Original Mufflers
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pulsar-List
freedom4life(at)xtra.co.n
PostPosted: Mon Jul 01, 2019 9:14 pm    Post subject: Original Mufflers Reply with quote
Hi Mark
I know exactly what you are talking about with cracked mufflers all the
time. I copied what one of the builders on here had done and now have
over 2000 hours on these now without any further cracking. Someone on
the forum will tell you who made them. If you have someone who is good
with a tig welder on stainless you shouldn't have too much bother making
some yourself like I did.
Cliff
Hey guys,
I have the original exhaust mufflers from 1994 kit - first flight
1996. Over the years I have had them crack 4 times but the most recent
has been twice within 8 hours Sad
I have added gussets to strengthen them and a bar stock connecting the
muffler to the engine to sync vibration with the motor many years ago.
This has worked great for 7-8 year blocks..I put in a new radiator on
last year. The old one required the coolant hose to sit against the
exhaust. I built a ventilation path to keep it cool that worked.
Anyway the new radiator doesn't have that rubber hose to dampen the
vibration so I think that is the change that caused 2 failures back to
back.
Now there isn't really enough basic metal to weld to anymore Sad
I know a decade or so ago this group was working on stainless steel
ones with some moderate luck.
Bottom line -  what is everyone using now for the pulsar XP exhaust?
Did someone finally find a design at works and has them for sale ?
Mark L. Fox
This email has been checked for viruses by AVG.
https://www.avg.com
- The Matronics Pulsar-List Email Forum -
http://www.matronics.com/Navigator?Pulsar-List
briana(at)xtra.co.nz
PostPosted: Mon Jul 01, 2019 10:31 pm    Post subject: Original Mufflers Reply with quote
It was Rick Thomason who designed and made the alternative version. Quite a long time ago now, but I think he may also have published some drawings so that builders could make a copy.
Rick used to be active on this forum. It is also possible to find his email address with a quick name search.
Brian
On 2/07/2019, at 1:13 PM, Cliff McChesney <freedom4life(at)xtra.co.nz> wrote:
Hi Mark
I know exactly what you are talking about with cracked mufflers all the time. I copied what one of the builders on here had done and now have over 2000 hours on these now without any further cracking. Someone on the forum will tell you who made them. If you have someone who is good with a tig welder on stainless you shouldn't have too much bother making some yourself like I did.
Cliff
> Hey guys,
> I have the original exhaust mufflers from 1994 kit - first flight 1996. Over the years I have had them crack 4 times but the most recent has been twice within 8 hours Sad
> I have added gussets to strengthen them and a bar stock connecting the muffler to the engine to sync vibration with the motor many years ago. This has worked great for 7-8 year blocks..I put in a new radiator on last year. The old one required the coolant hose to sit against the exhaust. I built a ventilation path to keep it cool that worked.
> Anyway the new radiator doesn't have that rubber hose to dampen the vibration so I think that is the change that caused 2 failures back to back.
> I know a decade or so ago this group was working on stainless steel ones with some moderate luck.
> Bottom line - what is everyone using now for the pulsar XP exhaust? Did someone finally find a design at works and has them for sale ?
> Thanks
> Mark L. Fox
https://www.avg.com
MikeyC
PostPosted: Tue Jul 02, 2019 5:06 am    Post subject: Original Mufflers Reply with quote
Mark,
I have a muffler from a Skystar FWF kit.  Not planning to use it.
Mike Cowan
On Tue, Jul 2, 2019 at 2:34 AM Brian Anderson <briana(at)xtra.co.nz (briana(at)xtra.co.nz)> wrote:
--> Pulsar-List message posted by: Brian Anderson <briana(at)xtra.co.nz (briana(at)xtra.co.nz)>
Brian
> On 2/07/2019, at 1:13 PM, Cliff McChesney <freedom4life(at)xtra.co.nz (freedom4life(at)xtra.co.nz)> wrote:
> --> Pulsar-List message posted by: Cliff McChesney <freedom4life(at)xtra.co.nz (freedom4life(at)xtra.co.nz)>
> Hi Mark
> Cliff
>> Hey guys,
>> Thanks
>> Mark L. Fox
> https://www.avg.com
ar-List" target="_blank" rel="noreferrer">http://www.matronics.com/Navigator?Pulsar-List
_blank" rel="noreferrer">http://forums.matronics.com
lank" rel="noreferrer">http://wiki.matronics.com
target="_blank" rel="noreferrer">http://www.matronics.com/contribution
Mike Cowan
DiscoverPulsar
PostPosted: Tue Jul 02, 2019 6:19 am    Post subject: Original Mufflers Reply with quote
Hi Mark,
There is a Yahoo Pulsar Group with drawings of Rick Thomson’s exhaust. Here is the link to the first drawing but you may need to join the group to access it. I’m not sure.
