Spider Identification
vernon.franklin(at)gmail.
PostPosted: Tue Mar 28, 2017 4:51 am    Post subject: Spider Identification Reply with quote
Could someone help me identify what this GAGE connection is?  How should I terminate it?
Is this an overflow?
Thanks!
[img]cid:ii_15b14f6755030dab[/img]
Vernon Franklin
 Filesize:  1.85 MB
 Viewed:  6216 Time(s)
Dave Saylor
PostPosted: Tue Mar 28, 2017 6:08 am    Post subject: Spider Identification Reply with quote
If you have a fuel flow sensor like the red cube, etc., you can just cap it.  It's used by some installations to display fuel pressure (often converted to fuel flow) in the cockpit.--Dave
On Tue, Mar 28, 2017 at 5:50 AM, Vernon Franklin <vernon.franklin(at)gmail.com (vernon.franklin(at)gmail.com)> wrote:
Thanks!
Vernon Franklin
 Filesize:  1.85 MB
 Viewed:  6213 Time(s)
--Dave
KWVI
Lenny Iszak
PostPosted: Tue Mar 28, 2017 6:16 am    Post subject: Re: Spider Identification Reply with quote
I plugged it. Here's a picture of my spider and a diagram from the Silverhawk manual.
Thanks!
Vernon Franklin
 Filesize:  48.85 KB
 Viewed:  6201 Time(s)
 Filesize:  784.86 KB
Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 500 hrs
Don Orrick
PostPosted: Tue Mar 28, 2017 7:25 am    Post subject: Spider Identification Reply with quote
Yes, plug it or it will leak fuel. I thought it was a bleeder but it isn't and won't leak anytime fuel pressure is applied. Only I Kept finding fuel stains on the spyder and finally figured it out.
On Mar 28, 2017, at 9:16 AM, Lenny Iszak <lenard(at)rapiddecision.com> wrote:
> Thanks!
> Vernon Franklin
Lenny
N311LZ
http://forums.matronics.com/viewtopic.php?p=467736#467736
http://forums.matronics.com//files/silverhawk_189.png
http://forums.matronics.com//files/spider_181.png
Bob Turner
PostPosted: Tue Mar 28, 2017 9:02 am    Post subject: Re: Spider Identification Reply with quote
You can find the fitting you need to cap it off at places like Aircraft Spruce.
Bob Turner
RV-10 QB
Tim Olson
PostPosted: Tue Mar 28, 2017 9:13 am    Post subject: Spider Identification Reply with quote
I think I used a 1/8" NPT plug from something else...they're
available all over the place but something tells me we even
got some extras either with the kit or with something
that I bought for the engine or avionics.
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=467755#467755
maca2790
PostPosted: Tue Mar 28, 2017 1:31 pm    Post subject: Spider Identification Reply with quote
Yes I had the same issue as mentioned. Fuel staining the crankcase because of a small leak from the fitting. There were some spare 1/8 NPT plugs in the Fire Wall forward kit and I used one of those to plug it.
Cheers John MacCallum
RV10 41016
VH-DUU
> Bob Turner
> RV-10 QB
