Stall warning system
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Allegro-List
Aero Siam
PostPosted: Fri Nov 15, 2019 4:32 am    Post subject: Stall warning system Reply with quote
Hi all
Can anyone help with the pneumatic stall sensor connections ? If I suck on the orange hose, the buzzer sounds. I presume this end is connected to the hose that runs to the leading edge and that the other side is connected to the static system. Is that correct ?
Also I saw there were posts in the past about the adjustment knob on the left bottom of the ASI. Does anyone know how this operates?
Paul
- The Matronics Allegro-List Email Forum -
http://www.matronics.com/Navigator?Allegro-List
 Filesize:  97.8 KB
 Viewed:  12538 Time(s)
aerosiam
PostPosted: Tue Dec 17, 2019 3:42 am    Post subject: Re: Stall warning system Reply with quote
I think I have the answer to this.
It's an MPL 503 pressure switch
https://www.aircraftspruce.com/catalog/inpages/mpl500series-ps.php
The V-vacuum side connects to the port in the leading edge and the pressure side to the static system
It tests correctly on the ground with slight suction on the port
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Allegro-List All times are GMT - 8 Hours
