freedom4life(at)xtra.co.n Guest
briana(at)xtra.co.nz Guest
Posted: Mon Jul 01, 2019 10:31 pm Post subject: Original Mufflers |
It was Rick Thomason who designed and made the alternative version. Quite a long time ago now, but I think he may also have published some drawings so that builders could make a copy.
Rick used to be active on this forum. It is also possible to find his email address with a quick name search.
Brian
| Quote: | On 2/07/2019, at 1:13 PM, Cliff McChesney <freedom4life(at)xtra.co.nz> wrote:
Hi Mark
I know exactly what you are talking about with cracked mufflers all the time. I copied what one of the builders on here had done and now have over 2000 hours on these now without any further cracking. Someone on the forum will tell you who made them. If you have someone who is good with a tig welder on stainless you shouldn't have too much bother making some yourself like I did.
Cliff
> Hey guys,
> I have the original exhaust mufflers from 1994 kit - first flight 1996. Over the years I have had them crack 4 times but the most recent has been twice within 8 hours
> I have added gussets to strengthen them and a bar stock connecting the muffler to the engine to sync vibration with the motor many years ago. This has worked great for 7-8 year blocks..I put in a new radiator on last year. The old one required the coolant hose to sit against the exhaust. I built a ventilation path to keep it cool that worked.
> Anyway the new radiator doesn't have that rubber hose to dampen the vibration so I think that is the change that caused 2 failures back to back.
> Now there isn't really enough basic metal to weld to anymore
> I know a decade or so ago this group was working on stainless steel ones with some moderate luck.
> Bottom line - what is everyone using now for the pulsar XP exhaust? Did someone finally find a design at works and has them for sale ?
> Thanks
> Mark L. Fox
This email has been checked for viruses by AVG.
https://www.avg.com
| | - The Matronics Pulsar-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Pulsar-List |
MikeyC
Posted: Tue Jul 02, 2019 5:06 am Post subject: Original Mufflers |
Mark,
I have a muffler from a Skystar FWF kit. Not planning to use it.
Mike Cowan
On Tue, Jul 2, 2019 at 2:34 AM Brian Anderson <briana(at)xtra.co.nz (briana(at)xtra.co.nz)> wrote:
| Quote: | --> Pulsar-List message posted by: Brian Anderson <briana(at)xtra.co.nz (briana(at)xtra.co.nz)>
Brian
> On 2/07/2019, at 1:13 PM, Cliff McChesney <freedom4life(at)xtra.co.nz (freedom4life(at)xtra.co.nz)> wrote:
> --> Pulsar-List message posted by: Cliff McChesney <freedom4life(at)xtra.co.nz (freedom4life(at)xtra.co.nz)>
> Hi Mark
> Cliff
>> Hey guys,
>> Thanks
>> Mark L. Fox
> https://www.avg.com
ar-List" target="_blank" rel="noreferrer">http://www.matronics.com/Navigator?Pulsar-List
_blank" rel="noreferrer">http://forums.matronics.com
lank" rel="noreferrer">http://wiki.matronics.com
target="_blank" rel="noreferrer">http://www.matronics.com/contribution
_________________ Mike Cowan |
DiscoverPulsar
Posted: Tue Jul 02, 2019 6:19 am Post subject: Original Mufflers |
Hi Mark,
There is a Yahoo Pulsar Group with drawings of Rick Thomson’s exhaust. Here is the link to the first drawing but you may need to join the group to access it. I’m not sure.
Hope this helps,
Ned
https://xa.yimg.com/df/Pulsar-Aviators/Pulsar+Exhaust+drawings_0001.jpg?token=GuvANfOvM09_lrPWgTwlKBFRJkMD8F2hZVUAiBZkm3sTDdoufsx3aOujQeX6BQiQVm7L4Y6_xcqqxUX2MozaIpjQllUI8bwXwgcZqX6153sNpFqUYzNWr6JDkiRqNgv2PUp1YZLEnifEWCfhWAhB72wIb4cB51fgLqUvlLpJquIWzqzmwBnmABA&type=download
On Jul 1, 2019, at 6:03 PM, Mark Fox <saafbusiness(at)gmail.com (saafbusiness(at)gmail.com)> wrote:
Hey guys,
Mark L. Fox
DiscoverPulsar
Posted: Tue Jul 02, 2019 6:24 am Post subject: Original Mufflers |
Here is the group home page
https://groups.yahoo.com/neo/groups/Pulsar-Aviators/info
And here are the 3 photos of Thompson’s drawings
[img]cid:252B6553-7DE3-49DF-AAF2-7C9BD925693A[/img][img]cid:7787096E-A59B-4D68-8883-C2F5B68A8094[/img][img]cid:176A3E68-8F05-40F5-9AED-DE551C1D1932[/img]
Hey guys,
Mark L. Fox
1.13 MB |
23367 Time(s) |
1020.68 KB |
23367 Time(s) |
2.13 MB |
23367 Time(s) |
kenw
Joined: 01 Oct 2015 Posts: 25 Location: Oklahoma City
Posted: Fri Feb 12, 2021 2:48 pm Post subject: Re: Original Mufflers |
Do any members have pics of Rick Thomason mufflers .?
Thank you in advance.
_________________ kenw |
ghf4986(at)gmail.com Guest
Posted: Fri Feb 12, 2021 3:28 pm Post subject: Original Mufflers |
Knew,
There was an engineering drawing made and it is in the files, unfortunately I can not direct you to it but you should be able to find it.
Dennis
Sent from an IPad
kenw
http://forums.matronics.com/viewtopic.php?p=500661#500661
phil(at)ishml.com Guest
Posted: Fri Feb 12, 2021 3:33 pm Post subject: Original Mufflers |
Drawings and pics are at the groups.io site...
https://groups.io/g/Pulsar-Aviators
Phil
kenw
Posted: Fri Feb 12, 2021 3:40 pm Post subject: Re: Original Mufflers |
Thank you Sir ! That’s helpful.
I was able to find 1 pic.
31.72 KB |
20872 Time(s) |
Eclat2
Joined: 06 Sep 2013 Posts: 13 Location: Minneapolis, Minnesota, USA
Posted: Fri Feb 12, 2021 3:47 pm Post subject: Original Mufflers |
Look in the Photos section. The 2nd folder is "Exhaust", and I just put 3 JPEGs in there. They're sketches of Ricky Thomason's exhaust for the 912.
It made more sense to me to put them in the Files section, since they were more 'tech' than 'pretty'. But the system wouldn't allow 'photos' in the Files section, and told me to put them in the Photos section.
Tim Engel
Eclat2
Posted: Fri Feb 12, 2021 4:08 pm Post subject: Original Mufflers |
I just did a little browse of the Files section on Groups.io, and found duplicates of the three sketches that I just uploaded in the Photos section.
Photos:
https://groups.io/g/Pulsar-Aviators/album?id=260646
Or, go to 'Files. Then scroll down & open the "Modification - Airframe & Engine" folder, and finally, open the "Exhaust - 912 XP by Ricky Thomason" folder.
Files:
https://groups.io/g/Pulsar-Aviators/files/Modification%20-%20Airframe%20&%20Engine
They're large files, burning up storage space. So rather than leaving duplicates, I'll delete mine from the 'Photos' section in a few days... after Ken has had a chance to find & download what he needs.
Tim Engel
02/12/2021, 5:45PM, Tim Engel, tsengel(at)comcast.net wrote:
Tim Engel
