Pat Hatch
Joined: 10 Jan 2006 Posts: 4 Location: Vero Beach, FL
Posted: Tue Mar 27, 2018 1:35 pm Post subject: Flap Switch |
Bob, perhaps you can help me find a SPDT (1-5) switch for flap control where the bat doesn't rotate. Years ago you published a piece on how to make a little flap lever out of a solid piece of aluminum that goes over the toggle and gets held there by a couple of set screws. The only ones I have found all have bats or toggles that rotate and this is not good. Do you recall which switch it was? Thanks!
_________________ RV-6
RV-7
Flying |
Flyitnow
JOHN TIPTON
Joined: 17 Sep 2006 Posts: 239 Location: Torquay - England
Pat Hatch
Posted: Tue Mar 27, 2018 3:54 pm Post subject: Re: Flap Switch |
Thanks, guys. Actually, I have the flap handle (toggle). I need the switch, one that has a bat that doesn't rotate. All the ones I've tried have a toggle that rotates in the switch such that the flap handle will not stay horizontal.
RV-7
Flying |
Posted: Wed Mar 28, 2018 4:49 am Post subject: Flap Switch |
At 05:13 PM 3/27/2018, you wrote:
| Quote: | Aircraft Spruce # 11-11337
Sent from the Yahoo Mail app. Get yours!
On Tue, Mar 27, 2018 at 2:51 PM, Pat Hatch
<pat_hatch(at)msn.com> wrote:
--> AeroElectric-List message posted by: "Pat Hatch" <pat_hatch(at)msn.com (pat_hatch(at)msn.com)>
Bob, perhaps you can help me find a SPDT (1-5) switch for flap control where the bat doesn't rotate. Years ago you published a piece on how to make a little flap lever out of a solid piece of aluminum that goes over the toggle and gets held there by a couple of set screws. The only ones I have found all have bats or toggles that rotate and this is not good. Do you recall which switch it was? Thanks! |
Yes . . .
You need a switch that with a restrained
handle such as the Honeywell 2TL1-5.
The Dash 5 is a 3 position that is stable
in two extremes and spring loaded out of the
third? Is this the action your seeking?
Shop around a bit . . . they come in all
$sizes$ . . .
https://goo.gl/FQfTRF
https://goo.gl/va48he
Posted: Wed Mar 28, 2018 4:56 am Post subject: Flap Switch |
On Tue, Mar 27, 2018 at 2:51 PM, Pat Hatch <pat_hatch(at)msn.com> wrote: --> AeroElectric-List message posted by: "Pat Hatch" <pat_hatch(at)msn.com (pat_hatch(at)msn.com)>
Yes . . .
$sizes$ . . .
[img]cid:7.1.0.9.0.20180328075345.05fffc70(at)aeroelectric.com.0[/img]
Found a picture of this switch with the nuts
removed. You can see the end of the handle
shaft. Anyone who supplies this kind of switch
as a MilSpec device will probably have the same
feature.
25.29 KB |
13526 Time(s) |
BARRY CHECK 6
Posted: Wed Mar 28, 2018 5:06 am Post subject: Flap Switch |
Pat:
If you LQQK into the switch where the 'bat' enters AND you see a rubber shield. Those switches have a dust/moisture barrier and they do not rotate.
You can make the lever out of aluminum, hardwood or even use a 3D printer.
If you use set-screws do a little grinding on the bat to make a flat for the set-screw to bite into.
Barry
On Wed, Mar 28, 2018 at 8:48 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Yes . . .
$sizes$ . . .
Pat Hatch
