lcottrell
Posted: Sat May 27, 2017 11:32 am Post subject: Fuel Pump |
There are many schools of thought. "Mine" is that my Facet pumps fuel
to the Mikuni pump, and from there to the engine. I have done so since
1997 with no problems using engines from 447-503-582 to HKS. I try to
keep it as simple as I can. Others may feel differently. Your choice.
Larry
On Sat, May 27, 2017 at 1:19 PM, west1m <west1m(at)hotmail.com> wrote:
Does anyone pump in series (or through) their Mikuni fuel pump?
I ask as I had a wire break off my regulator and eventually lost all power to gauges, EIS and GPS before getting back to home field. It would have been a much shorter flight with only the Facet pump.
West1m
Hastings, MN
http://forums.matronics.com/viewtopic.php?p=469643#469643
The older I get, the less tolerant I am of those who are intolerant of others.
If you forward this email, or any part of it, please remove my email
address before sending.
byoungplumbing(at)gmail.c Guest
Posted: Sat May 27, 2017 12:09 pm Post subject: Fuel Pump |
I pump in series....
Boyd Young mkiii
Richard Pike
Posted: Sat May 27, 2017 12:50 pm Post subject: Re: Fuel Pump |
The Mikuni is perfectly happy to have the Facet feed it, and just as happy when you turn the Facet off, because a properly functioning Mikuni will pull the fuel through a properly functioning (but turned off) Facet.
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
west1m
Joined: 19 Apr 2014 Posts: 155 Location: Hastings, MN
Posted: Sat May 27, 2017 4:06 pm Post subject: Re: Fuel Pump |
Thanks, sounds like a good addition. I looked a t a couple specs on facets (maybe not the one earlier mentioned) browsing around. I saw lift specs as low as 12 inches. Where do you mount the pump? Just right outside the tank rails tank level?
_________________ West1m
Hastings, MN |
west1m
Posted: Sat May 27, 2017 4:09 pm Post subject: Re: Fuel Pump |
I just figured out that is probably a bad question as I have a Firefly with the small 5 gallon tank and is likely completely different than the larger Kolbs.
Hastings, MN |
lcottrell
Posted: Sat May 27, 2017 4:39 pm Post subject: Fuel Pump |
I mounted mine on the boom tube in front of the tanks. Just be sure
that you get the facett pump that the recent discussion was about.
2-3 lbs or something like that.
Larry
gdhelton(at)gmail.com Guest
Posted: Sat May 27, 2017 5:56 pm Post subject: Fuel Pump |
Thanks for asking the same question that I had about still using the pulse pump along with the facet electric pump. I like redundancy when it comes to aircraft fuel systems. And thanks all the good information that was generated
rickofudall
Posted: Sun May 28, 2017 4:38 pm Post subject: Fuel Pump |
George, Congrats on the return to flight. Always good to hear that another Kolb is back in the air.I ran a Facet on my Mk III above the tanks, probably 20 inches of lift and never a problem. Just replumbed the fuel system on my HKS powered trike. A Facet in series with a Mikuni DF52. Flight tested it with a five minute climb at full power with the Facet off. The little HKS never missed a beat. Total lift for the Mikuni about 26 inches.
Safe flying,
Rick
On Sat, May 27, 2017 at 8:56 PM, George Helton <gdhelton(at)gmail.com (gdhelton(at)gmail.com)> wrote:
| Quote: | Thanks for asking the same question that I had about still using the pulse pump along with the facet electric pump. I like redundancy when it comes to aircraft fuel systems. And thanks all the good information that was generated.
I ordered a new rectifier/ regulator, 24V 22000uf capacitor and a 40104 fuel pump last week and am waiting for everything to come. I'm going to run some lift tests before mounting the new pump simply because I would like to mount the facet pump above my fuel tank if it lifts sufficiently? Time will tell?
Oh yeah guys I flew my restored Firestar (original) yesterday! It was its first flight in 28 years and it was sweet.
George H.
Firestar #FS100
Mesick, Michigan
Have a great day!
