Jim Combs
Joined: 24 Jan 2010 Posts: 141 Location: Lexington, Ky
Posted: Wed Dec 11, 2019 8:49 pm Post subject: Lyc IO-540 C4B5 |
I am putting a new engine in my -10. I have removed my C4B5 version.
Wondering what kind of value an engine like this has?
Specifics:
Lycoming IO-540 C4B5
5874.54 hrs TT
1955.54 hrs SMOH
970.64 hrs (RV-10, 5 Steel Cylinders at 984 hrs, 1 Chrome Cylinder)
Includes:
Airflow Performance fuel injection system
LightSpeed Plasma III ignition(1) + Slick Mag(1)
Flywheel Magnets + pickup for Lightspeed Ignition
RV-10 Baffles
Does Not Include:
Starter
Alternator
Prop Governor
Thanks, Jim C
N312F, 1200 Hours
1.65 MB |
8558 Time(s) |
1.52 MB |
8558 Time(s) |
_________________ RV-10 -> N312F - Flying as of 12/2008 |
Kelly McMullen
Posted: Thu Dec 12, 2019 5:52 am Post subject: Lyc IO-540 C4B5 |
I can't tell you what your extras are worth, but 5 yrs ago I paid $12,000 for a good core that could be rebuilt for around $26-27K, for total cost approx. $39K, in the era after Lycoming jacked the price of both engine kits and complete new engines, roughly 10K.
There are some that would say that if your old engine isn't using unusual amount of oil and has good compressions, to keep flying it.
Curious what you bought as replacement that you aren't reusing fuel system, ignition and baffles.
| Quote: | | Sent from my TRS-80 Model 100 |
On Wed, Dec 11, 2019 at 9:55 PM Jim Combs <jiminlexky(at)gmail.com (jiminlexky(at)gmail.com)> wrote:
| Quote: | I am putting a new engine in my -10. I have removed my C4B5 version.
Specifics:
5874.54 hrs TT
1955.54 hrs SMOH
Includes:
RV-10 Baffles
Does Not Include:
Starter
Alternator
Prop Governor
Thanks, Jim C
N312F, 1200 Hours
A&P/IA, EAA Tech Counselor
KCHD |
Jim Combs
Posted: Thu Dec 12, 2019 7:03 am Post subject: Lyc IO-540 C4B5 |
So I bought this engine in 2008 and had the fuel system overhauled and
added five new cylinders. Knowing it was a high time engine, I put
money away over the last ten years to buy a brand new engine. I put a
deposit on a Titan IO-540 about 4 years ago. They kept the quoted
price to me and this last year they built up the engine. It included
dual Lightspeed ignition, cold air induction, roller tappets at a
price below what I could get thru Vans. I have been doing oil changes
at 50 hour intervals with oil reports. Titan finally wanted to
deliver the engine and this engine was at BO. So time for a switch.
I am making everything firewall forward "New". New baffles and any
related parts that needed changing out have been replaced. So I have
this engine and looking to recycle it.
I was having an oil leak but pretty sure it was the prop governor.
That is out for an overhaul to go on the new engine. Compression
numbers are good. but I would assume someone might continue to use the
new cylinders? I don't know, I am not an engine expert. Hence the
question about the value of this engine.
Jim C
N312F
On Thu, Dec 12, 2019 at 8:56 AM Kelly McMullen <apilot2(at)gmail.com> wrote:
> Specifics:
> 5874.54 hrs TT
> 1955.54 hrs SMOH
> Includes:
> RV-10 Baffles
> Does Not Include:
> Starter
> Alternator
> Prop Governor
> Thanks, Jim C
> N312F, 1200 Hours
1.7 MB |
8556 Time(s) |
Tim Olson
Posted: Thu Dec 12, 2019 9:50 am Post subject: Lyc IO-540 C4B5 |
Hi Jim,
I'm almost in the same boat as you. I've been putting away money
for a new engine as I fly, and this year I ordered a new Titan engine.
It's not due until mid-2020, and I'm only at 1450 hours right now
on mine that was built zero time to new limits when I got it. I just
figured now is a good time to order one because in my case, someone
else who's building can still get a few hundred or maybe even 1,000
hours out of this one, but I can finally cash in my brand new engine
discount and the next one will keep me going for perhaps the rest
of my flying years. So I'll be curious as to how your sale goes.
Mine has enough time left on it that I'm hoping to get somewhere
around a 1/2 share of the >$50K that the new one costs.
Hopefully the new one will be as reliable as this one has been.
On 12/12/2019 9:02 AM, Jim Combs wrote:
| Quote: | So I bought this engine in 2008 and had the fuel system overhauled and
Jim C
N312F
>> Specifics:
>> 5874.54 hrs TT
>> 1955.54 hrs SMOH
>> Includes:
>> RV-10 Baffles
>> Does Not Include:
>> Starter
>> Alternator
>> Prop Governor
>> Thanks, Jim C
>> N312F, 1200 Hours
Tim Olson
Posted: Thu Dec 12, 2019 10:34 am Post subject: Lyc IO-540 C4B5 |
Sorry, I see you said "Titan". I got a Lycoming Thunderbolt.
Just wanted to make sure I spoke correctly.
Jim C
N312F
>> Specifics:
>> 5874.54 hrs TT
>> 1955.54 hrs SMOH
>> Includes:
>> RV-10 Baffles
>> Does Not Include:
>> Starter
>> Alternator
>> Prop Governor
>> Thanks, Jim C
>> N312F, 1200 Hours
