Viperdoc
Posted: Fri Mar 29, 2019 6:02 am Post subject: Covering Ailerons of YAK |
Anybody done their on fabric on the YAK or CJ?
Doc
_________________ Viperdoc |
wlannon(at)shaw.ca Guest
Posted: Fri Mar 29, 2019 10:02 am Post subject: Covering Ailerons of YAK |
Do yourself a huge favor Doc. Hire a pro.
Cheers;
Walt
cjpilot710(at)aol.com Guest
Viperdoc
Posted: Sat Mar 30, 2019 6:43 pm Post subject: Covering Ailerons of YAK |
To late Walt. I have one Aileron left to cover. 🤪
Doc
[quote] On Mar 29, 2019, at 12:57 PM, Walter Lannon <wlannon(at)shaw.ca> wrote:
Cheers;
Walt
Posted: Sat Mar 30, 2019 7:47 pm Post subject: Covering Ailerons of YAK |
That's great Doc. Hope it all works out well for you.
Walt
Viperdoc
Posted: Sun Mar 31, 2019 5:12 am Post subject: Covering Ailerons of YAK |
Walt,
Have had a great deal of help from 3 EAA gurus on stick and fabric airplanes. A lot of tricks learned from those 3.
It is a good thing I undertook this project. There were three cracked ribs along with the trailing edge that were almost completely broken through. The two worst were where the trim tab mounted. I now know why I had a ratcheting right snap roll.
To stiffen it some RU Afro engineer put a strip of 1/8 inch x 1 inch flat plate steel 1/2 of the length of the trailing edge. None of that mod was found in the right aileron.
It was a good thing I tore it down. That one was about to test my piloting skills.
Doc
[quote] On Mar 30, 2019, at 10:47 PM, Walter Lannon <wlannon(at)shaw.ca> wrote:
Walt
Viperdoc
Posted: Sun Mar 31, 2019 5:28 am Post subject: Covering Ailerons of YAK |
Walt,
This is a pics of my rudder getting the MEK wipe down before applying poly spray. My tail feathers are poly sprayed now hanging on a rack in my hanger awaiting the fourth coat of poly spray. Then I will paint them. ( with the help of my EAA gurus). 😜🥴
Walt
286.24 KB |
27882 Time(s) |
stephen.hayne
Joined: 01 Nov 2013 Posts: 59 Location: United States
Posted: Sun Mar 31, 2019 7:06 pm Post subject: Re: Covering Ailerons of YAK |
I had never done this before, and I did mine with the oversight of an EAA guru too. It was so cool to learn how to do this!
I could have done them better, but hey, 100 hours and they still look good. I also had a cracked trailing edge that I fixed. Here is a link to my "New Fabric" album...
https://photos.app.goo.gl/AnatC9pxLqJFNSxE9
_________________ -
Stephen Hayne, Cyber Security Consultant, Professor Emeritus (retired)
443LM Nanchang CJA
http://selfsynchronize.com/hayne/plane/cj6.asp |
draftsjust417(at)gmail.co Guest
Posted: Mon Apr 01, 2019 5:49 am Post subject: Covering Ailerons of YAK |
Wow, pix look great!How long did you invest in this project?
Just curious---
Justin
N280NC
On Sun, Mar 31, 2019 at 11:11 PM stephen.hayne <stephen.hayne(at)gmail.com (stephen.hayne(at)gmail.com)> wrote:
| Quote: | --> Yak-List message posted by: "stephen.hayne" <stephen.hayne(at)gmail.com (stephen.hayne(at)gmail.com)>
Dr. Stephen C. Hayne, Professor, CIS, Colorado State University
666CJA
http://forums.matronics.com/viewtopic.php?p=488391#488391
Posted: Mon Apr 01, 2019 8:21 am Post subject: Covering Ailerons of YAK |
Steven,I noted that you repaired the damaged trailing edge of your rudder. Should you have the need for this type of repair in the future, note that we carry this trailing edge in stock. Good looking job!!
Best,
Doug
On Sun, Mar 31, 2019 at 8:11 PM stephen.hayne <stephen.hayne(at)gmail.com (stephen.hayne(at)gmail.com)> wrote:
666CJA
Viperdoc
Posted: Mon Apr 01, 2019 2:49 pm Post subject: Covering Ailerons of YAK |
Sweet!
Doc
stephen.hayne
Posted: Tue Apr 09, 2019 7:31 pm Post subject: Re: Covering Ailerons of YAK |
| draftsjust417(at)gmail.co wrote: | Wow, pix look great!How long did you invest in this project?
Hey - thanks. IIRC, took me a month or so in the summer, working fairly sporadically while waiting for things to dry/cure, get the correct color shade for final coat, etc.