> On May 27, 2017, at 3:19 PM, west1m <west1m(at)hotmail.com (west1m(at)hotmail.com)> wrote:
> --> Kolb-List message posted by: "west1m" <west1m(at)hotmail.com (west1m(at)hotmail.com)>
> West1m
> Hastings, MN
“Blessed are the cracked, for they shall let in the light.” Groucho Marx
Posted: Sun May 28, 2017 5:03 pm Post subject: Fuel Pump |
Thanks, Rick! I was amazed on how well the little bird flew. It's good to back in a Kolb. Hopefully the weather up here in northern Michigan will finally decide to stop raining and give us fair winds and blue skies.
George H.
Firestar, #FS100
14GDH
Mesick, Mi.
Have a great day!
On May 28, 2017, at 8:36 PM, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
| Quote: | George, Congrats on the return to flight. Always good to hear that another Kolb is back in the air.I ran a Facet on my Mk III above the tanks, probably 20 inches of lift and never a problem. Just replumbed the fuel system on my HKS powered trike. A Facet in series with a Mikuni DF52. Flight tested it with a five minute climb at full power with the Facet off. The little HKS never missed a beat. Total lift for the Mikuni about 26 inches.
Safe flying,
Rick
George H.
Firestar #FS100
Mesick, Michigan
Have a great day!
> West1m
> Hastings, MN
Posted: Mon May 29, 2017 12:01 pm Post subject: Fuel Pump |
Question on installation of the 24V 22000uf capacitor do I just put it between the positive & negative posts on the battery or positive to ground at the Fuel pump? Thanks in advance. George H.
Have a great day!
Safe flying,
Rick
George H.
Firestar #FS100
Mesick, Michigan
Have a great day!
> West1m
> Hastings, MN
Posted: Fri Jun 02, 2017 2:23 pm Post subject: Fuel Pump |
This is thanks to you Kolbers who contributed to my request for information on the Facet fuel pump. I had to add an electrical system to my 1986 Firestar as I'd never really needed one before. I used pretty much all of your input. Here's what I came up with and it seems to work quite well.
I fabricated a mount plate that mounts to the aft cage section directly under the engine mounts. It's mounted using 4 ea. Steel with rubber insulated harness clamps. The mounting plate includes the rectifier/voltage regulator, Facet 40104 fuel pump, 25v22000uf capiciter and sealed lead acid Duracell 12 volt battery. I think the total cost was around $130.00 including wiring and a master power switch. Total weight came out to 3.8 pounds. Here's a couple of pictures. Before and after installation. Thank you all your help.
[img]cid:1AAC3692-A830-4FD1-AFB9-A06A4D034173[/img]
[img]cid:552E4821-85B3-4EBE-B875-909B6BCE2B6B[/img]
George H.
Firestar, FS#100
14GDH
Mesick, Michigan
Have a great day!
Safe flying,
Rick
George H.
Firestar #FS100
Mesick, Michigan
Have a great day!
> West1m
> Hastings, MN
41.34 KB |
19289 Time(s) |
35.92 KB |
19289 Time(s) |
victorbravo(at)sbcglobal. Guest
Posted: Fri Jun 02, 2017 2:47 pm Post subject: Fuel Pump |
PLEASE be careful with having fuel lines and seals and connections just a few inches from a battery and electrical connections !
Bill Berle
www.ezflaphandle.com - safety & performance upgrade for light aircraft
www.grantstar.net - winning proposals for non-profit and for-profit entities
On Fri, 6/2/17, George Helton <gdhelton(at)gmail.com> wrote:
Subject: Re: Re: Fuel Pump
Date: Friday, June 2, 2017, 3:22 PM
This is
quite well. I fabricated a mount
George H.Firestar,
FS#10014GDHMesick,
Michigan gdhelton(at)gmail.comHave a great
day!
On May 28,
2017, at 8:36 PM, Richard Girard <aslsa.rng(at)gmail.com>
inches.Safe
flying,Rick
8:56 PM, George Helton <gdhelton(at)gmail.com>
sweet.
George H.
Firestar #FS100
Mesick, Michigan
Have a great day!
> On May 27, 2017, at 3:19 PM, west1m <west1m(at)hotmail.com>
fuel pump?
