philperry9
tsts4
Posted: Wed Aug 09, 2017 12:13 pm Post subject: Re: Gust Lock Reviews |
I have it with Infinity grips and it works as advertised. I didn't make any mods to the stick or panel.
_________________ Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying |
Kelly McMullen
Posted: Wed Aug 09, 2017 3:48 pm Post subject: Gust Lock Reviews |
Phil,
Tim Olson has pretty good instructions on his web site to make your
own. I mostly followed his instructions, although I had to make a few
parts differently as I have Paul Grimstead's Rudder pedal system. I
have AntiSplat cowl flaps, and all his products are a bit spendy for
what they are.
Kelly
-sent from the I-droid implanted in my forearm
On Wed, Aug 9, 2017 at 12:11 PM, Phillip Perry <philperry9(at)gmail.com> wrote:
A&P/IA, EAA Tech Counselor
KCHD |
Bob Turner
Posted: Wed Aug 09, 2017 4:04 pm Post subject: Re: Gust Lock Reviews |
I use the very slightly modified Bogart tow bar as a control (all 3 axes) gust lock. Works fine, no extra weight since I take the tow bar everywhere anyway.
_________________ Bob Turner
RV-10 QB |
bhoppe2
Joined: 09 Apr 2015 Posts: 15 Location: Nolensville, TN
Posted: Wed Aug 09, 2017 5:02 pm Post subject: Gust Lock Reviews |
I have the Antisplat Aero gust lock. It is easy to install and works well. Connects to control stick several inches below the stick grip. A gage is included, which tells you where to mount the attachment bracket on the curved part of the stick. I do not see how it could interfere with any stick grip
_________________ Bruce Hoppe |
bill.peyton
Posted: Thu Aug 10, 2017 6:05 am Post subject: Re: Gust Lock Reviews |
I made this out of PVC. 600 hours and still working well
64.54 KB |
19120 Time(s) |
68.16 KB |
19118 Time(s) |
71.47 KB |
19118 Time(s) |
68.73 KB |
19118 Time(s) |
52.48 KB |
19118 Time(s) |
56.59 KB |
19118 Time(s) |
58.7 KB |
19118 Time(s) |
_________________ Bill
WA0SYV
Aviation Partners, LLC |
cooprv7(at)yahoo.com Guest
Posted: Thu Aug 10, 2017 6:43 am Post subject: Gust Lock Reviews |
Bill,
That's very similar to what I was thinking of making. Does it hold the stick well in roll also?
My cargo strap around the taillight for a rudder lock isn't very professional looking, but it works great.
Marcus
bill.peyton
Posted: Thu Aug 10, 2017 7:02 am Post subject: Re: Gust Lock Reviews |
Yes, it holds the stick and the rudder pedals. I have a #8 screw with a castellated nut that protrudes through the front web that secures the end of the gust lock from lateral movement. You can see it in the photos. Total cost under $10.
WA0SYV
rene(at)felker.com Guest
Posted: Thu Aug 10, 2017 7:32 am Post subject: Gust Lock Reviews |
Sorry no picture. I have a PVC model that is an "H". One of my first locks
tied in the stick and it failed when I needed it the most and I got rudder
damage. So I use the "H" pvc for the rudder and seat belt for the Stick.
Rene'
801-721-6080
civengpe
Posted: Thu Aug 10, 2017 7:54 am Post subject: Re: Gust Lock Reviews |
I built the PVC gust lock and have been happy with the results as well. Mine looks exactly like the one above, except it doesn't lock the stick. It just goes straight back and wedges on the back wall of the foot well. I use the seat belt for the stick.
larkrv10(at)gmail.com Guest
Posted: Thu Aug 10, 2017 9:19 am Post subject: Gust Lock Reviews |
I 'll second Bill's comments wrt the gust lick.
Works very well
Rick
C-GDMH
| Quote: | On Aug 10, 2017, at 11:02 AM, bill.peyton <peyton.b(at)sbcglobal.net> wrote:
WA0SYV
http://forums.matronics.com/viewtopic.php?p=471701#471701
arplnplt(at)gmail.com Guest
Posted: Thu Aug 10, 2017 4:36 pm Post subject: Gust Lock Reviews |
I made my gust lock similar to all the ones shown out of PVC and an extendable paint roller pole. The ends fit into the top of the break pedals and work as a parking break when installed. A small Velcro strap holds the stick tight against the assembly. The whole thing holds the breaks, rudder, elevator and ailerons when installed.
Dave LeikamN89DA
On Aug 10, 2017, at 2:48 PM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
| Quote: | I'm using the Bogey Bar as well. It's a mandatory item for moving the plane around and just happens to work perfectly as a gust lock. It seems almost 'tuned' to the RV10 in the sense that it jams down in front of the seat cushion and fits into the rudder pedals without modification.
I used it for a while as is, then added two welded tabs to insure that is stays jammed in the rudder pedals. Here's some more info:
[url=http://www.mykitlog.com/users/display_log.php?user=MauleDriver&project=224&category=2223&log 0875&row=1]Bogi Tow Bar as Control Lock[/url]
On 8/9/2017 8:04 PM, Bob Turner wrote:
