Starters
Steve Kelly
PostPosted: Wed Mar 13, 2019 7:00 am    Post subject: Starters Reply with quote
Can someone with more knowledge than me on the subject, tell me the difference between a series wound motor and a PM motor. Also, does the series wound have more torque. Is it more durable.
I have a Skytech PM on my O-320 thats getting a little sluggish on the initial turn of the prop. While I'm aware that there may be other causes, confidence that my engine will start reliably is important.
I have heard good things about B&Cs starters. While they're more expensive, I guess you get what you pay for.
Steve
Steve
PostPosted: Fri Mar 15, 2019 4:20 am    Post subject: Starters Reply with quote
At 10:00 AM 3/13/2019, you wrote:
--> AeroElectric-List message posted by: "Steve Kelly" <amsk22(at)gmail.com>
That's a question with a really big answer.
It fills a couple of volumes. It all depends
on the application. Series wound motors for
engine cranking are falling in popularity
for a host of interleaved trade-offs. Strong
influences on the shift to PM motors include
falling costs of rare earth magnets compared
to higher manufacturing costs for wound fields.
Wound field motors seem to find favor with
OEMs for diesel engines . . . a wound field
motor has a flatter speed torque curve
than PM motors under heavy load. They
generally outperform PM starters under
adverse conditions (cold, soggy battery,
high resistance in cranking loop).
[img]cid:.0[/img]
The downside of series wound motors include
poor load-speed regulation; an unloaded
PM motor has a limit on unloaded RPM.
A series wound motor's unloaded speed
is limited only by friction in the motor's
construction. Some designs are at risk
for self destruction if operated no-load.
There are a dozen trade-offs for deciding
which configuration to adopt for any given
application. Neither configuration is
'superior' to the other over the full
spectrum of operating characteristics.
Not 'more' but 'flatter' speed-torque
characteristics under heavy load . . .
Is it more durable
Not necessarily. Durability has more to
do with design details and manufacturing
quality than with choice of motors.
Motor condition is but one of several reasons
for sluggish performance. The weakest link
in cranking chain is battery condition.
Just for grins, jumper your car battery
to the ship's battery and see how the engine
cranks. If there is marked improvement,
consider load/capacity checking your battery.
A least likely reason for diminished
performance is an increased voltage
drop in cranking power loop.
[img]cid:.1[/img]
It's expected that voltage available at the starter
motor is lower than battery voltage. Just how much
lower has an effect on cranking speed. I'd carefully
check out the cranking power loop, ESPECIALLY the
battery, before swapping out the starter.
There were a number of discussions about the
differences for B&C versus other players
circa 1996. Here's one thread
https://tinyurl.com/y38w4ksz
In 23 years since, the various players
have had ample opportunity to secure their
position in the market based on perceived
value and demonstrated track record. Further,
I'm certain that many of the points cited
in the thread are not longer valid . . .
companies have changed hands and
sales volumes have promoted better
manufacturing techniques.
I have no recent knowledge of player
performance in today's starter market.
But I can share that Robinson Helicopter
was quite pleased with the performance
and weight advantages of the B&C
starters. They would swap B&C starters
onto brand new engines fitted with
factory supplied starters.
B&C would receive boxes of Robinson
starters pulled off engines taken
down for overhaul and returned for reman. No
matter how beat up and dirty the starters
were on the outside, the wearing parts
inside looked like they could go another
2,000 hours on the airplane.
I have no foundation to assert that
the major players do not offer good
value . . . but yes, in a free-market
competition for customers, you generally
do get what you pay for.