> West1m
> Hastings, MN
“Blessed are
Marx
Posted: Fri Jun 02, 2017 3:07 pm Post subject: Fuel Pump |
I still have heat shrink the terminal connections on the battery wires. Thanks for the reply. George H.
Have a great day!
| Quote: | On Jun 2, 2017, at 6:47 PM, Bill Berle <victorbravo(at)sbcglobal.net> wrote:
Bill Berle
This is
George H.Firestar,
FS#10014GDHMesick,
day!
On May 28,
inches.Safe
flying,Rick
sweet.
George H.
Firestar #FS100
Mesick, Michigan
Have a great day!
fuel pump?
> West1m
> Hastings, MN
“Blessed are
Marx
mojaveclimber
Posted: Fri Jun 02, 2017 5:13 pm Post subject: Fuel Pump |
West1mI have flow my R582 powered Mk3 for four plus years operating in series with good result. Tank to filter to electric powered pump to vacuum pulse pump to filters to carbs.
On Fri, Jun 2, 2017 at 4:06 PM, George Helton <gdhelton(at)gmail.com (gdhelton(at)gmail.com)> wrote:
| Quote: | --> Kolb-List message posted by: George Helton <gdhelton(at)gmail.com (gdhelton(at)gmail.com)>
Have a great day!
> On Jun 2, 2017, at 6:47 PM, Bill Berle <victorbravo(at)sbcglobal.net (victorbravo(at)sbcglobal.net)> wrote:
> --> Kolb-List message posted by: Bill Berle <victorbravo(at)sbcglobal.net (victorbravo(at)sbcglobal.net)>
> Bill Berle
> On Fri, 6/2/17, George Helton <gdhelton(at)gmail.com (gdhelton(at)gmail.com)> wrote:
> To: kolb-list(at)matronics.com (kolb-list(at)matronics.com)
> This is
> George H.Firestar,
> FS#10014GDHMesick,
> day!
> On May 28,
> inches.Safe
> flying,Rick
> wrote:
> Thanks
> sweet.
> George H.
> Firestar #FS100
> Mesick, Michigan
> Have a great day!
> fuel pump?
>> West1m
>> Hastings, MN
> “Blessed are
> Marx
west1m
Posted: Sat Jun 03, 2017 6:10 am Post subject: Re: Fuel Pump |
Thanks for the input on plumbing. I think I will replace the squeeze bulb thingie with a facet. There should be a good place by the tank to mount it.
Hastings, MN |
Posted: Sat Jun 03, 2017 10:09 am Post subject: Fuel Pump |
I finished the installation of my Facet pump(#40140) this morning. I had put a electrical system in my Firestar because it never had one. I had heatshrink the exposed battery terminals. Didn't think want any change of sparkies around my pump and fuel lines.
Does anyone remember back in the 80's when we flew the Eipper MX's and MXL's with 5 gallons of fuel right over our heads and a screaming Cayuna or Rotax with its hot exhaust right behind us? They were a lot of fun!
George H.
Firestar, #FS100
14GDH
Mesick, Michigan
Have a great day!
| Quote: | On Jun 3, 2017, at 10:10 AM, west1m <west1m(at)hotmail.com> wrote:
West1m
Hastings, MN
http://forums.matronics.com/viewtopic.php?p=469809#469809
west1m
Posted: Sun Jun 04, 2017 7:05 am Post subject: Re: Fuel Pump |
I do remember the Eipper and the Cayuna. That was the engine that liked to quit at the most inopportune times. I had a Weedhopper before that with a single cyl motor hanging out on the end of a pole that just flopped back and forth on a couple for bolts. It two alligator clips that hooked to 6V lantern battery to run the Ford ignition coil.
http://www.west1m.com/flyin/index.html
Hastings, MN |
Posted: Sun Jun 04, 2017 8:42 am Post subject: Fuel Pump |
Good times.
Have a great day!
| Quote: | On Jun 4, 2017, at 11:05 AM, west1m <west1m(at)hotmail.com> wrote:
West1m
Hastings, MN
http://forums.matronics.com/viewtopic.php?p=469822#469822
