Handheld Comm Interference In Flight
art(at)zemon.name
PostPosted: Sun Aug 04, 2019 5:25 am    Post subject: Handheld Comm Interference In Flight Reply with quote
During my flight home from AirVenture, I decided to test my handheld radio in flight. There was so much hum that it was unusable. This was a low-ish frequency hum, not pulsing. Definitely not what I have heard in the past as a higher frequency "alternator whine."
Here are the details:
I have the Yaesu Vertext FTA 550 handheld VHF radio. It works great on the ground.
I plugged in the Yaesu headset adapter into the radio. I plugged my headset into the adapter.
I have a second comm antenna on the airplane but, since the second comm radio is not installed, I have the coax with BNC connector readily available under the front of the instrument panel. I connected the second comm antenna to the handheld. The two comm antennas are mounted on top of the airplane, about 3 feet apart.
I tuned to a nearby ASOS. The audio was buried under such a loud hum that I could barely hear it. I tried a different ASOS; same result. I turned off the comm radio in my panel and the hum was still present. I did not try transmitting.
The in-panel comm radio (a VAL COM 2000) does not have any hum.
Other devices in the airplane which were turned on at the time:
  • Lycoming engine with primary and backup B&C alternators with B&C voltage regulators. Ignition is from two newly rebuilt magnetos.
  • PS Engineering audio panel.
  • VAL NAV 2000 VOR/ILS/GS receiver.
  • AeroLEDS landing lights on wig-wag
  • AeroLEDS Pulsar NSP wingtip lights with strobes on but nav/position lights off.
  • MGL iEFIS system
  • iPad and smartphone
What ideas do you have? Carrying a handheld radio for backup communication is kind of pointless if I can't communicate with it.
    -- Art Z.
https://CheerfulCurmudgeon.com/Love the stranger for you yourselves were strangers in Egypt. Deut. 10:19
jmackenzie52(at)outlook.c
PostPosted: Sun Aug 04, 2019 5:43 am    Post subject: Handheld Comm Interference In Flight Reply with quote
Please remove me from email list!
From: owner-aeroelectric-list-server(at)matronics.com <owner-aeroelectric-list-server(at)matronics.com> on behalf of Art Zemon <art(at)zemon.name>
Sent: Sunday, August 4, 2019 7:23 AM
To: aeroelectric-list(at)matronics.com <aeroelectric-list(at)matronics.com>
Subject: Handheld Comm Interference In Flight
  • MGL iEFIS system
-- Art Z.
https://CheerfulCurmudgeon.com/ Love the stranger for you yourselves were strangers in Egypt. Deut. 10:19
ceengland7(at)gmail.com
PostPosted: Sun Aug 04, 2019 5:54 am    Post subject: Handheld Comm Interference In Flight Reply with quote
On Sun, Aug 4, 2019 at 8:30 AM Art Zemon <art(at)zemon.name (art(at)zemon.name)> wrote:
  • MGL iEFIS system
    -- Art Z.
Hmmm (pardon the pun).
More details?
Was the handheld powered from ship's power or its internal batteries?
Did you try it with the handheld's rubber ducky antenna?
Does 'on the ground' mean without the engine running & everything powered off except the handheld?
Have you tested sitting on the ground with engine running and normal stuff powered up as typical for flight?
If you get the same noise in the above condition, I'd try shutting stuff down one at a time until everything's off or until the hum stops.
chaskuss(at)yahoo.com
PostPosted: Sun Aug 04, 2019 6:00 am    Post subject: Handheld Comm Interference In Flight Reply with quote
Art,
Do you get the hum if you use the Rubber Ducky antenna?
On Sunday, August 4, 2019, 9:39:49 AM EDT, Art Zemon <art(at)zemon.name> wrote:
  • MGL iEFIS system
-- Art Z.
Kellym
PostPosted: Sun Aug 04, 2019 6:05 am    Post subject: Handheld Comm Interference In Flight Reply with quote
All good suggestions. I'll add turn off your phone and Ipad, remove any
power adapters for them from 12 volt sockets. They are all known RF
generators.
* Lycoming engine with primary and backup B&C alternators with B&C
* PS Engineering audio panel.
* VAL NAV 2000 VOR/ILS/GS receiver.
* AeroLEDS landing lights on wig-wag
* AeroLEDS Pulsar NSP wingtip lights with strobes on but
* MGL iEFIS system
* iPad and smartphone
    -- Art Z.
More details?
Kelly McMullen
KCHD
PostPosted: Sun Aug 04, 2019 10:16 am    Post subject: Handheld Comm Interference In Flight Reply with quote
Please remove my email from the list.
From: owner-aeroelectric-list-server(at)matronics.com <owner-aeroelectric-list-server(at)matronics.com> on behalf of Kelly McMullen <kellym(at)aviating.com>
Sent: Sunday, August 4, 2019 8:03 AM
Subject: Re: Handheld Comm Interference In Flight
--> AeroElectric-List message posted by: Kelly McMullen <kellym(at)aviating.com>
generators.
> * MGL iEFIS system
> -- Art Z.
> More details?
> Charlie
ric-List Email Forum -
Electric-List">http://www.matronics.com/Navigator?AeroElectric-List
p; - MATRONICS WEB FORUMS -
ums.matronics.com
p; - NEW MATRONICS LIST WIKI -
matronics.com
p; - List Contribution Web Site -
p;   -Matt Dralle, List Admin.
From: owner-aeroelectric-list-server(at)matronics.com <owner-aeroelectric-list-server(at)matronics.com> on behalf of Charles Kuss <chaskuss(at)yahoo.com>
Sent: Sunday, August 4, 2019 7:58 AM
Art,
  • MGL iEFIS system
-- Art Z.
