John M Tipton
Joined: 07 Aug 2018 Posts: 45 Location: Devon - England
Posted: Sat Jan 26, 2019 1:42 am Post subject: Garmin Aera660 powered from aircraft bus |
Hi Guys
We intend to mount a Garmin Aera660 semi potable GPS into our panel using an AirGizmo mount, so far so good, with the wiring pack comes a 'cigar socket' power plug, is it OK to cut this off and connect to the aircraft bus, or does the cigar plug actually have a voltage reduction circuit inside.
Regards: John
Posted: Sat Jan 26, 2019 8:36 am Post subject: Garmin Aera660 powered from aircraft bus |
At 03:42 AM 1/26/2019, you wrote:
| Quote: | --> AeroElectric-List message posted by: "John M Tipton" <john(at)tiptonuk.eu>
Hi Guys
Regards: John |
Appendix D of the users manual describes
this item:
[img]cid:.0[/img]
A 'bare' wire interface between the Aera660 and
ship's systems. Also, the manual speaks to an
internal, 3A fuse in the cigar-lighter plug.
This is a common connector to many automotive
add-ons. The fuse installation takes up a substantial
volume of the connector shell . . . it seems
very unlikely that it contains additional
electronics . . . a disassembly would confirm.
151.57 KB |
4745 Time(s) |
John M Tipton
Posted: Sat Jan 26, 2019 2:46 pm Post subject: Re: Garmin Aera660 powered from aircraft bus |
Hi Bob
I've managed to get hold of a Garmin GPS lead, and the plug that goes into the unit has four pins, two are dormant, the other two are 12v + & -, the cigar plug once dismantled has indeed a glass fuse link, so all good for 12v fused to the aircraft bus.
Which does raise one other question, the fuse looks like 1/4amp, how do I fuse this (and other items like 'steam gauge lighting') which have only light gauge wires, the smallest fuse available for the bus is 1amp
hlbartel(at)pld.com Guest
Posted: Sun Jan 27, 2019 6:18 am Post subject: Garmin Aera660 powered from aircraft bus |
John,
I'm not sure where you live, but you should be able to go to an electronics
store and find that fuse there. When I was still at the local airport as
manager, we installed an AWOS, and the phone line to it was fused with a
1/10 amp fuse. When we installed it to protect an ISI board ($300) we no
longer blew the board at evey thunderstorm. That 1/10 amp fuse was only $2,
and much easier to replace.
Harry
N0HQG
