John Deere VR
wdaniell.longport(at)gmai
PostPosted: Wed May 13, 2020 1:56 pm    Post subject: John Deere VR Reply with quote
Dear list
Can someone direct me to a definitive wiring guide for the JD voltage regulator.   Ive found it in the past but cant find it now.
Will
William Daniell
LONGPORT
+1 786 878 0246
yellowduckduo(at)gmail.co
PostPosted: Wed May 13, 2020 2:58 pm    Post subject: John Deere VR Reply with quote
http://www.n56ml.com/corvair/dynamo.html
On 13/05/2020 5:51 PM, William Daniell wrote:
Dear list
Will
William Daniell
LONGPORT
+1 786 878 0246
At 04:51 PM 5/13/2020, you wrote:
Dear list
Will
William Daniell
LONGPORT
+1 786 878 0246
what's the part number on your
regulator.
PostPosted: Wed May 13, 2020 3:32 pm    Post subject: Re: John Deere VR Reply with quote
Can you post a picture of your John Deere regulator?
If it looks like this one, B+ terminal goes to a 30 amp fuse that is connected to the downstream side of battery contactor.
The AC terminals connect to Rotax permanent magnet generator (yellow wires)
L is for a lamp. Usually not used.
IGW connects to a switch (labeled "Alternator") which gets 12 volts from a 3 amp fuse on the main power bus.
Be sure to mount regulator using heat conductive grease between aluminum surfaces.
 Filesize:  33.77 KB
 Viewed:  5309 Time(s)
Joe Gores
PostPosted: Wed May 13, 2020 3:53 pm    Post subject: John Deere VR Reply with quote
I originally bought this as a back up to carry in my flying tool/spares pack.  I thought it might be a good idea to know how to install it.
thanks
Will
[img]cid:ii_ka5zpqfi0[/img]
William Daniell
+1 786 878 0246
On Wed, May 13, 2020, 19:03 Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Dear list
Will
William Daniell
LONGPORT
+1 786 878 0246
regulator.
 Filesize:  551.08 KB
 Viewed:  5308 Time(s)
gilles(at)elixir-aircraft
PostPosted: Thu May 14, 2020 9:38 am    Post subject: John Deere VR Reply with quote
Le 14/05/2020 à 17:54, William Daniell a écrit :
So my research indicates
AC = Yellow rotax wires output from ALT
B+ = +B = battery
I believe that on the Ducati R and +B are connected internally.
Will,
Yes they are.
http://contrails.free.fr/elec_ducati_en.php
Best regards,
Gilles
http://lapierre.skunkworks.free.fr