One thing I wish I had paid more attention to, is getting the tape to settle "down" over or into the rib lacing/sewing "channel". Much of it has a bit of a bubble the channel. It is well secured, but not beautifully level as some other work I have seen. Next time... !!
_________________ -
443LM Nanchang CJA
Rich Langer
Posted: Thu Nov 28, 2019 8:12 am Post subject: Re: Covering Ailerons of YAK |
Stephen , I am recovering my flight controls and I would like to know how you did the stitching. We can not figure out how the chinese got the knots tied after the fabric was put on. See pictures attached.
Also what weight fabric did you use. Thanks.
Rich
2.13 MB |
26904 Time(s) |
2.23 MB |
26904 Time(s) |
stephen.hayne
Posted: Thu Nov 28, 2019 10:31 am Post subject: Re: Covering Ailerons of YAK |
Just curious---
Justin
N280NC
Sorry to take so long to reply, I missed your question. The whole airplane re-assembly and refurbish (from pieces!) took about 4.5 years, of part time work. The web link below shows some pics trailering it to flying it...
For the recover, I used Poly-Fiber medium fabric and Stits P103 tapes. As far as stitching, my faint memory is that I would run a up/down loop through a couple holes, tie it off really close to a hole, and then repeat in such a way that as I was pulling the next stitch, if I pulled a little bit "taught", I could pull the knot under/through the hole and everything would tighten up... hard to explain. I might have a document/image of the stitching process somewhere. I will look in the fabric box and see if it is tucked in there with the Poly-Fiber instruction booklet.
_________________ -
443LM Nanchang CJA
A35plt
Joined: 14 Aug 2013 Posts: 9 Location: Wiesbaden, Germany
Posted: Fri Nov 29, 2019 6:42 pm Post subject: Re: Covering Ailerons of YAK |
IIRC the book on doing Poly Fiber covering showed exactly how to tie the knot with pictures and diagrams. I don't remember any substantial difference in the knot used by Poly Fiber vs. The Chinese knot. When done correctly the knot will be pulled under the surface of the fabric when tightened leaving a smooth finish.
Experimenting with the Poly Fiber process pays good dividends before doing it for real. I don't remember the name of the pink sealer used (poly coat?) but thinning it out and spraying it on will result in much nicer looking fabric that doesn't need to be sanded versus brushing it on.
Fabric work is fun! -Robert Starnes CJ-6A N8016Q
Viperdoc
Posted: Sat Nov 30, 2019 11:21 am Post subject: Covering Ailerons of YAK |
Rich,
I know you did not. I use the Stits method Seine knot. Placed at 2 cm ~ 1 inch it is supposed to good for 220 kts. I never could get the RU method to cinch up. When I pulled the cotton of my controls they had some loose strands. With a knot at every loop it’s not going balloon.
259.77 KB |
26834 Time(s) |
Rich Langer
Posted: Sun Dec 01, 2019 5:31 am Post subject: Re: Covering Ailerons of YAK |
Thanks to Stephen, Robert and Doc for your advice and pictures.
Doc, what do you mean by the RU method? I have the PolyFiber book and am trying to understand the Seine knot. I will need lots of practice.
Robert, the spray on is called PolyBrush. I will keep this thread updated as to my progress.
GeorgeCoy
Posted: Sun Dec 01, 2019 6:51 am Post subject: Covering Ailerons of YAK |
Attached is a diagram of the "Russian" stitching sketched by non-other than
Jill when she worked for us in the late 1990's
George Coy
 Download |
| Filename: |
STICHING_DIAGRAM.pdf |
544.2 KB |
| Downloaded: |
925 Time(s) |
Viperdoc
Posted: Sun Dec 01, 2019 9:34 pm Post subject: Covering Ailerons of YAK |
Rich,
Russian method.
Do not dispose of the foam plugs that form the control push rod dams. Can not use the foam with MEK because it dissolves them. However you can use them to make fiber glass molds. I unfortunately threw mine away by mistake so I’m experimenting with forms to lay up fiber glass on.
Do a Stits Covering search on YouTube. Their young rep at does a great job of teach you with her rabbit running for the hole how to do the seine knot.
The STITS Covering Book leaves something to be desired. After watching the video you will be doing seine knots in your sleep.
| Quote: | On Dec 1, 2019, at 7:37 AM, Rich Langer <rlanger2(at)comcast.net> wrote:
http://forums.matronics.com/viewtopic.php?p=493698#493698
Rich Langer
Posted: Thu Dec 26, 2019 7:08 am Post subject: Re: Covering Ailerons of YAK |
Doc, thanks for the advice about the foam plugs. And thanks to George Coy for sending the stitching diagram. Everyone has been a great help.
Rich
