kirkhull(at)sbcglobal.net Guest
Posted: Sat Jul 15, 2006 6:28 pm Post subject: broken push rod suberu ea81 |
this pic is of a factory sub part in a Stratus conversion with solid lifters
| Description: |
| Filesize: |
56.59 KB |
| Viewed: |
176 Time(s) |
wingsdown(at)comcast.net Guest
Posted: Sun Jul 16, 2006 11:05 am Post subject: broken push rod suberu ea81 |
Might give Stratus a call, do believe they replaced the stock push rods.
Many good points made reference the break.
Rick
Posted: Sun Jul 16, 2006 3:57 pm Post subject: broken push rod suberu ea81 |
already talked with stratus and they said they use the stock parts. I
replaced it with a stock part from the auto parts store. I was just
wandering what the NSI parts look like and if they are stronger.
szakreski(at)shaw.ca Guest
Posted: Mon Jul 17, 2006 6:24 am Post subject: broken push rod suberu ea81 |
Lance once told me they use the stock pushrod ends however they replace the actual rod with an aluminum rod.
SteveZ
Calgary
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of wingsdown
Sent: Friday, July 14, 2006 6:52 PM
Subject: RE: broken push rod suberu ea81
I will be out to the airport on the 17th and would be most happy to do that.
Rick