 Filesize:  25 KB
 Viewed:  12912 Time(s)
 Filesize:  129.21 KB
Steve Kelly
PostPosted: Fri Mar 15, 2019 9:21 am    Post subject: Starters Reply with quote
Bob,  Thank you for the reply.  I will try to get out to the hanger early next week and check the voltage readings.  The battery is a PC680 at three months old.   Do you have a method you would suggest to do a load/capacity check on it.Steve
On Fri, Mar 15, 2019 at 8:27 AM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
--> AeroElectric-List message posted by: "Steve Kelly" <amsk22(at)gmail.com (amsk22(at)gmail.com)>
[img]cid:16982567f58a8583ca21[/img]
 Is it more durable
[img]cid:16982567f58aa0d15412[/img]
 Filesize:  25 KB
 Viewed:  12909 Time(s)
 Filesize:  129.21 KB
Steve
argoldman(at)aol.com
PostPosted: Fri Mar 15, 2019 9:55 am    Post subject: Starters Reply with quote
While you are checking...check all of the cable connections for security and corrosionRich
On Mar 15, 2019, at 12:18 PM, Steve Kelly <amsk22(at)gmail.com (amsk22(at)gmail.com)> wrote:
<b1f680f.jpg>
Is it more durable
<b1f681f.jpg>
cluros(at)gmail.com
PostPosted: Fri Mar 15, 2019 11:17 am    Post subject: Starters Reply with quote
That is a very common battery, any battery store will test it for you.
On Fri, Mar 15, 2019, 13:31 Steve Kelly <amsk22(at)gmail.com (amsk22(at)gmail.com)> wrote:
 Is it more durable
 Filesize:  25 KB
 Viewed:  12906 Time(s)
 Filesize:  129.21 KB
Kellym
PostPosted: Fri Mar 15, 2019 12:38 pm    Post subject: Starters Reply with quote
Odyssey batteries are often prematurely aged by keeping on a battery
maintainer. If you contact Odyssey they can give you a rejuvenation
protocol to restore the battery to near full capacity. I'm at about 4
years on my Odyssey 925 in the Aridzona heat, and still working fine.
Steve
Kelly McMullen
KCHD
PostPosted: Sat Mar 16, 2019 6:06 am    Post subject: Starters Reply with quote
That's a pretty fresh battery . . . this suggests
the problem is elsewhere. However, in answer to
your testing questions, I'll suggest that
every owner of an aircraft should also own
something like this
https://tinyurl.com/yag4529y
This LOAD tester allows you to load the battery
to an output of 9 volts while waiting for the
15 second timer light to go out. Note the current
at the end of 15 seconds . . . it should be in
excess of 200A for small engines, 300A for larger
engines. This test confirms the battery's avbility
to grunt the extra-ordinary demands for cranking
the engine.
A CAPACITY test seeks to quantify the battery's
ENERGY content . . . which is entirely separate
from the capability to grunt a cranking load.
There are some rather small batteries that have
demonstrated the ability to crank a turbine
engine
https://tinyurl.com/yye6znqp
But this product wouldn't run the aircraft's
critical systems for very long after the
alternator quits. There are dozens of 'tiny'
products that offer a similar utility
https://tinyurl.com/y2hzkq9l
The way to cap check your battery is to set
up your panel to operate your Plan-B (alternator
out) electrical loads and monitor battery voltage
with a voltmeter. The time it takes to reduce
battery voltage to 10V (the lower limit for
your avionics to operate).
For example, a NEW PC680 has the following
ENERGY delivery capability.
[img]cid:.0[/img]
Assume a 4A endurance load. The curves say you're
good to 3 hours. Here you have to tailor the question
to match your own endurance requirements. If one hour
meets your own Plan-B design goals, then according
to the chart, the new battery is good for about 10A.
Actually, you would want to rate the battery for about
8A given that maintenance protocols suggest replacing
the battery at 75% of new capacity.
Then there's the real-life test . . . turn on the
goodies, start the clock, watch the voltage, measure
the time then recharge the battery. If that time
is equal to or greater than your design goals, then
you're good to fly.
How old is your starter? It MIGHT be that brushes
and/or commutator are worn to the point of producing
degraded performance.