Hope this helps,
Ned
https://xa.yimg.com/df/Pulsar-Aviators/Pulsar+Exhaust+drawings_0001.jpg?token=GuvANfOvM09_lrPWgTwlKBFRJkMD8F2hZVUAiBZkm3sTDdoufsx3aOujQeX6BQiQVm7L4Y6_xcqqxUX2MozaIpjQllUI8bwXwgcZqX6153sNpFqUYzNWr6JDkiRqNgv2PUp1YZLEnifEWCfhWAhB72wIb4cB51fgLqUvlLpJquIWzqzmwBnmABA&type=download
On Jul 1, 2019, at 6:03 PM, Mark Fox <saafbusiness(at)gmail.com (saafbusiness(at)gmail.com)> wrote:
Hey guys,
Mark L. Fox
DiscoverPulsar
PostPosted: Tue Jul 02, 2019 6:24 am    Post subject: Original Mufflers Reply with quote
Here is the group home page
https://groups.yahoo.com/neo/groups/Pulsar-Aviators/info
And here are the 3 photos of Thompson’s drawings
[img]cid:252B6553-7DE3-49DF-AAF2-7C9BD925693A[/img][img]cid:7787096E-A59B-4D68-8883-C2F5B68A8094[/img][img]cid:176A3E68-8F05-40F5-9AED-DE551C1D1932[/img]
Hey guys,
Mark L. Fox
 Filesize:  1.13 MB
 Viewed:  23242 Time(s)
 Filesize:  1020.68 KB
 Filesize:  2.13 MB
kenw
PostPosted: Fri Feb 12, 2021 2:48 pm    Post subject: Re: Original Mufflers Reply with quote
Do any members have pics of Rick Thomason mufflers .?
Thank you in advance.
kenw
ghf4986(at)gmail.com
PostPosted: Fri Feb 12, 2021 3:28 pm    Post subject: Original Mufflers Reply with quote
Knew,
There was an engineering drawing made and it is in the files, unfortunately I can not direct you to it but you should be able to find it.
Dennis
Sent from an IPad
kenw
http://forums.matronics.com/viewtopic.php?p=500661#500661
phil(at)ishml.com
PostPosted: Fri Feb 12, 2021 3:33 pm    Post subject: Original Mufflers Reply with quote
Drawings and pics are at the groups.io site...
https://groups.io/g/Pulsar-Aviators
Phil
kenw
PostPosted: Fri Feb 12, 2021 3:40 pm    Post subject: Re: Original Mufflers Reply with quote
Thank you Sir ! That’s helpful.
I was able to find 1 pic.
 Filesize:  31.72 KB
 Viewed:  20747 Time(s)
kenw
Eclat2
PostPosted: Fri Feb 12, 2021 3:47 pm    Post subject: Original Mufflers Reply with quote
Look in the Photos section. The 2nd folder is "Exhaust", and I just put 3 JPEGs in there. They're sketches of Ricky Thomason's exhaust for the 912.
It made more sense to me to put them in the Files section, since they were more 'tech' than 'pretty'. But the system wouldn't allow 'photos' in the Files section, and told me to put them in the Photos section.
Tim Engel
Phil
Eclat2
PostPosted: Fri Feb 12, 2021 4:08 pm    Post subject: Original Mufflers Reply with quote
I just did a little browse of the Files section on Groups.io, and found duplicates of the three sketches that I just uploaded in the Photos section.
Photos:
https://groups.io/g/Pulsar-Aviators/album?id=260646
Or, go to 'Files. Then scroll down & open the "Modification - Airframe & Engine" folder, and finally, open the "Exhaust - 912 XP by Ricky Thomason" folder.
Files:
https://groups.io/g/Pulsar-Aviators/files/Modification%20-%20Airframe%20&%20Engine
They're large files, burning up storage space. So rather than leaving duplicates, I'll delete mine from the 'Photos' section in a few days... after Ken has had a chance to find & download what he needs.
Tim Engel
Tim Engel
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pulsar-List All times are GMT - 8 Hours
