Flap Switch
Pat Hatch
PostPosted: Tue Mar 27, 2018 1:35 pm    Post subject: Flap Switch Reply with quote
Bob, perhaps you can help me find a SPDT (1-5) switch for flap control where the bat doesn't rotate. Years ago you published a piece on how to make a little flap lever out of a solid piece of aluminum that goes over the toggle and gets held there by a couple of set screws. The only ones I have found all have bats or toggles that rotate and this is not good. Do you recall which switch it was? Thanks!
RV-6
RV-7
Flying
Flyitnow
PostPosted: Tue Mar 27, 2018 2:16 pm    Post subject: Flap Switch Reply with quote
Aircraft Spruce # 11-11337
Sent from the Yahoo Mail app. Get yours!
On Tue, Mar 27, 2018 at 2:51 PM, Pat Hatch
<pat_hatch(at)msn.com> wrote:
--> AeroElectric-List message posted by: "Pat Hatch" <pat_hatch(at)msn.com (pat_hatch(at)msn.com)>
RV-6
RV-7
Flying
http://forums.matronics.com/viewtopic.php?p=478894#478894
http://www.matronics.com/Navigator?AeroElectric-L; - MATRONICS WEB FORUMS -
http://forums.matronbsp; - NEW MATRONICS LIST WIKI -
http://wiki.matronics.com
_-========================sp; - List Contribution Web Site -
http://www.matronics.com/contributi======================
JOHN TIPTON
PostPosted: Tue Mar 27, 2018 3:01 pm    Post subject: Re: Flap Switch Reply with quote
Surely this will answer your requirements:
http://www.aircraftspecialty.com/rvall1.html
Pat Hatch
PostPosted: Tue Mar 27, 2018 3:54 pm    Post subject: Re: Flap Switch Reply with quote
Thanks, guys. Actually, I have the flap handle (toggle). I need the switch, one that has a bat that doesn't rotate. All the ones I've tried have a toggle that rotates in the switch such that the flap handle will not stay horizontal.
RV-6
RV-7
Flying
PostPosted: Wed Mar 28, 2018 4:49 am    Post subject: Flap Switch Reply with quote
Yes . . .
You need a switch that with a restrained
handle such as the Honeywell 2TL1-5.
The Dash 5 is a 3 position that is stable
in two extremes and spring loaded out of the
third? Is this the action your seeking?
Shop around a bit . . . they come in all
$sizes$ . . .
https://goo.gl/FQfTRF
https://goo.gl/va48he
PostPosted: Wed Mar 28, 2018 4:56 am    Post subject: Flap Switch Reply with quote
On Tue, Mar 27, 2018 at 2:51 PM, Pat Hatch <pat_hatch(at)msn.com> wrote: --> AeroElectric-List message posted by: "Pat Hatch" <pat_hatch(at)msn.com (pat_hatch(at)msn.com)>
Yes . . .
$sizes$ . . .
[img]cid:7.1.0.9.0.20180328075345.05fffc70(at)aeroelectric.com.0[/img]
Found a picture of this switch with the nuts
removed. You can see the end of the handle
shaft. Anyone who supplies this kind of switch
as a MilSpec device will probably have the same
feature.
 Filesize:  25.29 KB
 Viewed:  13516 Time(s)
BARRY CHECK 6
PostPosted: Wed Mar 28, 2018 5:06 am    Post subject: Flap Switch Reply with quote
Pat:
If you LQQK into the switch where the 'bat' enters AND you see a rubber shield.  Those switches have a dust/moisture barrier and they do not rotate.
You can make the lever out of aluminum, hardwood or even use a 3D printer.
If you use set-screws do a little grinding on the bat to make a flat for the set-screw to bite into.
Barry
On Wed, Mar 28, 2018 at 8:48 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
  Yes . . .
  $sizes$ . . .
Pat Hatch
PostPosted: Tue Apr 03, 2018 2:28 am    Post subject: Re: Flap Switch Reply with quote
  Yes . . .
  $sizes$ . . .
[url=https://goo.gl/FQfTRF]https://goo.gl/FQfTRF[/url]
[u][/u]
[u][/u]   Bob . . .
[/quote][/quote]
Thanks, Bob, that's exactly what I was looking for! Very Happy
RV-6
RV-7
Flying