 Filesize:  224.52 KB
 Viewed:  12897 Time(s)
Steve Kelly
PostPosted: Mon Mar 18, 2019 7:37 am    Post subject: Starters Reply with quote
Bob.  Thanks for the help.  I had a chance to do the voltage tests like you suggested.  They were fairly similar to your your're example.  While cranking the voltage at the battery was around 10.5 and at the starter it was between 7.5 and 8.5 volts.  I also acquired a load tester.  At the end of the 15 sec test current was about 330 amps.  Battery voltage dropped to 11.3 volts.  The starter is a Sky Tec 149xlt.  It's about 3 years old and has 170 hours on it.  This is probably the smallest starter Sky Tec makes.  Not sure if it's the weakest one.  Other contributing factors are cooler weather, fresh engine overhaul, and a lightweight prop.  Still, the starter should spin it better than it is.  Do worn starters draw the battery down faster?
  Also, just to be clear, replacing the battery at 75% refers to the time it takes to drop to 10 volts, correct?  In you're example above when the PC680 gets to 10v in 2.25 hours it's time to consider replacement.
 Steve
On Sat, Mar 16, 2019 at 10:13 AM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
something like this
the engine.
engine
[img]cid:169915204ebb1ccea621[/img]
you're good to fly.
 Filesize:  224.52 KB
 Viewed:  12871 Time(s)
Steve
millner(at)me.com
PostPosted: Mon Mar 18, 2019 9:19 am    Post subject: Starters Reply with quote
2-3 volts is a huge voltage drop. You need to determine where that’s happening... SkyTec has a troubleshooting chart to help you find the bad actor
On Mar 18, 2019, at 8:35 AM, Steve Kelly <amsk22(at)gmail.com (amsk22(at)gmail.com)> wrote:
Steve
something like this
the engine.
engine
<10a704b8.jpg>
you're good to fly.
PostPosted: Mon Mar 18, 2019 9:31 am    Post subject: Starters Reply with quote
Agreed. Use a voltmeter between
(1) battery(+) and starter power terminal
while cranking.
(2) battery(-) and crankcase.
Where is your battery located with respect
to starter i.e. how long are the wires
and what gage are they?
This is a NEW condition . . . used to crank
right smartly and only now sluggish?
Steve Kelly
PostPosted: Mon Mar 18, 2019 1:51 pm    Post subject: Starters Reply with quote
Bob,  The slow prop became more noticeable after rebuilding the engine last summer.  Fresh cylinders along with upping the compression ratio from 7 to 8.5.
  The battery and solenoids are located on the firewall.  So the cables are not very long.  Maybe 5' total and 2' for ground.  They are B&Cs 4 ga. weld cable.
  Looking at the measurements I made yesterday, the drop on the negative was small, maybe .3 volts.  The biggest drop was somewhere between the battery and in side of the starter solenoid.   10.5 volts down to around 8.  Didn't check either side of the battery contactor as the battery was getting low.  I have a brass strap that connects between the two contactors.  1/2' wide by about 4" long.  Do you think this may not be adequate.  Either that or the battery contactor.  I will check the voltages there when I get back out to the hanger.
 Thanks, Steve
On Mon, Mar 18, 2019 at 1:37 PM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
      while cranking.
Steve
Kellym
PostPosted: Mon Mar 18, 2019 6:03 pm    Post subject: Starters Reply with quote
Your compression change is not significant in terms of starter cranking.
A PC680 easily cranks an 0-360 with 8.5 compression.
Check to see that each connection is at proper torque at the max end of
scale for bolt size. Check the drop across the solenoid.
Now that you have run the battery down a fair amount, charge it at
around 3 amps until full charge. Should have a resting voltage of 12.9
to 13.0 four or more hours after off charger. If less, may need
rejuvenation through several discharge, charge cycles.
On 3/18/2019 2:49 PM, Steve Kelly wrote:
to 8.5.
ga. weld cable.
 Thanks, Steve
<nuckolls.bob(at)aeroelectric.com <mailto:nuckolls.bob(at)aeroelectric.com>>
      while cranking.
__
__   Bob . . .
Kelly McMullen
KCHD
