Gust Lock Reviews
philperry9
PostPosted: Wed Aug 09, 2017 11:12 am    Post subject: Gust Lock Reviews Reply with quote
Does anyone have any feedback on the Anti-Splat gust lock for the RV-10?
http://www.aircraftspruce.com/catalog/pspages/gustlocks05-12368.php?clickkey=4469
https://www.youtube.com/watch?v=s5NvoygYcc8
Most specifically, any feedback on how it works/fits with the infinity grips where the sticks had to be cut down to minimum length to fit under the panel...
Phil
tsts4
PostPosted: Wed Aug 09, 2017 12:13 pm    Post subject: Re: Gust Lock Reviews Reply with quote
I have it with Infinity grips and it works as advertised. I didn't make any mods to the stick or panel.
Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying
Kelly McMullen
PostPosted: Wed Aug 09, 2017 3:48 pm    Post subject: Gust Lock Reviews Reply with quote
Phil,
Tim Olson has pretty good instructions on his web site to make your
own. I mostly followed his instructions, although I had to make a few
parts differently as I have Paul Grimstead's Rudder pedal system. I
have AntiSplat cowl flaps, and all his products are a bit spendy for
what they are.
Kelly
-sent from the I-droid implanted in my forearm
On Wed, Aug 9, 2017 at 12:11 PM, Phillip Perry <philperry9(at)gmail.com> wrote:
panel...
Phil
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
Bob Turner
PostPosted: Wed Aug 09, 2017 4:04 pm    Post subject: Re: Gust Lock Reviews Reply with quote
I use the very slightly modified Bogart tow bar as a control (all 3 axes) gust lock. Works fine, no extra weight since I take the tow bar everywhere anyway.
Bob Turner
RV-10 QB
bhoppe2
PostPosted: Wed Aug 09, 2017 5:02 pm    Post subject: Gust Lock Reviews Reply with quote
I have the Antisplat Aero gust lock. It is easy to install and works well. Connects to control stick several inches below the stick grip. A gage is included, which tells you where to mount the attachment bracket on the curved part of the stick. I do not see how it could interfere with any stick grip
Bruce Hoppe
bill.peyton
PostPosted: Thu Aug 10, 2017 6:05 am    Post subject: Re: Gust Lock Reviews Reply with quote
I made this out of PVC. 600 hours and still working well
 Filesize:  64.54 KB
 Viewed:  19134 Time(s)
 Filesize:  68.16 KB
 Viewed:  19132 Time(s)
 Filesize:  71.47 KB
 Filesize:  68.73 KB
 Filesize:  52.48 KB
 Filesize:  56.59 KB
 Filesize:  58.7 KB
WA0SYV
Aviation Partners, LLC
cooprv7(at)yahoo.com
PostPosted: Thu Aug 10, 2017 6:43 am    Post subject: Gust Lock Reviews Reply with quote
Bill,
That's very similar to what I was thinking of making. Does it hold the stick well in roll also?
My cargo strap around the taillight for a rudder lock isn't very professional looking, but it works great.
Marcus
WA0SYV
http://forums.matronics.com/viewtopic.php?p=471699#471699
http://forums.matronics.com//files/img_2857_740.jpg
bill.peyton
PostPosted: Thu Aug 10, 2017 7:02 am    Post subject: Re: Gust Lock Reviews Reply with quote
Yes, it holds the stick and the rudder pedals. I have a #8 screw with a castellated nut that protrudes through the front web that secures the end of the gust lock from lateral movement. You can see it in the photos. Total cost under $10.
WA0SYV
rene(at)felker.com
PostPosted: Thu Aug 10, 2017 7:32 am    Post subject: Gust Lock Reviews Reply with quote
Sorry no picture. I have a PVC model that is an "H". One of my first locks
tied in the stick and it failed when I needed it the most and I got rudder
damage. So I use the "H" pvc for the rudder and seat belt for the Stick.
Rene'
801-721-6080
civengpe
PostPosted: Thu Aug 10, 2017 7:54 am    Post subject: Re: Gust Lock Reviews Reply with quote
I built the PVC gust lock and have been happy with the results as well. Mine looks exactly like the one above, except it doesn't lock the stick. It just goes straight back and wedges on the back wall of the foot well. I use the seat belt for the stick.
larkrv10(at)gmail.com
PostPosted: Thu Aug 10, 2017 9:19 am    Post subject: Gust Lock Reviews Reply with quote
I 'll second Bill's comments wrt the gust lick.
Works very well
Rick
C-GDMH
WA0SYV
http://forums.matronics.com/viewtopic.php?p=471701#471701
Mauledriver(at)nc.rr.com
PostPosted: Thu Aug 10, 2017 11:48 am    Post subject: Gust Lock Reviews Reply with quote
I'm using the Bogey Bar as well.  It's a mandatory item for moving the plane around and just happens to work perfectly as a gust lock.  It seems almost 'tuned' to the RV10 in the sense that it jams down in front of the seat cushion and fits into the rudder pedals without modification.
I used it for a while as is, then added two welded tabs to insure that is stays jammed in the rudder pedals.  Here's some more info:
[url=http://www.mykitlog.com/users/display_log.php?user=MauleDriver&project=224&category=2223&log 0875&row=1]Bogi Tow Bar as Control Lock[/url]
On 8/9/2017 8:04 PM, Bob Turner wrote:
--> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu> (bobturner(at)alum.rpi.edu)
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=471686#471686
arplnplt(at)gmail.com
PostPosted: Thu Aug 10, 2017 4:36 pm    Post subject: Gust Lock Reviews Reply with quote
I made my gust lock similar to all the ones shown out of PVC and an extendable paint roller pole. The ends fit into the top of the break pedals and work as a parking break when installed. A small Velcro strap holds the stick tight against the assembly. The whole thing holds the breaks, rudder, elevator and ailerons when installed.
Dave LeikamN89DA
On Aug 10, 2017, at 2:48 PM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
Bob Turner
RV-10 QB
