broken push rod suberu ea81
Goto page Previous  1, 2
kirkhull(at)sbcglobal.net
PostPosted: Sat Jul 15, 2006 6:28 pm    Post subject: broken push rod suberu ea81 Reply with quote
this pic is of a factory sub part in a Stratus conversion with solid lifters
 Filesize:  56.59 KB
 Viewed:  221 Time(s)
wingsdown(at)comcast.net
PostPosted: Sun Jul 16, 2006 11:05 am    Post subject: broken push rod suberu ea81 Reply with quote
Might give Stratus a call, do believe they replaced the stock push rods.
Many good points made reference the break.
Rick
PostPosted: Sun Jul 16, 2006 3:57 pm    Post subject: broken push rod suberu ea81 Reply with quote
already talked with stratus and they said they use the stock parts. I
replaced it with a stock part from the auto parts store. I was just
wandering what the NSI parts look like and if they are stronger.
szakreski(at)shaw.ca
PostPosted: Mon Jul 17, 2006 6:24 am    Post subject: broken push rod suberu ea81 Reply with quote
Lance once told me they use the stock pushrod ends however they replace the actual rod with an aluminum rod.
SteveZ
Calgary
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of wingsdown
Sent: Friday, July 14, 2006 6:52 PM
Subject: RE: broken push rod suberu ea81
I will be out to the airport on the 17th and would be most happy to do that.
Rick
Page 2 of 2
