dmasys2(at)gmail.com Guest
Posted: Tue May 26, 2020 10:58 am Post subject: Spark plugs and heat range |
Sorry to be too lazy to go pull the cowl to check, but does anyone know if the same injector marking rules apply to the GAMI injectors? Have been happily flying behind a set of them for more than a decade and never really thought about clocking them during reinstall after cleaning (or remember reading GAMI instructions that said to do that).
-Dan Masys
N104LD
On Mon, May 25, 2020 at 2:04 PM Bob Turner <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> wrote:
| Quote: | --> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
Thank you, Vol88, for reminding me of the actual instructions. Note the arrow doesn't have to point exactly down: anywhere within a 180 deg of arc of "not up" will suffice to minimize fuel dripping out after shutdown. If you're concerned with ram air hitting the opening, you could point the arrow down and slightly forward.
Like Kelly, I didn't want to over torque these things. I stopped at 40 in-lbs if the arrow was down. If necessary I went to 60. If that didn't work, I removed the whole thing, cleaned the treads with a toothbrush and tried again. That usually worked!
Bob Turner
RV-10 QB
Kelly McMullen
Posted: Tue May 26, 2020 12:16 pm Post subject: Spark plugs and heat range |
I don't know...However, since they are just injectors with the restrictor more precisely drilled, I expect they would be the same.
| Quote: | | Sent from my TRS-80 Model 100 |
On Tue, May 26, 2020 at 12:02 PM Dan Masys <dmasys2(at)gmail.com (dmasys2(at)gmail.com)> wrote:
| Quote: | Sorry to be too lazy to go pull the cowl to check, but does anyone know if the same injector marking rules apply to the GAMI injectors? Have been happily flying behind a set of them for more than a decade and never really thought about clocking them during reinstall after cleaning (or remember reading GAMI instructions that said to do that).
-Dan Masys
N104LD
Bob Turner
RV-10 QB
A&P/IA, EAA Tech Counselor
KCHD |
Lenny Iszak
Posted: Tue May 26, 2020 2:43 pm Post subject: Spark plugs and heat range |
Dan,
This should help you out. Paragraph #2:
[url=https://gami.com/gamijectors/installation/GAMI IP-98-001 Rev B Lyc GL10.pdf]https://gami.com/gamijectors/installation/GAMI%20IP-98-001%20Rev%20B%20Lyc%20GL10.pdf[/url]
[img]cid:EB809DEF-DBCC-4749-A943-94F30665C4DC(at)localdomain[/img]
Lenny | Quote: | On May 26, 2020, at 2:54 PM, Dan Masys <dmasys2(at)gmail.com (dmasys2(at)gmail.com)> wrote:
-Dan Masys
N104LD
| Quote: | | --> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> Thank you, Vol88, for reminding me of the actual instructions. Note the arrow doesn't have to point exactly down: anywhere within a 180 deg of arc of "not up" will suffice to minimize fuel dripping out after shutdown. If you're concerned with ram air hitting the opening, you could point the arrow down and slightly forward. Like Kelly, I didn't want to over torque these things. I stopped at 40 in-lbs if the arrow was down. If necessary I went to 60. If that didn't work, I removed the whole thing, cleaned the treads with a toothbrush and tried again. That usually worked! -------- Bob Turner RV-10 QB |
125.96 KB |
8172 Time(s) |
_________________ Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 500 hrs |
Posted: Tue May 26, 2020 3:34 pm Post subject: Spark plugs and heat range |
Just what I needed, Lenny. Thanks!
-Dan Masys
On Tue, May 26, 2020 at 3:50 PM Lenny Iszak <lenard(at)rapiddecision.com (lenard(at)rapiddecision.com)> wrote:
| Quote: | Dan,
[img]cid:17253525ecf5b2e86771[/img]
Lenny
-Dan Masys
N104LD
Bob Turner
RV-10 QB
125.96 KB |
8170 Time(s) |
rvdave
Posted: Wed Jun 10, 2020 3:59 pm Post subject: Re: Spark plugs and heat range |
I found I had the orifice holders clocked opposite what they should have been, so clocked the vent side away from ram air but wasn’t noticeably different. Of course maybe now I need to retune orifices, my next project to see if it makes a difference for peak egts.
_________________ Dave Ford
Cadillac, MI |
