Re: Spark plugs and heat range Reply with quote
I found I had the orifice holders clocked opposite what they should have been, so clocked the vent side away from ram air but wasn’t noticeably different. Of course maybe now I need to retune orifices, my next project to see if it makes a difference for peak egts.
Dave Ford
Cadillac, MI
Page 2 of 2
