art(at)zemon.name Guest
Posted: Thu Aug 15, 2019 6:58 pm Post subject: Flaky EGT Probe |
Folks,
One of my four EGT probes is flaky. Sometimes it works. Most of the time it reads zero (too low to register). I don't actually use the EGT for anything so I'm not very excited about spending money to fix it. But it annoys me to see three nice green bars and one black space where there should be a green bar.
Are these things repairable?
-- Art Z.
https://CheerfulCurmudgeon.com/Love the stranger for you yourselves were strangers in Egypt. Deut. 10:19
email(at)jaredyates.com Guest
Posted: Thu Aug 15, 2019 7:32 pm Post subject: Flaky EGT Probe |
Art, you seem like the kind of fellow who would appreciate a lengthy blog post:
http://bearhawkblue.com/replacing-the-oem-dynon-thermocouple-connectors-with-omega-connectors/
On August 15, 2019 23:05:01 Art Zemon <art(at)zemon.name> wrote: | Quote: | Folks,
-- Art Z.
bob.verwey(at)gmail.com Guest
Posted: Thu Aug 15, 2019 10:01 pm Post subject: Flaky EGT Probe |
Hi Art
So how is it that you dont use your EGT? To me it is a prized tool in the engine management arsenal!
On Fri, 16 Aug 2019 at 05:03, Art Zemon <art(at)zemon.name (art(at)zemon.name)> wrote:
| Quote: | Folks,
-- Art Z.
Best...Bob Verwey
082 331 2727
[img]https://docs.google.com/uc?export=download&id=0B5d7rgAInTuTUUZsUjY4QmJsdVU&revid=0B5d7rgAInTuTdDJDaXRFZVh3b3lMa3FWL0s3MFdzc01YRlNvPQ[/img]
fidot
Posted: Fri Aug 16, 2019 4:47 pm Post subject: Re: Flaky EGT Probe |
Art,
For what it's worth, when I had a similar problem on my EI Engine Monitor, it turned out to be the bad input channel rather than probe. I'd start with trying to move it to another channel (ie, swap two probes) and seeing what happens... unless you've already done that...
Posted: Sat Aug 17, 2019 5:39 pm Post subject: Flaky EGT Probe |
The Lycoming operating manual says:
| Quote: | LEANING WITH MANUAL MIXTURE CONTROL. (Economy cruise, 75% power or less, without flowmeter or EGT gauge.)
<snip>
Fuel Injected Engines.
(1) Slowly move mixture control from “Full Rich” position toward lean position.
(2) Continue leaning until slight loss of power is noted (loss of power may or may not be accompanied by roughness.
(3) Enrich until engine runs smoothly and power is regained. |
I tried this method and compared the results with using the EGT (also per Lycoming's operating manual). I got the same fuel flow both ways.
I learned the manual method in airplanes that lacked an EGT probe on each cylinder. It's quick and doesn't require me to interrupt my scan.
-- Art Z.
On Fri, Aug 16, 2019 at 1:18 AM Bob Verwey <bob.verwey(at)gmail.com (bob.verwey(at)gmail.com)> wrote:
| Quote: | Hi Art
| Quote: | Folks,
-- Art Z.
Best...Bob Verwey
082 331 2727
Posted: Sun Aug 18, 2019 4:23 am Post subject: Flaky EGT Probe |
Jared,
Yes, indeed; I did appreciate that. I would have replaced flaky connectors, too.
I have an MGL system so the only connectors in the EGT circuit are the screw terminals on the RDAC.
-- Art Z.
On Thu, Aug 15, 2019 at 10:46 PM Jared Yates <email(at)jaredyates.com (email(at)jaredyates.com)> wrote:
On August 15, 2019 23:05:01 Art Zemon <art(at)zemon.name (art(at)zemon.name)> wrote: | Quote: | Folks,
-- Art Z.
Posted: Sun Aug 18, 2019 4:29 am Post subject: Flaky EGT Probe |
Good thought. I can easily try that since I have several unused channels.
-- Art Z.
On Fri, Aug 16, 2019 at 8:03 PM fidot <web(at)79ft.net (web(at)79ft.net)> wrote:
| Quote: | --> AeroElectric-List message posted by: "fidot" <web(at)79ft.net (web(at)79ft.net)>
Art,
For what it's worth, when I had a similar problem on my EI Engine Monitor, it turned out to be the bad input channel rather than probe. I'd start with trying to move it to another channel (ie, swap two probes) and seeing what happens... unless you've already done that... |
skywagon185(at)gmail.com Guest
Posted: Sun Aug 18, 2019 10:46 am Post subject: Flaky EGT Probe |
Art,
About the leaning steps....
