Aero Siam
Posted: Fri Nov 15, 2019 4:32 am Post subject: Stall warning system |
Hi all
Can anyone help with the pneumatic stall sensor connections ? If I suck on the orange hose, the buzzer sounds. I presume this end is connected to the hose that runs to the leading edge and that the other side is connected to the static system. Is that correct ?
Also I saw there were posts in the past about the adjustment knob on the left bottom of the ASI. Does anyone know how this operates?
Paul
| | - The Matronics Allegro-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Allegro-List |
97.8 KB |
12536 Time(s) |
aerosiam
Posted: Tue Dec 17, 2019 3:42 am Post subject: Re: Stall warning system |
I think I have the answer to this.
It's an MPL 503 pressure switch
https://www.aircraftspruce.com/catalog/inpages/mpl500series-ps.php
The V-vacuum side connects to the port in the leading edge and the pressure side to the static system
It tests correctly on the ground with slight suction on the port