I would suggest one additional comment/step:
As one pulls the Mixture knob for leaning, when you get near peak EGT, one should develop a habit of "zipping" thru peak and getting on the lean side as quickly as possible.
When on the rich side and coming up on Peak EGT, there is a region most prone to cause engine problems; pinging, detonation, etc. depending on power setting, atmospherics, etc.. That region should be not lingered in. Getting into the lean side does a nice job of cooling and cruise economy. After some practice in noting where the mixture knob sits in lean mode, one can do a fast "pull" from rich to lean, and then use EGT or CHT to set the final mixture for lean cruise.
On Sat, Aug 17, 2019 at 6:45 PM Art Zemon <art(at)zemon.name (art(at)zemon.name)> wrote:
| Quote: | Bob,
<snip>
-- Art Z.
| Quote: | Hi Art
| Quote: | Folks,
-- Art Z.
Best...Bob Verwey
082 331 2727
Kellym
Posted: Sun Aug 18, 2019 11:13 am Post subject: Flaky EGT Probe |
Whether going slow or fast through peak area is highly dependent on the
power setting in use at the time. If 65% or less, it is immaterial
whether you go slow or fast, you won't hurt anything. Generally more
desirable to establish peak at 65%, then adjust to final power you
desire with throttle.
Otherwise, as you say, establish a known fuel flow that is assured to be
LOP for the power setting, go straight from rich to that setting, and
then find peak from the lean side, knowing the first to reach peak will
be the richest cylinder and the rest are leaner.
On 8/18/2019 11:44 AM, skywagon185guy . wrote:
| Quote: | Art,
<mailto:art(at)zemon.name>> wrote:
<snip>
lean position.
of power may or may not beaccompanied by roughness.
both ways.
-- Art Z.
<mailto:bob.verwey(at)gmail.com>> wrote:
Hi Art
Folks,
be a green bar.
-- Art Z.
Egypt. /Deut. 10:19
Best...
Bob Verwey
082 331 2727
/Deut. 10:19
KCHD |
ceengland7(at)gmail.com Guest
Posted: Sun Aug 18, 2019 11:16 am Post subject: Flaky EGT Probe |
That's been recommended by some of the 'big names', and makes some sense.
But my recent experience with a new-to-me RV-6 with a ~15+ year old Dynon
engine monitor is that a 'quick pull' seems to confuse its lean function,
and it can't seem to detect lean of peak. That also makes some intuitive
sense, since EGT never really 'peaks'. Anyone have this experience with
later engine monitors?
Art, if the probe does turn out to be bad, do some ebay deep diving. If
you're willing to wait a few weeks (and you're not hung up on "buy
'Murcun", there are some good deals on Chinese probes.
On Sun, Aug 18, 2019 at 1:51 PM skywagon185guy . <skywagon185(at)gmail.com>
wrote:
[quote] Art,
Posted: Sun Aug 18, 2019 12:40 pm Post subject: Flaky EGT Probe |
Gents,
I encourage both of you to read the Lycoming operator's manual for the O-360 and IO-360. You can download it here: https://www.lycoming.com/sites/default/files/O-HO-IO-HIO-AIO%20%26%20TIO-360%20Oper%20Manual%2060297-12.pdf
The document is quite specific about how to lean the engine and when running LOP is permissible and how much hotter than peak.
Executive summary:
- 75% power or greater, run at peak EGT
- less than 75% power, run up to 150 degrees F lean of peak
-- Art Z.
On Sun, Aug 18, 2019 at 2:28 PM Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
> Art,
> or CHT to set the final mixture for lean cruise. |
chuckryan4(at)gmail.com Guest
Posted: Sun Aug 18, 2019 12:54 pm Post subject: Flaky EGT Probe |
On Sun, Aug 18, 2019 at 2:45 PM Art Zemon <art(at)zemon.name (art(at)zemon.name)> wrote:
| Quote: | Gents,
Executive summary:
-- Art Z.
> Art,
Posted: Sun Aug 18, 2019 1:54 pm Post subject: Flaky EGT Probe |
Art, my copy flips that:
[img]cid:ii_jzhhrik50[/img]
Operating at or above 75% at peak egt is generally considered to be hazardous to exhaust valves. Under 75% makes peak operation ok, as mentioned in the document. The doc doesn't seem to address lean of peak; not surprising since it's almost 15 years old. IIRC, there are Lyc docs with later publication dates that hedge a bit on that 75%/peak statement, but virtually no one operates there, anyway. Almost nothing is lost by going 20-30 lean of peak, assuming mixture distribution allows it.
On Sun, Aug 18, 2019 at 3:45 PM Art Zemon <art(at)zemon.name (art(at)zemon.name)> wrote:
| Quote: | Gents,
Executive summary:
-- Art Z.
> Art,
29.6 KB |
17285 Time(s) |
